path: root/include/configs/katmai.h
2008-10-14Remove unused CFG_EEPROM_PAGE_WRITE_ENABLE referencesPeter Tyser
2008-08-13Merge branch 'Makefile' of git://git.denx.de/u-boot-armWolfgang Denk
2008-07-11ppc4xx: Cleanup Katmai & Yucca PCIe register usageStefan Roese
This patch cleans up the 440SPe PCIe register usage. Now only defines from the include/asm-ppc/4xx_pcie.h are used. Signed-off-by: Stefan Roese <sr@denx.de>
2008-07-10ppc4xx: Enable support for > 2GB SDRAM on AMCC KatmaiStefan Roese
Newer PPC's like 440SPe, 460EX/GT can be equipped with more than 2GB of SDRAM. To support such configurations, we "only" map the first 2GB via the TLB's. We need some free virtual address space for the remaining peripherals like, SoC devices, FLASH etc. Note that ECC is currently not supported on configurations with more than 2GB SDRAM. This is because we only map the first 2GB on such systems, and therefore the ECC parity byte of the remaining area can't be written. Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-06ppc4xx: Unify AMCC's board config files (part 2/3)Stefan Roese
This patch series unifies the AMCC eval board ports by introducing a common include header for all AMCC eval boards: include/configs/amcc-common.h This header now includes all common configuration options/defines which are removed from the board specific headers. The reason for this is ease of maintenance and unified look and feel of all AMCC boards. Signed-off-by: Stefan Roese <sr@denx.de>
2008-06-03ppc4xx: Remove implementations of testdram()Stefan Roese
This patch removes the used testdram() implementations of the board that are maintained by myself. Signed-off-by: Stefan Roese <sr@denx.de>
2008-05-08ppc4xx: Add fdt support to all remaining AMCC PPC4xx eval boardsStefan Roese
This patch adds fdt (flattened device tree) support to all remaining AMCC eval boards. Most newer boards already support device tree. With this patch, all AMCC boards now enable device tree passing from U-Boot to Linux arch/powerpc kernels. Signed-off-by: Stefan Roese <sr@denx.de>
2008-04-29ppc4xx: Fix CFG_MONITOR_LEN on Katmai failsave this timeStefan Roese
2008-04-29ppc4xx: Fix Katmai CFG_MONITOR_LENStefan Roese
2008-04-28katmai: fix section overlap problemWolfgang Denk
Since we didn't want to remove features from the configuration, we decided to increase the U-Boot image size (add one flash sector). Also changed the default environment definition to make it independent of such changes. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2008-03-06Replace "run load; run update" with conditionalized "run load update".Detlev Zundel
The latter version stops when "run load" fails for whatever reasons rendering the combination *a lot* more secure. Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2008-01-05ppc4xx: Update Katmai/44x_spd_ddr2.c code for optimal DDR2 setupStefan Roese
On Katmai the complete auto-calibration somehow doesn't seem to produce the best results, meaning optimal values for RQFD/RFFD. This was discovered by GDA using a high bandwidth scope, analyzing the DDR2 signals. GDA provided a fixed value for RQFD, so now on Katmai "only" RFFD is auto-calibrated. This patch also adds RDCC calibration as mentioned on page 7 of the AMCC PowerPC440SP/SPe DDR2 application note: "DDR1/DDR2 Initialization Sequence and Dynamic Tuning" Signed-off-by: Stefan Roese <sr@denx.de>
2007-12-27ppc4xx: Add fdt support to AMCC Katmai eval boardStefan Roese
2007-10-31ppc4xx: Remove cache definition from 4xx board config filesStefan Roese
All 4xx board config files don't need the cache definitions anymore. These are now defined in common headers. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Add SNTP support to AMCC Katmai, Kilauea & Makalu boardsStefan Roese
2007-10-31ppc4xx: Change inbound PCIe location for endpoint tests on KatmaiStefan Roese
On Yucca & Katmai, the inbound memory map pointed to 0x4.0000.0000, which is the internal SRAM. Since I now ported and tested this endpoint mode on Kilauea successfully to map to 0 (SDRAM), I also changed this for Katmai. Yucca will stay at internal SRAM for now. Not sure if somebody relies on this setup. Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: Dynamic configuration of 4xx PCIe mode as root or endpoint modeStefan Roese
This patch adds support for dynamic configuration of PCIe ports for the AMCC PPC4xx boards equipped with PCIe interfaces. These are the PPC440SPe boards Yucca & Katmai and the 405EX board Kilauea. This dynamic configuration is done via the "pcie_mode" environement variable. This variable can be set to "EP" or "RP" for endpoint or rootpoint mode. Multiple values can be joined via the ":" delimiter. Here an example: pcie_mode=RP:EP:EP This way, PCIe port 0 will be configured as rootpoint, PCIe port 1 and 2 as endpoint. Per default Yucca will be configured as: pcie_mode=RP:EP:EP Per default Katmai will be configured as: pcie_mode=RP:RP:REP Per default Kilauea will be configured as: pcie_mode=RP:RP Signed-off-by: Tirumala R Marri <tmarri@amcc.com> Signed-off-by: Stefan Roese <sr@denx.de>
