Signed-off-by: Andreas Engel <andreas.engel@ericsson.com>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
Explicitly add in default CONFIG_BOOTP_* options where cmd_confdefs.h
used to be included but CONFIG_BOOTP_MASK was not defined.
Remove lingering references to CFG_CMD_* symbols.
CONFIG_BOOTP_MASK.
Correct addessing errors in platform files.
Split off common core module data from Integrator header files to
include/armcoremodule.h.
Patch by Peter Pearse, 04 Oct 2005
Patch by Peter Pearse, 2 Feb 2005
Add standalone application to change SMC91C111 MAC addresses,
see examples/README.smc91111_eeprom
* Patch by Xiaogeng (Shawn) Jin, 12 Oct 2004:
Fix Flash support for ARM Integrator CP.
Replaced hardcoded PL011 clock frequency with config variable.
Fixed wrong CONFIG_CMD_DFL doc.
* Patch by Thomas Viehweger, 09 Jun 2004:
make it possible to remove chpart when there is only one partition
Added ARM Integrator AP, CP and Versatile PB926EJ-S Reference
Platform support.
* Patch by Masami Komiya, 08 Mar 2004:
Don't overwrite server IP address or boot file name
when the boot server does not return values
* Patch by listmember@orkun.us, 5 Mar 2004:
Removed compile time restriction on CFG_I2C_SPEED for DS1338 RTC
