path: root/include/configs/imx8mq_evk.h
2019-05-18CONFIG_SYS_[DI]CACHE_OFF: convert to KconfigTrevor Woerner
CONFIG_SYS_[DI]CACHE_OFF had been partially converted to Kconfig parameters; only for the ARC architecture. This patch turns these two parameters into Kconfig items everywhere else they are found. All of the include/configs/* and defconfig changes in this patch are for arm machines only. The Kconfig changes for arc, nds32, riscv, and xtensa have been included since these symbols are found in code under arch/{arc,nds32,riscv,xtensa}, however, no currently-defined include/configs/* or defconfigs for these architectures exist which include these symbols. These results have been confirmed with tools/moveconfig.py. Acked-by: Alexey Brodkin <abrodkin@snopsys.com> Signed-off-by: Trevor Woerner <trevor@toganlabs.com> [trini: Re-migrate for a few more boards] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-04Convert CONFIG_SUPPORT_EMMC_BOOT to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_SUPPORT_EMMC_BOOT As requested by Michal Simek <michal.simek@xilinx.com>, these boards have no eMMC so CONFIG_SUPPORT_EMMC_BOOT has not been migrated: xilinx_zynqmp_zc1275_revB xilinx_zynqmp_zc1751_xm018_dc4 xilinx_zynqmp_zc1751_xm019_dc5 xilinx_zynqmp_zcu100_revC xilinx_zynqmp_zcu102_rev1_0 xilinx_zynqmp_zcu102_revA xilinx_zynqmp_zcu102_revB xilinx_zynqmp_zcu104_revA xilinx_zynqmp_zcu104_revC xilinx_zynqmp_zcu106_revA xilinx_zynqmp_zcu111_revA Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Acked-by: Lukasz Majewski <lukma@denx.de> Acked-by: Patrick Delaunay <patrick.delaunay@st.com> Acked-by: Ramon Fried <ramon.fried@gmail.com> Reviewed-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
2019-04-13configs: move CONFIG_MXC_OCOTP to KconfigMarcel Ziswiler
While commit 3e020f03e94f ("driver: misc: add MXC_OCOTP Kconfig entry") introduced a Kconfig entry it did not actually migrate all configurations to using it. As CONFIG_MXC_OCOTP was in mx{6/7}_common.h enable it by default on those architectures. Additionally, also enable it on ARCH_IMX8M and ARCH_VF610 where all current members enabled it through their legacy configuration header files. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2019-03-13imx8mq_evk: Move CONFIG_ENV_IS_IN_MMC to KconfigFabio Estevam
Currently the command "saveenv" is not available. The CONFIG_ENV_IS_IN_MMC symbol has been converted to Kconfig, so fix the problem by moving it to the defconfig. Signed-off-by: Fabio Estevam <festevam@gmail.com> Reviewed-by: Peng Fan <peng.fan@nxp.com>
2019-01-14imx8mq_evk_defconfig: Move file system options to KconfigFabio Estevam
Chris Spencer reports that when enabling ext4 read support without also enabling write support the following error is seen: fs/fs.c:198:12: error: 'ext4_write_file' undeclared here (not in a function); did you mean 'ext4_read_file'? .write = ext4_write_file, ^~~~~~~~~~~~~~~ Fix this problem by moving these options to Kconfig. Reported-by: Chris Spencer <spencercw@gmail.com> Acked-by: Peng Fan <peng.fan@nxp.com> Signed-off-by: Fabio Estevam <festevam@gmail.com>
2019-01-01imx: add i.MX8MQ EVK supportPeng Fan
Add i.MX8MQ EVK support. SPL will initialize ddr and load ddr phy firmware. Then loading FIT image, ATF to OCRAM, U-Boot and DTB to DRAM. The boot log with Arm trusted firmware console enabled: " U-Boot SPL 2018.11-00142-g9ae14e7274 (Nov 20 2018 - 18:13:16 +0800) PMIC: PFUZE100 ID=0x10 Normal Boot Trying to boot from MMC2 NOTICE: Configureing TZASC380 NOTICE: BL31: v1.5(release):p9.0.0_1.0.0-beta-20180928-8-ge09c4b62-dirty NOTICE: BL31: Built : 09:28:54, Nov 8 2018 lpddr4 swffc start NOTICE: sip svc init U-Boot 2018.11-00142-g9ae14e7274 (Nov 20 2018 - 18:13:16 +0800) CPU: Freescale i.MX8MQ rev2.0 at 1000 MHz Reset cause: POR Model: Freescale i.MX8MQ EVK DRAM: 3 GiB MMC: FSL_SDHC: 0, FSL_SDHC: 1 In: serial Out: serial Err: serial Net: Warning: ethernet@30be0000 using MAC address from ROM eth0: ethernet@30be0000 Hit any key to stop autoboot: 0 " Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Stefano Babic <sbabic@denx.de>
