This patch cleans up the 440SPe PCIe register usage. Now only defines
from the include/asm-ppc/4xx_pcie.h are used.
Newer PPC's like 440SPe, 460EX/GT can be equipped with more than 2GB of SDRAM.
To support such configurations, we "only" map the first 2GB via the TLB's. We
need some free virtual address space for the remaining peripherals like, SoC
devices, FLASH etc.
Note that ECC is currently not supported on configurations with more than 2GB
SDRAM. This is because we only map the first 2GB on such systems, and therefore
the ECC parity byte of the remaining area can't be written.
This patch series unifies the AMCC eval board ports by introducing
a common include header for all AMCC eval boards:
include/configs/amcc-common.h
This header now includes all common configuration options/defines which
are removed from the board specific headers.
The reason for this is ease of maintenance and unified look and feel
of all AMCC boards.
This patch removes the used testdram() implementations of the board
that are maintained by myself.
This patch adds fdt (flattened device tree) support to all remaining AMCC
eval boards. Most newer boards already support device tree. With this patch,
all AMCC boards now enable device tree passing from U-Boot to Linux
arch/powerpc kernels.
Since we didn't want to remove features from the configuration, we
decided to increase the U-Boot image size (add one flash sector).
Also changed the default environment definition to make it
independent of such changes.
The latter version stops when "run load" fails for whatever reasons
rendering the combination *a lot* more secure.
Signed-off-by: Detlev Zundel <dzu@denx.de>
On Katmai the complete auto-calibration somehow doesn't seem to
produce the best results, meaning optimal values for RQFD/RFFD.
This was discovered by GDA using a high bandwidth scope,
analyzing the DDR2 signals. GDA provided a fixed value for RQFD,
so now on Katmai "only" RFFD is auto-calibrated.
This patch also adds RDCC calibration as mentioned on page 7 of
the AMCC PowerPC440SP/SPe DDR2 application note:
"DDR1/DDR2 Initialization Sequence and Dynamic Tuning"
All 4xx board config files don't need the cache definitions anymore.
These are now defined in common headers.
On Yucca & Katmai, the inbound memory map pointed to 0x4.0000.0000, which
is the internal SRAM. Since I now ported and tested this endpoint mode
on Kilauea successfully to map to 0 (SDRAM), I also changed this for
Katmai.
Yucca will stay at internal SRAM for now. Not sure if somebody relies on
this setup.
This patch adds support for dynamic configuration of PCIe ports for the
AMCC PPC4xx boards equipped with PCIe interfaces. These are the PPC440SPe
boards Yucca & Katmai and the 405EX board Kilauea.
This dynamic configuration is done via the "pcie_mode" environement
variable. This variable can be set to "EP" or "RP" for endpoint or
rootpoint mode. Multiple values can be joined via the ":" delimiter.
Here an example:
pcie_mode=RP:EP:EP
This way, PCIe port 0 will be configured as rootpoint, PCIe port 1 and 2
as endpoint.
Per default Yucca will be configured as:
pcie_mode=RP:EP:EP
Per default Katmai will be configured as:
pcie_mode=RP:RP:REP
Per default Kilauea will be configured as:
pcie_mode=RP:RP
Signed-off-by: Tirumala R Marri <tmarri@amcc.com>
128MB seems to be the smallest possible value for the memory size
for on PCIe port. With this change now the BAR's of the PCIe cards
are accessible under U-Boot.
One big note: This only works for PCIe port 0 & 1. For port 2 this
currently doesn't work, since the base address is now 0xc0000000
(0xb0000000 + 2 * 0x08000000), and this is already occupied by
CFG_PCIE0_CFGBASE. But solving this issue for port 2 would mean
to change the base addresses completely and this change would have
too much impact right now.
This patch adds debug output to the 4xx pcie driver too.
- 'pciconfighost' is set by default in order to be able to scan bridges
behind the primary host/PCIe
- 'pciscandelay' env variable is recognized to allow for user-controlled
delay before the PCIe bus enumeration; some peripheral devices require a
significant delay before they can be scanned (e.g. LSI8408E); without the
delay they are not detected
Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
- correct configuration space mapping
- correct bus numbering
- better access to config space
Prior to this patch, the 440SPe host/PCIe bridge was able to configure only the
first device on the first bus. We now allow to configure up to 16 buses;
also, scanning for devices behind the PCIe-PCIe bridge is supported, so
peripheral devices farther in hierarchy can be identified.
platforms wishing to display RAM diagnostics in addition to size,
can do so, on one line, in their own board_add_ram_info()
implementation.
this consequently eliminates CONFIG_ADD_RAM_INFO.
Thanks to Stefan for the hint.
Explicitly add in default CONFIG_BOOTP_* options where cmd_confdefs.h
used to be included but CONFIG_BOOTP_MASK was not defined.
Remove lingering references to CFG_CMD_* symbols.
config files.
This patch removes the CFG_PCI_PRE_INIT option completely, since
it's not needed anymore with the patch from Matthias Fuchs with
the "weak" pci_pre_init() implementation.
- Introduced dedicated switches for building 440 and 405 images required
for 440-specific machine instructions like 'rfmci' etc.
- Exception vectors moved to the proper location (_start moved away from
the critical exception handler space, which it occupied)
- CriticalInput now serviced (with default handler)
- MachineCheck properly serviced (added a dedicated handler and return
subroutine)
- Overall cleanup of exceptions declared with STD_EXCEPTION macro (unused,
unhandled and those not relevant for 4xx were eliminated)
- Eliminated Linux leftovers, removed dead code
Signed-off-by: Rafal Jaworowski <raj@semihalf.com>
Previous versions used full wait states for the chip select #1 which
is connected to the Xilinix SystemACE controller on the AMCC Katmai
evaluation board. This leads to really slow access and therefore low
performance. This patch now sets up the chip select a lot faster
resulting in much better read/write performance of the Linux driver.
With this new base address of the Xilinx SystemACE controller
the Linux driver will be easier to adapt, since it can now be
mapped via the "normal" ioremap() call.
This patch updates the recently added Katmai board support. The biggest
change is the support of ECC DIMM modules in the 440SP(e) SPD DDR2
driver.
Please note, that still some problems are left with some memory
configurations. See the driver for more details.