2007-10-31ppc4xx: 4xx_pcie: More general cleanup and 405EX PCIe support addedStefan Roese
2007-10-31ppc4xx: 4xx_pcie: Change CFG_PCIE_MEMSIZE to 128MB on Yucca & KatmaiStefan Roese
128MB seems to be the smallest possible value for the memory size for on PCIe port. With this change now the BAR's of the PCIe cards are accessible under U-Boot. One big note: This only works for PCIe port 0 & 1. For port 2 this currently doesn't work, since the base address is now 0xc0000000 (0xb0000000 + 2 * 0x08000000), and this is already occupied by CFG_PCIE0_CFGBASE. But solving this issue for port 2 would mean to change the base addresses completely and this change would have too much impact right now. This patch adds debug output to the 4xx pcie driver too. Signed-off-by: Stefan Roese <sr@denx.de>
2007-09-07[PPC440SPe] PCIe environment settings for Katmai and YuccaGrzegorz Bernacki
- 'pciconfighost' is set by default in order to be able to scan bridges behind the primary host/PCIe - 'pciscandelay' env variable is recognized to allow for user-controlled delay before the PCIe bus enumeration; some peripheral devices require a significant delay before they can be scanned (e.g. LSI8408E); without the delay they are not detected Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
2007-09-07[PPC440SPe] Improve PCIe configuration space accessGrzegorz Bernacki
- correct configuration space mapping - correct bus numbering - better access to config space Prior to this patch, the 440SPe host/PCIe bridge was able to configure only the first device on the first bus. We now allow to configure up to 16 buses; also, scanning for devices behind the PCIe-PCIe bridge is supported, so peripheral devices farther in hierarchy can be identified. Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com>
2007-08-18lib_ppc: make board_add_ram_info weakKim Phillips
platforms wishing to display RAM diagnostics in addition to size, can do so, on one line, in their own board_add_ram_info() implementation. this consequently eliminates CONFIG_ADD_RAM_INFO. Thanks to Stefan for the hint. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-07-10include/configs/[p-z]* + misc: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various j* and k* named board ↵Jon Loeliger
config files. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-06-25ppc4xx: Add pci_pre_init() for 405 boardsStefan Roese
This patch removes the CFG_PCI_PRE_INIT option completely, since it's not needed anymore with the patch from Matthias Fuchs with the "weak" pci_pre_init() implementation. Signed-off-by: Stefan Roese <sr@denx.de>
2007-06-20Coding style cleanup. Refresh CHANGELOG.Wolfgang Denk
2007-06-15ppc4xx: Clean up 440 exceptions handlingGrzegorz Bernacki
- Introduced dedicated switches for building 440 and 405 images required for 440-specific machine instructions like 'rfmci' etc. - Exception vectors moved to the proper location (_start moved away from the critical exception handler space, which it occupied) - CriticalInput now serviced (with default handler) - MachineCheck properly serviced (added a dedicated handler and return subroutine) - Overall cleanup of exceptions declared with STD_EXCEPTION macro (unused, unhandled and those not relevant for 4xx were eliminated) - Eliminated Linux leftovers, removed dead code Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Signed-off-by: Rafal Jaworowski <raj@semihalf.com> Signed-off-by: Stefan Roese <sr@denx.de>
2007-04-19ppc4xx: Fix chip select timing for SysACE access on AMCC KatmaiStefan Roese
Previous versions used full wait states for the chip select #1 which is connected to the Xilinix SystemACE controller on the AMCC Katmai evaluation board. This leads to really slow access and therefore low performance. This patch now sets up the chip select a lot faster resulting in much better read/write performance of the Linux driver. Signed-off-by: Stefan Roese <sr@denx.de>
2007-04-02ppc4xx: Change SysACE address on KatmaiStefan Roese
With this new base address of the Xilinx SystemACE controller the Linux driver will be easier to adapt, since it can now be mapped via the "normal" ioremap() call. Signed-off-by: Stefan Roese <sr@denx.de>
2007-03-08ppc4xx: Small AMCC Katmai 440SPe updateStefan Roese
2007-03-01[PATCH] Update AMCC Katmai 440SPe eval board supportStefan Roese
This patch updates the recently added Katmai board support. The biggest change is the support of ECC DIMM modules in the 440SP(e) SPD DDR2 driver. Please note, that still some problems are left with some memory configurations. See the driver for more details. Signed-off-by: Stefan Roese <sr@denx.de>
2007-02-20[PATCH] Add support for the AMCC Katmai (440SPe) eval boardStefan Roese
