path: root/include/configs/katmai.h
2016-10-28pci: Move CONFIG_PCI_PNP to KconfigBin Meng
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-generate configs and include/configs/ changes] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-08-05treewide: move CONFIG_PHYS_64BIT to KconfigMasahiro Yamada
We need to ensure that CONFIG_PHYS_64BIT is configured via Kconfig so that it is always available to the build system. Otherwise we can run into cases where we have inconsistent sizes of certain attributes. Ravi Babu reported offset mismatch of struct dwc3 across files since commit 95ebc253e6d4 ("types.h: move and redefine resource_size_t"). Since the commit, resource_addr_t points to phys_addr_t, whose size is dependent on CONFIG_PHYS_64BIT for ARM architecture. I tried my best to use "select" where possible (for example, ARMv8 architecture) because I think this kind of option is generally user- unconfigurable. However, I see some of PowerPC boards have 36BIT defconfigs as well as 32BIT ones. I moved CONFIG_PHYS_64BIT to the defconfigs for such boards. CONFIG_36BIT is no longer referenced, so all of the defines were removed from CONFIG_SYS_EXTRA_OPTIONS. Fixes: 95ebc253e6d4 ("types.h: move and redefine resource_size_t") Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reported-by: Ravi Babu <ravibabu@ti.com> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: York Sun <york.sun@nxp.com>
2015-11-21eeprom: Zap CONFIG_SYS_I2C_MULTI_EEPROMSMarek Vasut
This option only complicates the code unnecessarily, just use CONFIG_SYS_DEF_EEPROM_ADDR as the default address if there are only five arguments to eeprom {read/write} if this is defined. If CONFIG_SYS_DEF_EEPROM_ADDR is not defined, we mandate all six arguments. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Tom Rini <trini@konsulko.com> Cc: Heiko Schocher <hs@denx.de> Reviewed-by: Heiko Schocher <hs@denx.de>
2014-01-24powerpc: ppc4xx: remove redundant CONFIG_4xx definitionMasahiro Yamada
We do not have to define CONFIG_4xx in board config headers because it is defined in arch/powerpc/cpu/ppc4xx/config.mk. include/configs/JSE.h defines "CONFIG_4x", not "CONFIG_4xx". I believe it is a typo because "CONFIG_4x" is not used at all in other files. So, I also deleted "CONFIG_4x" in include/configs/JSE.h. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, ppc4xx_i2c: switch to new multibus/multiadapter supportDirk Eibach
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Heiko Schocher <hs@denx.de> Cc: Stefan Roese <sr@denx.de> Tested-by: Stefan Roese <sr@denx.de>
2013-06-07pci: introduce CONFIG_PCI_INDIRECT_BRIDGE optionGabor Juhos
The pci_indirect.c file is always compiled when CONFIG_PCI is defined although the indirect PCI bridge support is not needed by every board. Introduce a new CONFIG_PCI_INDIRECT_BRIDGE config option and only compile indirect PCI bridge support if this options is enabled. Also add the new option into the configuration files of the boards which needs that. Compile tested for powerpc, x86, arm and nds32. MAKEALL results: powerpc: --------------------- SUMMARY ---------------------------- Boards compiled: 641 Boards with warnings but no errors: 2 ( ELPPC MPC8323ERDB ) ---------------------------------------------------------- Note: the warnings for ELPPC and MPC8323ERDB are present even without the actual patch. x86: --------------------- SUMMARY ---------------------------- Boards compiled: 1 ---------------------------------------------------------- arm: --------------------- SUMMARY ---------------------------- Boards compiled: 311 ---------------------------------------------------------- nds32: --------------------- SUMMARY ---------------------------- Boards compiled: 3 ---------------------------------------------------------- Cc: Tom Rini <trini@ti.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Signed-off-by: Gabor Juhos <juhosg@openwrt.org>
2010-09-28Merge branch 'next' of /home/wd/git/u-boot/nextWolfgang Denk
Conflicts: include/ppc4xx.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-23ppc4xx: Use common NS16550 driver for PPC4xx UARTStefan Roese
This patch removes the PPC4xx UART driver. Instead the common NS16550 driver is used, since all PPC4xx SoC's use this peripheral device. The file 4xx_uart.c now only implements the UART clock calculation function which also sets the SoC internal UART divisors. All PPC4xx board config headers are changed to use this common NS16550 driver now. Tested on these boards: acadia, canyonlands, katmai, kilauea, sequoia, zeus Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-21POST cleanup.Michael Zaidman
- Revives POST for blackfin arch; - Removes redundant code: arch/blackfin/lib/post.c arch/powerpc/cpu/ppc4xx/commproc.c arch/powerpc/cpu/mpc512x/common.c - fixes up the post_word_{load|store} usage. Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de> List of the maintainers of the affected by patch boards: Cc: Stephan Linz <linz@li-pro.net> Cc: Denis Peter <d.peter@mpl.ch> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Larry Johnson <lrj@acm.org> Cc: Feng Kan <fkan@amcc.com>
