Move the individual keystone 2 SoC symbols to the mach Kconfig file,
select them as needed.
Rename CONFIG_ENV_KS2_BOARD_SETTINGS to ENV_KS2_BOARD_SETTINGS so that
it better fits with the rest of the environment addition macros.
Cc: Vitaly Andrianov <vitalya@ti.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
The ISW_ENTRY_ADDR Kconfig option under mach-omap2 isn't a SoC specific
notion but rather "where is our previous stage loaded in memory?"
option. Make use of this on ARCH_KEYSTONE rather than SPL_TEXT_BASE for
our HS builds that are not using SPL anyhow.
Cc: Andrew F. Davis <afd@ti.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com?
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
This patch updates the default u-boot env for K2L HS devices
to install the secure boot monitor and load the fitImage during
boot.
Signed-off-by: Madan Srinivas <madans@ti.com>
Acked-by: Andrew F. Davis <afd@ti.com>
CONFIG_ENV_IS_IN_MMC
CONFIG_ENV_IS_IN_NAND
CONFIG_ENV_IS_IN_UBI
CONFIG_ENV_IS_NOWHERE
In fact this already exists for sunxi as a 'choice' config. However not
all the choices are available in Kconfig yet so we cannot use that. It
would lead to more than one option being set.
In addition, one purpose of this series is to allow the environment to be
stored in more than one place. So the existing choice is converted to a
normal config allowing each option to be set independently.
There are not many opportunities for Kconfig updates to reduce the size of
this patch. This was tested with
./tools/moveconfig.py -i CONFIG_ENV_IS_IN_MMC
And then manual updates. This is because for CHAIN_OF_TRUST boards they
can only have ENV_IS_NOWHERE set, so we enforce that via Kconfig logic
now.
Not all TI Keystone2 EVMs want environment in NAND flash.
K2G EVM which has an MMC/SD slot, keep environment in a
FAT partition on SD card.
Since ti_armv7_keystone2.h defines environment is in NAND,
boards which do not follow that have to #undef'ine that
configuration. This leads to ugly ordering issues around
where exactly the include of ti_armv7_keystone2.h can come
in within the k2*_evm.h files.
Move environment location to config file of each board.
This should make it easy to change it for any one board
without affecting all other boards.
Signed-off-by: Sekhar Nori <nsekhar@ti.com>
SPI U-Boot image for K2 boards have now exceeded 512K partition
allocated to it and no longer fit the partitions defined in kernel DTS
file. Therefore, pass an updated MTD partition table from U-Boot as
kernel command line arguments to avoid kernel from accidentally
modifying boot loader image that has overflowed to next user partition.
To do is, introduce a common environment file for declaring SPI
partition so that each individual boards need not repeat the same.
Choose appropriate SPI bus from board config file and pass it as command
line argument to kernel.
Signed-off-by: Vignesh R <vigneshr@ti.com>
The config option TARGET_K2x_EVM is set by the k2x defconfigs to pick
a board target, but the header configs also set K2x_EVM. This config
is redundant, remove it and use TARGET_K2x_EVM everywhere in its place.
Signed-off-by: Andrew F. Davis <afd@ti.com>
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
As boot monitor contains a mkimage header, it can be loaded at any location.
So, have a common addr_mon address across all keystone2 SoCs. And also
making sure that boot monitor is installed early during default boot to
avoid any overlapping with other images.
Now that all Keystone2 dts file names are changed in Linux kernel, reflect the
same in evn variables inorder to find the right dtb file.
For k2l, k2e and k2hk, ubi is set to default boot in uboot
environment settings; while for k2g, mmc should be the
default boot. This patch is to set mmc as default for k2g-evm
Signed-off-by: Yan Liu <yan-liu@ti.com>
This patch updates the env script to include a initramfs with firmware
loaded and provided to kernel through second argument of bootz command
during boot. Defined DEFAULT_FW_INITRAMFS_BOOT_ENV to have all of the
required env variables and use it in evm specific config file.
The K2 linux drivers for PCIe and NetCP (1G, 10G) requires serdes
firmwares. These requires firmware to be available early through the boot
process in some cases to satisfy firmware requests from driver. Hence use
a small initramfs to provide the same and update boot env to accommodate
this in the boot flow. This method is used when rootfs is nfs and ubifs.
This fs contains just lib/firmware folder with all required firmware.
When rootfs is on initramfs, then the filesystem has the firmware under
lib/firmware and this early initramfs is not required and is not used.
Signed-off-by: Murali Karicheri <m-karicheri2@ti.com>
using http://git.ti.com/keystone-linux/boot-monitor/trees/master as
reference (tag K2_BM_15.07) the generated files do not have evm
extensions by default. So dont use -evm extension.
Reviewed-by: Murali Karicheri <m-karicheri2@ti.com>
Signed-off-by: Nishanth Menon <nm@ti.com>
Switch to using zImage instead of uImage. and while at it, start using
bootz as default. While at it, get rid of BOOTIMAGE define and start
using Linux upstream dtb file names.
Try to maintain as much commonality by conditionally including stuff
in armv7_common as necessary and removing the common defines from
keystone2 header.
Note: as part of this change, all keystone2 platforms will now start
using the generic u-boot prompt instead of the custom prompt.
rename the keystone2 common header into an keystone2 architecture
specific header which can then reuse the common ti_armv7 config headers.
Acked-by: Vitaly Andrianov <vitalya@ti.com>
Acked-By: Murali Karicheri <m-karicheri2@ti.com>
Because it is possible for the MTD number to change, causing a
filesystem mount failure, we should use the volume name instead
of the MTD number and let Linux resolve the correct one.
Signed-off-by: Mike Scherban <m-scherban@ti.com>
The Multicore Software Development Kit (MCSDK) provides foundational
software for TI KeyStone II device platforms. It's supposed to be used
with uboot, and it's convenient to have the same names for images, so
correct environment image names according to the last MCSDK3.
Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
Reviewed-by: Tom Rini <trini@ti.com>
Currently to customize env for various ks2 boards, individual
variables such as NAME_FS etc are defined and included in the
common config.h to define CONFIG_EXTRA_ENV_SETTINGS. This
doesn't scale well if a variable is not applicable on a
specific board. Using this scheme, we have to define variables
with empty value and it's ugly. Instead, to allow board specific
customization of default env variable, define a common
CONFIG_EXTRA_ENV_KS2_SETTINGS for all common variables and define
board specific variables in individual board specific config.h
using CONFIG_EXTRA_ENV_KS2_BOARD_SETTINGS. Use the common and board
specific variables to define CONFIG_EXTRA_ENV_SETTINGS. This way
more variables can be added in future for individual boards
without affecting the other config.h files.
This patch adds network support code and enables keystone_net
driver usage for k2l_evm evaluation board.
Acked-by: Murali Karicheri <m-karicheri2@ti.com>
Signed-off-by: Hao Zhang <hzhang@ti.com>
This patch adds Keystone II Lammar (K2L) EVM board support.
