path: root/include/configs/integratorap.h
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-02-27integrator: rewrite the AP PCI driverLinus Walleij
The PCI support for the Integrator AP has apparently never been finished and I strongly suspect that it has never worked, so let's fix it. This is a list of the more or less un-splittable changes done in this driver rewrite: - Replace the register definitions stashed into the config file (!) with a copy if the register file from the Linux kernels arch/arm/include/asm/hardware/pci_v3.h - Delete the unreadable gigantic macros that perform the config accesses and replace them with copyedited code from Linux arch/arm/mach-integrator/pci_v3.c - Rewrite the rest of the setup code to use the v3_[read|write][lwb]() accessors. - Enable PCI by default in the AP board configuration. - Fix checkpatch warnings and make code more conformant. Tested-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-11-10integrator: move text offset to configLinus Walleij
Do away with the config.mk file and move the text offset to the config files to make things easier. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-03integrator: convert to new build systemLinus Walleij
This deletes the integrator split_by_variant.sh script and defines a number of unique board types for the core modules that are meaningful to support for the Integrator AP/CP, i.e. the ones that did not just say "unsupported core module" in split_by_variant.sh. If more core modules need to be supported they are easy to add. We delete all the old cruft in Makefile and MAKEALL that was working around the old way of building boards. We create a unique config file per board to satisfy the build system, but they are just oneliners that include the existing integratorap.h and integratorcp.h configs. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-03integratorap: remove hardcoded 32MB memory cmdlineLinus Walleij
The default configuration for the Integrator AP forces memory to be 32 MB on the command line to the kernel, while we have perfect information and detection of the actual memory size in the ATAGs. Delete the confusion. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-03integratorap: support some rudimentary commandsLinus Walleij
This adds support for a subset of the default commands for the Integrator, however since the card does not have Ethernet (unless you plug in a PCI card) we can not use the default command set. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-03integratorap: support the hush shellLinus Walleij
Give us some kind of sane shell environment so the bootloader can be used. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-03integratorap: support relocationLinus Walleij
The integrator board was apparently never converted over to support relocation until now. After this the integrator u-boot both compiles and boots on the Integrator AP. This also fixes the SDRAM memory size detection. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2011-09-03integratorap: make the compile work againLinus Walleij
The integratorap/cp config for u-boot was outdated and would not even compile, so fix the obvious missing bits for it to start building. After this "make ap920t_config/make all" starts working again. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2009-06-23integratorap/cp: use cfi driverJean-Christophe PLAGNIOL-VILLARD
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Acked-by: Peter Pearse <peter.pearse@arm.com>
2009-06-12arm: cleanup remaining CONFIG_INIT_CRITICALJean-Christophe PLAGNIOL-VILLARD
2009-04-05integratorap: fix PCI supportJean-Christophe PLAGNIOL-VILLARD
2009-03-29Remove nowhere used symbol CONFIG_SYS_CLKS_IN_HZLadislav Michl
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2008-09-10rename CFG_ENV_IS_NOWHERE in CONFIG_ENV_IS_NOWHEREJean-Christophe PLAGNIOL-VILLARD
2008-09-09Moved conditional compile into MakefileAndreas Engel
Signed-off-by: Andreas Engel <andreas.engel@ericsson.com>
2007-07-10include/configs/[p-z]* + misc: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-09include/configs/[a-m]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various i* named board config files.Jon Loeliger
2005-10-04Update ARM Integrator boards:Wolfgang Denk
Correct addessing errors in platform files. Split off common core module data from Integrator header files to include/armcoremodule.h. Patch by Peter Pearse, 04 Oct 2005
2005-09-25CleanupWolfgang Denk
2005-09-25Update multicore CM9XX support for Integrator AP to allow booting from flashWolfgang Denk
Patch by Jean-Paul Saman, 8 Feb 2005
2005-09-25Add ARM946E cpu and core module targets; remap memory to 0x00000000Wolfgang Denk
Patch by Peter Pearse, 2 Feb 2005
2004-08-02* Patch by Andreas Engel, 12 Jul 2004:wdenk
Replaced hardcoded PL011 clock frequency with config variable. Fixed wrong CONFIG_CMD_DFL doc. * Patch by Thomas Viehweger, 09 Jun 2004: make it possible to remove chpart when there is only one partition
2004-03-14Code cleanup; make several boards compile & link.LABEL_2004_03_14_2340wdenk
2004-03-14* Patch by Philippe Robin, 09 Mar 2004:wdenk
Added ARM Integrator AP, CP and Versatile PB926EJ-S Reference Platform support. * Patch by Masami Komiya, 08 Mar 2004: Don't overwrite server IP address or boot file name when the boot server does not return values * Patch by listmember@orkun.us, 5 Mar 2004: Removed compile time restriction on CFG_I2C_SPEED for DS1338 RTC