2010-08-09ppc4xx: Fix/Update katmai board headerStefan Roese
This patch has the following fixes/changes: - Set 'kernel_addr' and 'ramdisk_addr' to correct values and add 'fdt_addr' environment variable - Remove 'kozio' environment variable - Remove environmant variables to boot ancient arch/ppc Linux kernels - Remove CONFIG_SYS_BOOTMAPSZ definition. It's already defined to the same value in amcc-common.h Signed-off-by: Stefan Roese <sr@denx.de>
2010-07-23ppc4xx: Enable "ecctest" command on katmaiStefan Roese
2010-04-14ppc4xx: Add option for PPC440SPe ports without old Rev. A supportStefan Roese
The 440SPe Rev. A is quite old and newer 440SPe boards don't need support for this CPU revision. Since removing support for this older version simplifies the creation for newer U-Boot ports, this patch now enables 440SPe > Rev. A support by creating the CONFIG_440SPE_REVA define. By defining this in the board config header, Rev. A will still be supported. Otherwise (default for newer board ports), Rev. A will not be supported. Signed-off-by: Stefan Roese <sr@denx.de>
2009-11-10ppc4xx: Katmai: Add chip_config commandStefan Roese
This patch removes the Katmai "bootstrap" command and replaces it with the now common command "chip_config". Signed-off-by: Stefan Roese <sr@denx.de>
2009-06-12i2c: Remove deprecated individual i2c commandsPeter Tyser
The following individual I2C commands have been removed: imd, imm, inm, imw, icrc32, iprobe, iloop, isdram. The functionality of the individual commands is still available via the 'i2c' command. This change only has an impact on those boards which did not have CONFIG_I2C_CMD_TREE defined. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-02-12ppc4xx: Fix problem with CONFIG_MAX_MEM_MAPPED in include/asm-ppc/config.hStefan Roese
CONFIG_SDRAM_PPC4xx_IBM_DDR2 is not set when include/asm-ppc/config.h is included. So for katmai, CONFIG_MAX_MEM_MAPPED will get set to 256MB. It makes perfect sense to set CONFIG_MAX_MEM_MAPPED to 2GB for all PPC4xx boards right now. Signed-off-by: Stefan Roese <sr@denx.de>
2008-11-21ppc4xx: katmai: Change default configYuri Tikhonov
This patch enables support for EXT2, and increases the CONFIG_SYS_BOOTMAPSZ size for the default configuration of the katmai boards to use them as the RAID-reference AMCC setups. EXT2 enabling allows one to boot kernels from the EXT2 formatted Compact Flash cards. CONFIG_SYS_BOOTMAPSZ increasing allows one to boot the Linux kernels, which use PAGE_SIZE of 256KB. Otherwise, the memory area with DTB file (which is placed at the end of the bootmap area) will turn out to be overlapped with the BSS segment of the 256KB kernel, and zeroed in early_init() of Linux. Actually, increasing of the bootmap size could be done via setting of the bootm_size U-Boot variable, but it looks like the current U-Boot implementation have some bootm_size- related functionality lost. In many places through the U-Boot code the CONFIG_SYS_BOOTMAPSZ definition is used directly (instead of trying to read the corresponding value from the environment). The same is truth for the boot_jump_linux() function in lib_ppc/bootm.c, where U-Boot transfers control to Linux passing the CONFIG_SYS_BOOTMAPSZ (not bootm_size) value to the booting kernel. Signed-off-by: Yuri Tikhonov <yur@emcraft.com> Signed-off-by: Ilya Yanok <yanok@emcraft.com> Signed-off-by: Stefan Roese <sr@denx.de>
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2008-08-13Merge branch 'Makefile' of git://git.denx.de/u-boot-armWolfgang Denk
2008-07-11ppc4xx: Cleanup Katmai & Yucca PCIe register usageStefan Roese
This patch cleans up the 440SPe PCIe register usage. Now only defines from the include/asm-ppc/4xx_pcie.h are used. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-10ppc4xx: Enable support for > 2GB SDRAM on AMCC KatmaiStefan Roese
Newer PPC's like 440SPe, 460EX/GT can be equipped with more than 2GB of SDRAM. To support such configurations, we "only" map the first 2GB via the TLB's. We need some free virtual address space for the remaining peripherals like, SoC devices, FLASH etc. Note that ECC is currently not supported on configurations with more than 2GB SDRAM. This is because we only map the first 2GB on such systems, and therefore the ECC parity byte of the remaining area can't be written. Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-06ppc4xx: Unify AMCC's board config files (part 2/3)Stefan Roese
This patch series unifies the AMCC eval board ports by introducing a common include header for all AMCC eval boards: include/configs/amcc-common.h This header now includes all common configuration options/defines which are removed from the board specific headers. The reason for this is ease of maintenance and unified look and feel of all AMCC boards. Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-03ppc4xx: Remove implementations of testdram()Stefan Roese
This patch removes the used testdram() implementations of the board that are maintained by myself. Signed-off-by: Stefan Roese <sr@denx.de>
2008-05-08ppc4xx: Add fdt support to all remaining AMCC PPC4xx eval boardsStefan Roese
