path: root/include/configs/imx6_spl.h
2015-08-02imx: imx6_spl add mx6ul supportPeng Fan
i.MX6UL's DRAM space starts from 0x80000000, same to i.MX6SX, so use same address with i.MX6SX. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-01-22imx:mx6 add mx6sx in imx spl header filePeng Fan
Since mx6sx's memory space is different to mx6dq, redefine the SPL related macro for mx6sx chip. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2014-12-08imx6: remove redudant CONFIG_SPL_START_S_PATH defineMasahiro Yamada
The CPU directory of IMX6 is arch/arm/cpu/armv7, so setting CONFIG_SPL_START_S_PATH to arch/arm/cpu/armv7 is totally redundant. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Stefano Babic <sbabic@denx.de>
2014-12-04MMC SD fs boot partition config coding style and proper descriptionPaul Kocialkowski
CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION ought to be called CONFIG_SYS_MMCSD_FS_BOOT_PARTITION to keep it consistent with other config options such as: CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR. In addition, it is not related to raw mode booting but to fs mode instead. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-05Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2014-10-30ARM: mx6: Add support for Kosagi NovenaMarek Vasut
Add support for the Kosagi Novena board. Currently supported are: - I2C busses - FEC Ethernet - MMC0, MMC1, Booting from MMC - SATA - USB ports - USB Ethernet Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Sean Cross <xobs@kosagi.com> Cc: Nikolay Dimitrov <picmaster@mail.bg> Reviewed-by: Nikolay Dimitrov <picmaster@mail.bg>
2014-10-27Rename some defines containing FAT in their name to be filesystem genericGuillaume GARDET
Rename some defines containing FAT in their name to be filesystem generic: MMCSD_MODE_FAT => MMCSD_MODE_FS CONFIG_SPL_FAT_LOAD_ARGS_NAME => CONFIG_SPL_FS_LOAD_ARGS_NAME CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME => CONFIG_SPL_FS_LOAD_PAYLOAD_NAME CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION => CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Tom Rini <trini@ti.com>
2014-08-20ARM: mx6: Enable Thumb build for SPLMarek Vasut
Building the SPL in Thumb mode saves roughly 30% in size of the resulting SPL binary. As the size of SPL it limited on the MX6, this helps a lot. Signed-off-by: Marek Vasut <marex@denx.de> Acked-by: Tim Harvey <tharvey@gateworks.com>
2014-06-06mx6: add common SPL configurationTim Harvey
Add a common header which can hopefully be shared amon imx6 SPL users Cc: Stefan Roese <sr@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Andy Ng <andreas2025@gmail.com> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Tapani Utriainen <tapani@technexion.com> Cc: Tom Rini <trini@ti.com> Signed-off-by: Tim Harvey <tharvey@gateworks.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Nikita Kiryanov <nikita@compulab.co.il>
