path: root/include/configs/integrator-common.h
2013-04-12integrator: enable device treeLinus Walleij
This enables the device tree library on the Integrator platforms so we can pass a device tree when booting. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2012-09-04integrator: break out common configLinus Walleij
The configuration that is common for all Integrator boards may just as well be stored in a common include file as per pattern from other boards. This eases maintenance quite a bit. Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
