path: root/include/configs/jupiter.h
2007-09-06Migrate 5xxx boards from CONFIG_OF_FLAT_TREE to CONFIG_OF_LIBFDTGrant Likely
Affects boards: icecube (lite5200), jupiter, motionpro, tqm5200 Tested on: lite5200b Note: the fixup functions have not been moved to a common place. This patch is targeted for immediate merging as in solves a build issue, but the final name/location of the fixups is still subject to debate. I propose to merge this now, and move the fixups in the next merge window to be usable by all targets. Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2007-08-29fdt: remove unused OF_FLAT_TREE_MAX_SIZE referencesKim Phillips
and make some minor corrections to the FDT part of the README. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2007-07-10include/configs/[g-o]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various j* and k* named board ↵Jon Loeliger
config files. Signed-off-by: Jon Loeliger <jdl@freescale.com>
2007-03-13Make SC3 board build with 'make O='; use 'addcons' consistentlyWolfgang Denk
(SC3 and Jupiter used to use 'addcon' instead). Signed-off-by: Wolfgang Denk wd@denx.de
2007-03-13Merge with /home/hs/jupiter/u-bootWolfgang Denk
2007-03-13[PATCH] update board config for jupiter Board:Heiko Schocher
added Hush Shell, CONFIG_CMDLINE_EDITING, CFG_ENV_ADDR_REDUND activated Signed-off-by: Heiko Schocher <hs@denx.de>
2007-03-08Minor cleanupWolfgang Denk
2007-02-16[PATCH] Added support for the jupiter board.Heiko Schocher