This patch adds fdt (flattened device tree) support to all remaining AMCC eval boards. Most newer boards already support device tree. With this patch, all AMCC boards now enable device tree passing from U-Boot to Linux arch/powerpc kernels. Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-29ppc4xx: Fix CFG_MONITOR_LEN on Katmai failsave this timeStefan Roese
2008-04-29ppc4xx: Fix Katmai CFG_MONITOR_LENStefan Roese
2008-04-28katmai: fix section overlap problemWolfgang Denk
Since we didn't want to remove features from the configuration, we decided to increase the U-Boot image size (add one flash sector). Also changed the default environment definition to make it independent of such changes. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2008-03-06Replace "run load; run update" with conditionalized "run load update".Detlev Zundel
The latter version stops when "run load" fails for whatever reasons rendering the combination *a lot* more secure. Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2008-01-05ppc4xx: Update Katmai/44x_spd_ddr2.c code for optimal DDR2 setupStefan Roese
On Katmai the complete auto-calibration somehow doesn't seem to produce the best results, meaning optimal values for RQFD/RFFD. This was discovered by GDA using a high bandwidth scope, analyzing the DDR2 signals. GDA provided a fixed value for RQFD, so now on Katmai "only" RFFD is auto-calibrated. This patch also adds RDCC calibration as mentioned on page 7 of the AMCC PowerPC440SP/SPe DDR2 application note: "DDR1/DDR2 Initialization Sequence and Dynamic Tuning" Signed-off-by: Stefan Roese <sr@denx.de>
2007-12-27ppc4xx: Add fdt support to AMCC Katmai eval boardStefan Roese
2007-10-31ppc4xx: Remove cache definition from 4xx board config filesStefan Roese
All 4xx board config files don't need the cache definitions anymore. These are now defined in common headers. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Add SNTP support to AMCC Katmai, Kilauea & Makalu boardsStefan Roese
2007-10-31ppc4xx: Change inbound PCIe location for endpoint tests on KatmaiStefan Roese
On Yucca & Katmai, the inbound memory map pointed to 0x4.0000.0000, which is the internal SRAM. Since I now ported and tested this endpoint mode on Kilauea successfully to map to 0 (SDRAM), I also changed this for Katmai. Yucca will stay at internal SRAM for now. Not sure if somebody relies on this setup. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Dynamic configuration of 4xx PCIe mode as root or endpoint modeStefan Roese
This patch adds support for dynamic configuration of PCIe ports for the AMCC PPC4xx boards equipped with PCIe interfaces. These are the PPC440SPe boards Yucca & Katmai and the 405EX board Kilauea. This dynamic configuration is done via the "pcie_mode" environement variable. This variable can be set to "EP" or "RP" for endpoint or rootpoint mode. Multiple values can be joined via the ":" delimiter. Here an example: pcie_mode=RP:EP:EP This way, PCIe port 0 will be configured as rootpoint, PCIe port 1 and 2 as endpoint. Per default Yucca will be configured as: pcie_mode=RP:EP:EP Per default Katmai will be configured as: pcie_mode=RP:RP:REP Per default Kilauea will be configured as: pcie_mode=RP:RP Signed-off-by: Tirumala R Marri <tmarri@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: 4xx_pcie: More general cleanup and 405EX PCIe support addedStefan Roese
2007-10-31ppc4xx: 4xx_pcie: Change CFG_PCIE_MEMSIZE to 128MB on Yucca & KatmaiStefan Roese
128MB seems to be the smallest possible value for the memory size for on PCIe port. With this change now the BAR's of the PCIe cards are accessible under U-Boot. One big note: This only works for PCIe port 0 & 1. For port 2 this currently doesn't work, since the base address is now 0xc0000000 (0xb0000000 + 2 * 0x08000000), and this is already occupied by CFG_PCIE0_CFGBASE. But solving this issue for port 2 would mean to change the base addresses completely and this change would have too much impact right now. This patch adds debug output to the 4xx pcie driver too. Signed-off-by: Stefan Roese <sr@denx.de>
2007-09-07[PPC440SPe] PCIe environment settings for Katmai and YuccaGrzegorz Bernacki
- 'pciconfighost' is set by default in order to be able to scan bridges behind the primary host/PCIe - 'pciscandelay' env variable is recognized to allow for user-controlled delay before the PCIe bus enumeration; some peripheral devices require a significant delay before they can be scanned (e.g. LSI8408E); without the delay they are not detected Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
2007-09-07[PPC440SPe] Improve PCIe configuration space accessGrzegorz Bernacki
- correct configuration space mapping - correct bus numbering - better access to config space Prior to this patch, the 440SPe host/PCIe bridge was able to configure only the first device on the first bus. We now allow to configure up to 16 buses; also, scanning for devices behind the PCIe-PCIe bridge is supported, so peripheral devices farther in hierarchy can be identified. Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
