path: root/include/configs/inka4x0.h
2009-05-15powerpc/inka4x0: Remove left-over ide reset code.Detlev Zundel
The pin which was used in preliminary versions of the board for ide reset is really connected to the rtc clock. Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-03-30inka4x0: Add hardware diagnosis and RTC in configuration.Detlev Zundel
This patch adds the board specific communication routines needed by the external 4543 RTC. Signed-off-by: Detlev Zundel <dzu@denx.de> Signed-off-by: Andreas Pfefferle <ap@denx.de>
2009-03-30inka4x0: Add hardware diagnosis functions for inka4x0Detlev Zundel
This patch adds advanced diagnosis functions for the inka4x0 board. Signed-off-by: Andreas Pfefferle <ap@denx.de> Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-02-09net: removed board-specific CONFIGs from MPC5xxx FEC driverBen Warren
Added new CONFIG options for the three type of MAC-PHY interconnect and applied them all relevant board config files Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-06-03PPC: Create and use CONFIG_HIGH_BATSBecky Bruce
Change all code that conditionally operates on high bat registers (that is, BATs 4-7) to look at CONFIG_HIGH_BATS instead of the myriad ways this is done now. Define the option for every config for which high bats are supported (and enabled by early boot, on parts where they're not always enabled) Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-04-13Update CONFIG_PCIAUTO_SKIP_HOST_BRIDGE to related boardsTsiChung Liew
Remove test for CONFIG_MPC5200 in drivers/pci/pci_auto.c and define CONFIG_PCIAUTO_SKIP_HOST_BRIDGE in related board configuration files. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2007-11-15[INKA4x0] NG hardware: flash supportMarian Balakowicz
Disabled and remove inka4x0 custom flash driver, use CFI flash driver instead. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-11-15[INKA4x0] NG hardware: SDRAM supportMarian Balakowicz
Add support for three new DDR chips that may be present on a NG INKA4x0 hardware: HYB25D512160BF-5, K4H511638C-7CB3, T46V32M16BN-6IT. Cleanup board/inka4x0/mt48lc16m16a2-75.h file. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-11-15[INKA4x0] NG hardware: platform code updateMarian Balakowicz
- Cleanup compile warnings. - Add missing '\0' in default environment. - Increase CFG_MONITOR_LEN to 256 KiB. - Add required CFG_USE_PPCENV. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-07-10include/configs/[g-o]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various i* named board config files.Jon Loeliger
2007-05-27MPC5xxx: Change names of defines related to IPB and PCI clocks.Bartlomiej Sieka
Both CFG_PCISPEED_66 and CFG_IPBSPEED_133 are misnamed, as defining them does not cause PCI or IPB clocks to run at the specified speed. Instead, they configure divisors used to calculate said clocks. This patch renames the defines according to their real function. Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Acked-by: Bartlomiej Sieka <tur@semihalf.com>
2006-02-07Update default environment for INKA4x00 board.Wolfgang Denk
2005-09-21Update configuration for INKA4x0 boardWolfgang Denk
2005-04-22Fix INKA4x0: use CS1 as gpio_wkup_6 outputwdenk
2005-04-02Fix problems with SNTP support;wdenk
enable SNTP support in some boards.
2005-03-14INKA4x0: Allow initialization of LCD backlight dimming fromwdenk
"brightness" environment variable.
2005-03-06Add port initialization for digital I/O on INKA4x0LABEL_2005_03_06_0225wdenk
2005-03-04* Fix get_partition_info() parameter error in all other callswdenk
(common/cmd_ide.c, common/cmd_reiser.c, common/cmd_scsi.c). * Enable USB and IDE support for INKA4x0 board * Patch by Andrew Dyer, 28 February 2005: fix ext2load passing an incorrect pointer to get_partition_info() resulting in load failure for devices other than 0
2005-02-27Add support for SRAM and 2 x Quad UARTs on INKA4x0 boardLABEL_2005_02_28_0050wdenk
2005-02-24Cleanup USB and partition defineswdenk
2005-02-24* Add support for ext2 filesystems and image timestamps to TQM5200 boardwdenk
* Add reset code for Coral-P on INKA4x0 board * Patch by Martin Krause, 28 Jun 2004: Update for TRAB board. * Fix some missing "volatile"s in MPC5xxx FEC driver
2005-01-31* Update CPC45 board configuration.LABEL_2005_01_31_2245wdenk
* Add USB and PCI support for INKA4x0 board
2004-12-19* Fix problems with CMC_PU2 flash driver.LABEL_2004_12_19_2240wdenk
* Adjust INKA 4x0 default settings
2004-12-19Cleanup: avoid trigraph warning in fs/ext2/ext2fs.c; rename UC100 -> uc100wdenk
2004-12-16Add support for INKA4X0 boardwdenk
