path: root/include/configs/intip.h
2011-10-12ppc4xx: Change DDR2 CL from 4 to 5 for intipDirk Eibach
Some intip boards don't seem to run stable with CL4, datasheets suggest that CL5 is the safe value. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2011-10-12ppc4xx: Do not stop booting on any keypress on intipDirk Eibach
Use CONFIG_AUTOBOOT_KEYED on intip so that booting can only be stopped with well defined keypresses. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-23ppc4xx: Use common NS16550 driver for PPC4xx UARTStefan Roese
This patch removes the PPC4xx UART driver. Instead the common NS16550 driver is used, since all PPC4xx SoC's use this peripheral device. The file 4xx_uart.c now only implements the UART clock calculation function which also sets the SoC internal UART divisors. All PPC4xx board config headers are changed to use this common NS16550 driver now. Tested on these boards: acadia, canyonlands, katmai, kilauea, sequoia, zeus Signed-off-by: Stefan Roese <sr@denx.de>
2010-09-194xx: add missing CONFIG_SYS_SRAM_SIZE definitionWolfgang Denk
A number of boards define CONFIG_SYS_SRAM_BASE but fail to define CONFIG_SYS_SRAM_SIZE which is needed when cleaning up the code that prints this information with the bdinfo command. Add the missing deinitions. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2009-09-23ppc4xx: Make DDR2 timing for intip more robustDirk Eibach
DDR2 timing for intip was on the edge for some of the available chips for this board. Now it is verfied to work with all of them. Signed-off-by: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2009-09-11ppc4xx: Rename compactcenter to intipDirk Eibach
