The new uuu will change to burn entire boot image to nandfit mtdpart not
only the FIT image. We enable REDUND offset configuration here, so that SPL will
try to find FIT header at two locations: the begin of nandfit mtdpart and
the 0x57c00 offset of nandfit mtdpart. This helps to be compatible with both
old and new uuu.
Signed-off-by: Ye Li <ye.li@nxp.com>
Because the iMX8MQ DDR4 ARM2 has 4GB DDR. To fit new MMU settings, we split
it to two banks. The first bank has 3GB DDR, reach to 4GB memory map.
The second bank has 1GB DDR, is beyond 4GB memory map.
Notice: there is no OPTEE for ARM2 board. The trust zone setting in OPTEE
for iMX8MQ EVK is not match with DDR size on ARM2 board. So ARM2 Only can
work without OPTEE.
Reviewed-by: Peng Fan <peng.fan@nxp.com>
The "imx_env.h" is not included, so when using default mfgtool environments,
we get build break.
When running uuu to burning NAND on imx8mq DDR4 ARM2, meet two u-boot environments problems.
1. fastboot won't be run in regular u-boot, due the bootcmd_mfg is not correct.
2. mtdparts in bootargs are not updated to align with uuu.
20M read size is not large enough for current kernel
Signed-off-by: Han Xu <han.xu@nxp.com>
add fastboot support for nand u-boot.
1. Add fastboot related configs
2. enlarge the SPL size for i.MX8MQ DDR4 NAND config
3. include the imx_env for boot command settings
When running on ARM64 platforms like imx8 and imx8m, the initrd_high should set to
0xffffffffffffffff not 0xffffffff. Otherwise the initramfs will be relocated to high
memory by u-boot before booting up kernel.
This may not cause issue, but to align with previous imx series and save boot time,
we'd better disable relocation for initramfs.
(cherry picked from commit 33d88b0f2e31d965fd455bff9da7391d6a7b3594)
Enable the mtest command and add relevant configurations for tested memory
range to all ARM2 boards and EVK board.
(cherry picked from commit bb3dfa130dd0af57dfe7a41869f6ecd843e6c558)
When using SPL NAND boot, the required malloc memory is larger than SD/eMMC boot.
Since we have used out OCRAM (for ATF) and OCRAM_S, there is no enough memory could be
allocated.
The solution is moving the malloc memory pool to DDR. The malloc pool is initialized in
board_init_r, so we moved the VDD_DRAM adjustment and DDR init to board_init_f. Then the DDR
can setup before memory pool initialization. Because the i2c and PMIC driver needs to malloc
data, this change has to enable malloc_f pool by setting CONFIG_MALLOC_F_ADDR to previous
malloc address on OCRAM_S.
(cherry picked from commit ab1895fb5e38d216ff86de292a44776099d159ab)
Add board codes, configurations, DTS and DDR initialization codes for the
DDR3L and DDR4 ARM2 boards.
Supported modules
- DDR3L ARM2: Two RANK DDR3L, QSPI B, eMMC/SD, RMII ENET, UART.
- DDR4 ARM2: Two RANK DDR4, SD, NAND, RGMII ENET, UART.
NAND read/write/erase is ok in u-boot, NAND SPL boot will be tested later
when tool is ready.
Acked-by: Peng Fan <peng.fan@nxp.com>
