path: root/include/configs/jetson-tk1.h
2016-03-22net: Move CONFIG_RTL8169 to KconfigBin Meng
Introduce CONFIG_RTL8169 in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Acked-by: Stephen Warren <swaren@nvidia.com> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2016-02-18ARM: tegra: don't set CONFIG_USB_MAX_CONTROLLER_COUNTStephen Warren
This option is no longer used now that DM_USB is enabled. Fixes: 534f9d3feffd ("dm: tegra: usb: Move USB to driver model") Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-12-01dm: pci: Avoid a driver model build error with CONFIG_CMD_PCI_ENUMSimon Glass
This is not supported with driver model, so print a message instead of generating a build error. Rescanning PCI is not yet implemented. This function will be implemented later once some additional PCI driver model improvements are merged. It was confirmed on the mailing list that no one on the tegra side will miss this feature, so it is disabled for tegra. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2015-12-01dm: tegra: pci: Move CONFIG_PCI_TEGRA to KconfigSimon Glass
Move this option to Kconfig and fix up all users. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2015-11-12ARM: tegra: simplify GPU setupAlexandre Courbot
Enable the GPU node in the system-wide ft_system_setup() hook instead of the board-specific ft_board_hook(). This allows us to enable GPU per SoC generation instead of per-board as we did initially. Reported-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-06ARM: tegra: enable GPU DT node when appropriateAlexandre Courbot
T124/210 requires some specific configuration (VPR setup) to be performed by the bootloader before the GPU can be used. For this reason, the GPU node in the device tree is disabled by default. This patch enables the node if U-boot has performed VPR configuration. Boards enabled by this patch are T124's Jetson TK1 and Venice2 and T210's P2571. Signed-off-by: Alexandre Courbot <acourbot@nvidia.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-05Tegra: spi: Move TEGRA114_SPI switch to defconfigsTom Warren
All T114+ Tegra boards should be using the Kconfig TEGRA114_SPI switch. Remove it from include/config and put it into defconfig. Also removed unused TEGRA114_SPI_CTRLS from T114+ configs. All Tegra SoCs build OK with this change. Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-05configs: Remove CONFIG_SERIAL_MULTIStephen Warren
This config option isn't used anywhere at all. Remove all places that define/enable the option. Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-05-13jetson-tk1: Add PSCI configuration options and reserve secure codeIan Campbell
The secure world code is relocated to the MB just below the top of 4G, we reserve it in the FDT (by setting CONFIG_ARMV7_SECURE_RESERVE_SIZE) but it is not protected in h/w. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Thierry Reding <treding@nvidia.com> Tested-by: Thierry Reding <treding@nvidia.com> Tested-by: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-03-04ARM: tegra: move common config defines centrallyStephen Warren
All boards need CONFIG_BOARD_EARLY_INIT_F, and many actively need CONFIG_BOARD_LATE_INIT. Move both of these into tegra-common.h so that board config headers don't need to repeatedly define them. Later commits will add new code in board_late_init() which applies to all boards, so CONFIG_BOARD_LATE_INIT should be enabled for all Tegra boards. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-18ARM: tegra: Enable PCIe on Jetson TK1Thierry Reding
The Jetson TK1 has an ethernet NIC connected to the PCIe bus and routes the second root port to a miniPCIe slot. Enable the PCIe controller and the network driver to allow the device to boot over the network. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-12-11dm: i2c: tegra: Convert to driver modelSimon Glass
This converts all Tegra boards over to use driver model for I2C. The driver is adjusted to use driver model and the following obsolete CONFIGs are removed: - CONFIG_SYS_I2C_INIT_BOARD - CONFIG_I2C_MULTI_BUS - CONFIG_SYS_MAX_I2C_BUS - CONFIG_SYS_I2C_SPEED - CONFIG_SYS_I2C This has been tested on: - trimslice (no I2C) - beaver - Jetson-TK1 It has not been tested on Tegra 114 as I don't have that board. Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-09-25kconfig: move CONFIG_OF_* to KconfigMasahiro Yamada
This commit moves: CONFIG_OF_CONTROL CONFIG_OF_SEPARATE CONFIG_OF_EMBED CONFIG_OF_HOSTFILE Because these options are currently not supported for SPL, the "Device Tree Control" menu does not appear in the SPL configuration. Note: zynq-common.h should be adjusted so as not to change the default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2014-08-18ARM: tegra: enable DFU tooStephen Warren
Enable DFU protocol support (via the "dfu" command) on Tegra boards where USB device/gadget mode is enabled. Note that for DFU to operate correctly on Tegra, we still need some DFU fixes/enhancements that are going through the DFU -> USB trees. However, the code builds just fine without those changes, and applying this patch now will allow both sets of patches to meet in the main U-Boot tree much more quickly. In order to run test/dfu/dfu_gadget_test.sh, you would need to add the following to the board configuration: CONFIG_EXT4_WRITE CONFIG_CMD_EXT4_WRITE However, I haven't enabled those here, since I believe the main use-case for DFU on Tegra is raw flash writing, rather than filesystem access, so we don't need the additional code-size hit. However, I could be persuaded otherwise! We should probably add a separate test script for raw flash access. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-06-05ARM: tegra: enable USB device mode and UMS on some boardsStephen Warren
For each of Jetson TK1, Venice2, and Beaver: - Enable the first USB controller in DT, and describe its configuration. - Enable USB device/gadget support. This allows the user to type e.g. "ums 0 mmc 0" at the command-line to cause U-Boot to act a USB device implementing the USB Mass Storage protocol, and expose MMC device 0 that way. This allows a host PC to mount the Tegra device's MMC, partition it, and install a filesystem on it. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-04-17ARM: tegra: add Jetson TK1 boardStephen Warren
Jetson TK1 is an NVIDIA Tegra124 reference board, which shares much of its design with Venice2. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
