path: root/include/configs/k2g_evm.h
2017-04-08ARM: ti: consolidate mmc environment variablesSekhar Nori
Introduce include/environment/ti/mmc.h that consolidates environment variable definitions for various TI boards that support MMC/SD. This allows reuse of same environment variables on non-ARMv7 TI platforms like OMAP-L138 for example. While at it, move DFU-related environment variable includes to only non-SPL builds for AM335x and AM437x since they are not really used for SPL today. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-04-08ARM: keystone: Pass SPI MTD partition table via kernel command lineVignesh R
SPI U-Boot image for K2 boards have now exceeded 512K partition allocated to it and no longer fit the partitions defined in kernel DTS file. Therefore, pass an updated MTD partition table from U-Boot as kernel command line arguments to avoid kernel from accidentally modifying boot loader image that has overflowed to next user partition. To do is, introduce a common environment file for declaring SPI partition so that each individual boards need not repeat the same. Choose appropriate SPI bus from board config file and pass it as command line argument to kernel. Signed-off-by: Vignesh R <vigneshr@ti.com>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-11mmc: move more driver config options to KconfigMasahiro Yamada
Move (and rename) the following CONFIG options to Kconfig: CONFIG_DAVINCI_MMC (renamed to CONFIG_MMC_DAVINCI) CONFIG_OMAP_HSMMC (renamed to CONFIG_MMC_OMAP_HS) CONFIG_MXC_MMC (renamed to CONFIG_MMC_MXC) CONFIG_MXS_MMC (renamed to CONFIG_MMC_MXS) CONFIG_TEGRA_MMC (renamed to CONFIG_MMC_SDHCI_TEGRA) CONFIG_SUNXI_MMC (renamed to CONFIG_MMC_SUNXI) They are the same option names as used in Linux. This commit was created as follows: [1] Rename the options with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_DAVINCI_MMC/CONFIG_MMC_DAVINCI/g s/CONFIG_OMAP_HSMMC/CONFIG_MMC_OMAP_HS/g s/CONFIG_MXC_MMC/CONFIG_MMC_MXC/g s/CONFIG_MXS_MMC/CONFIG_MMC_MXS/g s/CONFIG_TEGRA_MMC/CONFIG_MMC_SDHCI_TEGRA/g s/CONFIG_SUNXI_MMC/CONFIG_MMC_SUNXI/g ' [2] Commit the changes [3] Create entries in driver/mmc/Kconfig. (copied from Linux) [4] Move the options with the following command tools/moveconfig.py -y -r HEAD \ MMC_DAVINCI MMC_OMAP_HS MMC_MXC MMC_MXS MMC_SDHCI_TEGRA MMC_SUNXI [5] Sort and align drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-01-04spi: cadence_qspi_apb: Use 32 bit indirect write transaction when possibleVignesh R
According to Section 11.15.4.9.2 Indirect Write Controller of K2G SoC TRM SPRUHY8D[1], the external master is only permitted to issue 32-bit data interface writes until the last word of an indirect transfer otherwise indirect writes is known to fails sometimes. So, make sure that QSPI indirect writes are 32 bit sized except for the last write. If the txbuf is unaligned then use bounce buffer to avoid data aborts. So, now that the driver uses bounce_buffer, enable CONFIG_BOUNCE_BUFFER for all boards that use Cadence QSPI driver. [1]www.ti.com/lit/ug/spruhy8d/spruhy8d.pdf Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Jagan Teki <jagan@openedev.com>
2016-11-28keystone2: Move target selection to KconfigAndrew F. Davis
The config option TARGET_K2x_EVM is set by the k2x defconfigs to pick a board target, but the header configs also set K2x_EVM. This config is redundant, remove it and use TARGET_K2x_EVM everywhere in its place. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-10-01ti_armv7_keystone2: Update addr_mon variableLokesh Vutla
As boot monitor contains a mkimage header, it can be loaded at any location. So, have a common addr_mon address across all keystone2 SoCs. And also making sure that boot monitor is installed early during default boot to avoid any overlapping with other images. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-01keystone2: k2g: add env script to load firmware initramfs as part of boot flowMurali Karicheri
On K2G, the PCIe SerDes h/w is a re-use from other K2 devices and SerDes driver requires a firmware image to initialize the SerDes h/w device. This is firmware is part of the initramfs file that is loaded to memory in u-boot and passed to kernel as in other K2 platforms. This patch customize the u-boot env to have this done automatically when the K2G EVM boots up. With this, a user may be able to boot the EVM with a standard PCIe card at the x1 PCIe slot and release image and test PCIe devices such as NIC, SATA etc. Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-07-09defconfig: k2g_evm_defconfig: Enable Cadence QSPI controllerVignesh R
Enable Cadence QSPI controller support to use QSPI on K2G SoC. Also enable Spansion flash support to access s25fl512s flash present on K2G QSPI bus. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2016-06-06configs: k2*_evm: Update fdt file namesLokesh Vutla
Now that all Keystone2 dts file names are changed in Linux kernel, reflect the same in evn variables inorder to find the right dtb file. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com>
2016-03-22ti: k2g: increase phy autoneg timeoutVitaly Andrianov
After power cycle of a K2G EVM dhcp fails due to a auto-negotiation timeout. This commit increases the timeout to fix the issue. Signed-off-by: Vitaly Andrianov <vitalya@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-15keystone2: env: Set mmc as default boot for k2g-evmYan Liu
For k2l, k2e and k2hk, ubi is set to default boot in uboot environment settings; while for k2g, mmc should be the default boot. This patch is to set mmc as default for k2g-evm Signed-off-by: Yan Liu <yan-liu@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-15keystone2: env: add env script for booting with an initramfs with firmwareMurali Karicheri
This patch updates the env script to include a initramfs with firmware loaded and provided to kernel through second argument of bootz command during boot. Defined DEFAULT_FW_INITRAMFS_BOOT_ENV to have all of the required env variables and use it in evm specific config file. The K2 linux drivers for PCIe and NetCP (1G, 10G) requires serdes firmwares. These requires firmware to be available early through the boot process in some cases to satisfy firmware requests from driver. Hence use a small initramfs to provide the same and update boot env to accommodate this in the boot flow. This method is used when rootfs is nfs and ubifs. This fs contains just lib/firmware folder with all required firmware. When rootfs is on initramfs, then the filesystem has the firmware under lib/firmware and this early initramfs is not required and is not used. Signed-off-by: Murali Karicheri <m-karicheri2@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-15k2g: configs: Add support to save env in MMCLokesh Vutla
Adding support to save env in MMC on k2g platforms, as it is the preferred peripheral in saving env. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-15k2g: env: Allow use of a script and plain text env filesLokesh Vutla
For development purposes, it is easier to use the env import command and plain text or script files instead of script-images. So allow u-boot to load env var from a text file or a script file. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-03-14configs: k2g_evm: Add TI power processor supportNishanth Menon
Enable support for PMMC the TI power processor on K2G. This processor manages all power management related activities on the SoC and and allows the Operating Systems on compute processors such as ARM, DSP to offload the power logic away into the power processor. Signed-off-by: Nishanth Menon <nm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2015-10-22ARM: k2g: Add config fileLokesh Vutla
Add config file for k2g Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Signed-off-by: Vitaly Andrianov <vitalya@ti.com>
