path: root/include/configs/k2hk_evm.h
2014-10-23soc: keystone_serdes: create a separate SGMII SerDes driverKhoronzhuk, Ivan
This patch split the Keystone II SGMII SerDes related code from Ethernet driver and create a separate SGMII SerDes driver. The SerDes driver can be used by others keystone subsystems like PCI, sRIO, so move it to driver/soc/keystone directory. Add soc specific drivers directory like in the Linux kernel. It is going to be used by keysotone soc specific drivers. Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-10-23net: keystone_net: move header file from arch to ti-commonKhoronzhuk, Ivan
The header file for the driver should be in correct place. So move it to "arch/arm/include/asm/ti-common/keystone_net.h" and correct driver's external dependencies. At the same time align and correct some definitions. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-10-23net: keystone_net: add support for NETCP v1.5Khoronzhuk, Ivan
Currently the network driver is used only by k2hk evm board. The k2hk SoC contains NETCP v1.0, but Keystone2 SoCs, like k2e contain NETCP v1.5. So driver should be able to work with such kind of NETCP. This commit adds this opportunity. The main difference in masks and some registers, the logic is the same, so only definitions should be changed. To differentiate between versions add KS2_NETCP_V1_0 and KS2_NETCP_V1_5. Also remove unused and no more needed defines. The port number is specific for each board so move this parameter to configuration. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-10-23dma: keystone_nav: generalize driver usageKhoronzhuk, Ivan
The keystone_nav driver is general driver intended to be used for working with queue manager and pktdma for different IPs like NETCP, AIF, FFTC, etc. So the it's API shouldn't be named like it works only with one of them, it should be general names. The names with prefix like netcp_* rather do for drivers/net/keystone_net.c driver. So it's good to generalize this driver to be used for different IP's and delete confusion with real NETCP driver. The current netcp_* functions of keystone navigator can be used for other settings of pktdma, not only for NETCP. The API of this driver is used by the keystone_net driver to work with NETCP, so net driver also should be corrected. For convenience collect pkdma configurations in drivers/dma/keystone_nav_cfg.c. Acked-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-10-23dma: keystone_nav: move keystone_nav driver to driver/dma/Khoronzhuk, Ivan
The keystone_nav is used by drivers/net/keystone_net.c driver to send and receive packets, but currently it's placed at keystone arch sources. So it should be in the drivers directory also. It's separate driver that can be used for sending and receiving pktdma packets by others drivers also. This patch just move this driver to appropriate directory and doesn't add any functional changes. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-07-25configs: k2hk_evm: config: add common EVM configuration headerHao Zhang
This patch adds a common config header file for all the Keystone II EVM platforms. It combines a lot of general definitions in one file. The common header included in the EVM should be specific configuration header. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-07-25ARM: keystone2: move K2HK board files to common KS2 board directoryHao Zhang
This patch moves K2HK board directory to a common Keystone II board directory. The Board related common functions are moved to a common keystone board file. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Hao Zhang <hzhang@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-07-25k2hk: use common KS2_ prefix for all hardware definitionsKhoronzhuk, Ivan
Use KS2_ prefix in all definitions, for that replace K2HK_ prefix and add KS2_ prefix where it's needed. It requires to change names also in places where they're used. Align lines and remove redundant definitions in kardware-k2hk.h at the same time. Using common KS2_ prefix helps resolve redundant redefinitions and adds opportunity to use KS2_ definition across a project not thinking about what SoC should be used. It's more convenient and we don't need to worry about the SoC type in common files, hardware.h will think about that. The hardware.h decides definitions of what SoC to use. Acked-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-07-25k2hk_evm: add script to automate NAND flash processKhoronzhuk, Ivan
Add script to automate NAND flash process. As for now the board has two burn scripts - burn to boot from SPI NOR flash and burn to boot from AEMIF NAND flash, rename burn_uboot script to burn_uboot_spi. Also update README to contain NAND burn U-boot process description. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> Acked-by: Murali Karicheri <m-karicheri2@ti.com>
2014-07-25mtd: nand: davinci: add opportunity to write keystone U-boot imageKhoronzhuk, Ivan
The Keystone SoCs use the same NAND driver as Davinci. This patch adds opportunity to write Keystone U-boot image to NAND device using appropriate RBL ECC layout. This is needed only if RBL boots U-boot from NAND device and that's supposed that raw u-boot partition is used only for writing image. The main problem is that default Davinci ECC layout is different from Keystone RBL layout. To read U-boot image the RBL needs that image was written using RBL ECC layout. The BBT table is written using default Davinci layout and has to be updated using one. The BBT can be updated only while erasing chip or by forced bad block assigning, so erase function has to use native ecc layout in order to be able to write BBT correctly. So if we're writing to NAND U-boot address we use RBL layout for others we use default ECC layout. Also remove definition for CONFIG_CMD_NAND_ECCLAYOUT as there is no reasons to use ECC layout commands. It was added by mistake. Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-06-19ARM: keystone: aemif: move aemif driver to drivers/memory/ti-aemif.cKhoronzhuk, Ivan
Move AEMIF driver to drivers/memory/ti-aemif.c along with AEMIF definitions collected in arch/arm/include/asm/ti-common/ti-aemif.h Acked-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-06-19mtd: nand: davinci: add header file for driver definitionsKhoronzhuk, Ivan
The definitions inside emif_defs.h concern davinci nand driver and should be in it's header. So create header file for davinci nand driver and move definitions from emif_defs.h and nand_defs.h to it. Acked-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com> [trini: Fixup more davinci breakage] Signed-off-by: Tom Rini <trini@ti.com>
2014-06-06keystone: k2hk: enable support of nand ecclayout commandWingMan Kwok
Enable support of nand ecclayout command. Acked-By: Murali Karicheri <m-karicheri2@ti.com> Acked-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: WingMan Kwok <w-kwok2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-06-06keystone: init: enable UART1 to be able use it from kernelMurali Karicheri
Currently PWREMU_MGMT is not configured in the Linux generic UART driver as this register seems to be specific TI UART IP. So this needs to be enabled in u-boot to use UART1 from kernel space. Acked-By: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-05-13config: k2hk_evm: Add generic board supportKhoronzhuk, Ivan
We should use generic board in order the ARM maintainer be able to remove arch/arm/lib/board.c Signed-off-by: Ivan Khoronzhuk <ivan.khoronzhuk@ti.com>
2014-04-17keystone2: net: add keystone ethernet driverKaricheri, Muralidharan
Ethernet driver configures the CPSW, SGMI and Phy and uses the the Navigator APIs. The driver supports 4 Ethernet ports and can work with only one port at a time. Port configurations are defined in board.c. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: WingMan Kwok <w-kwok2@ti.com>
2014-04-17k2hk-evm: add configuration for spi1 and spi2 supportKaricheri, Muralidharan
currently only spi0 is enabled on k2hk evm. This configuration update is needed to enable spi1 and spi2. Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Acked-by: Tom Rini <trini@ti.com>
2014-04-17k2hk: add support for k2hk SOC and EVMVitaly Andrianov
k2hk EVM is based on Texas Instruments Keystone2 Hawking/Kepler SoC. Keystone2 SoC has ARM v7 Cortex-A15 MPCore processor. Please refer the ti/k2hk_evm/README for details on the board, build and other information. This patch add support for keystone architecture and k2hk evm. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: WingMan Kwok <w-kwok2@ti.com> Signed-off-by: Sandeep Nair <sandeep_n@ti.com>
