path: root/include/configs/imx6_spl.h
2019-02-01spl: Kconfig: Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPL_FS_EXT4Tien Fong Chee
Replace CONFIG_SPL_EXT_SUPPORT to CONFIG_SPLY_FS_EXT4 so both obj-$(CONFIG_$(SPL_)FS_EXT4) and CONFIG_IS_ENABLED(FS_EXT4) can be used to control the build in both SPL and U-Boot. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-02-01spl: Kconfig: Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FATTien Fong Chee
Replace CONFIG_SPL_FAT_SUPPORT with CONFIG_SPL_FS_FAT so obj-$(CONFIG_$(SPL_)FS_FAT) can be used to control the build in both SPL and U-Boot. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-01-04mx6ull: Handle the CONFIG_MX6ULL cases correctlyFabio Estevam
Since commit 051ba9e082f7 ("Kconfig: mx6ull: Deselect MX6UL from CONFIG_MX6ULL") CONFIG_MX6ULL does not select CONFIG_MX6UL anymore, so take this into consideration in all the checks for CONFIG_MX6UL. This fixes a boot regression. Reported-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Stefan Agner <stefan@agner.ch> Tested-by: Breno Lima <breno.lima@nxp.com> Tested-by: Peng Fan <peng.fan@nxp.com> Reviewed-by: Stefano Babic <sbabic@denx.de> Tested-by: Jörg Krause <joerg.krause@embedded.rocks>
2017-08-13spl: moveconfig: remove SPL_LDSCRIPT definitions for header-filesPhilipp Tomsich
With the hierarchical defaults set up, we remove these from the header files. To do so, I've run moveconfig on SPL_LDSCRIPT and this commits the changes. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-07-12imx6_spl: Add u-boot-dtb.img for SPL payloadJagan Teki
Add u-boot-dtb.img for SPL_FS_LOAD_PAYLOAD_NAME when OF_CONTROL used. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
2017-05-31arm: mx6: remove unused config variable CONFIG_SPL_NAND_MXSLothar Waßmann
The config variable CONFIG_SPL_NAND_MXS is only set in include/configs/imx6_spl.h but used nowhere. Remove it. Signed-off-by: Lothar Waßmann <LW@KARO-electronics.de> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2017-03-18arm: Migrate SYS_THUMB_BUILD to Kconfig, introduce SPL_SYS_THUMB_BUILDTom Rini
Today, we have cases where we wish to build all of U-Boot in Thumb2 mode for various reasons. We also have cases where we only build SPL in Thumb2 mode due to size constraints and wish to build the rest of the system in ARM mode. So in this migration we introduce a new symbol as well, SPL_SYS_THUMB_BUILD to control if we build everything or just SPL (or in theory, just U-Boot) in Thumb2 mode. Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Siarhei Siamashka <siarhei.siamashka@gmail.com>
2017-03-18spl: Convert CONFIG_SPL_ABORT_ON_RAW_IMAGE into a positive optionAndrew F. Davis
CONFIG_SPL_ABORT_ON_RAW_IMAGE causes SPL to abort and move on when it encounters RAW images, express this same functionality as a positive option enabling support for RAW images: CONFIG_SPL_RAW_IMAGE_SUPPORT Also move uses of this to defconfigs. Signed-off-by: Andrew F. Davis <afd@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Rework Kconfig logic a little, move to common/spl/Kconfig] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-29arm: mx6: specify SPL paddingStefan Agner
Specify standard padding for payload to 68KB. This is derived from the maximum header size plus maximum SPL size. It matches the already defined offset for SD/eMMC devices (69KB) too. This allows to use the u-boot-with-spl.imx build target to generate a directly flashable image which can be flashed using: dd if=u-boot-with-spl.imx of=/dev/mmcblk0 bs=512 skip=2 While the patch has been created with SD/eMMC in mind, this also works with other boot media. The board file needs to configure the media specific (absolute) payload offset accordingly. Especially the IVT offset is boot media specific and can be retrieved from the reference manual (Table 8-25. Image Vector Table Offset and Initial Load Region Size). For NAND boot a define like this should do the job: #define CONFIG_SYS_NAND_U_BOOT_OFFS (SPL_PAD_TO + 0x400) Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
2016-11-21arm: Introduce arch/arm/mach-omap2 for OMAP2 derivative platformsTom Rini
This moves what was in arch/arm/cpu/armv7/omap-common in to arch/arm/mach-omap2 and moves arch/arm/cpu/armv7/{am33xx,omap3,omap4,omap5} in to arch/arm/mach-omap2 as subdirectories. All refernces to the former locations are updated to the current locations. For the logic to decide what our outputs are, consolidate the tests into a single config.mk rather than including 4. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-18spl: Remove CONFIG_SYS_U_BOOT_MAX_SIZE_SECTORSSemen Protsenko
This option isn't used for anything, so get rid of it. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-11-18spl: Convert CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR to KconfigSemen Protsenko
Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Fix sniper and kc1 migration] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-16Convert CONFIG_SPL_WATCHDOG_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_EXT_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_DMA_SUPPORT to KconfigSimon Glass
2016-05-17ARM: mx6: Enable MMC and SATA extfs boot supportMarek Vasut
Enable support for booting U-Boot image from ext filesystem when either SD/MMC or SATA support is compiled into the SPL. This will allow easy transition from loading U-Boot image from ad-hoc offset on the card to loading U-Boot image from the filesystem. VFAT support is intently not enabled. The boot order is tweaked so that raw is tested first and if the raw has no signature, FS boot is attempted. To install just the SPL on i.MX6 board, perform the following operation $ dd if=SPL of=/dev/sdX seek=2 bs=512 To install the U-Boot image, copy u-boot.img to the first partition of the SD/MMC/SATA drive. The partition must be formated to extfs. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Fabio Estevam <fabio.estevam@nxp.com> Cc: Peng Fan <van.freenix@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Tom Rini <trini@konsulko.com>
2016-01-25imx: spl: enable CONFIG_SPL_WATCHDOG_SUPPORTPeng Fan
This commit 4bdcbe60a142b08eefccb0e326a37ba81d3389e8 removes reset_cpu which breaks SPL build when DEBUG macro defined. " arch/arm/lib/built-in.o: In function `do_reset': ~/uboot/arch/arm/lib/reset.c:45: undefined reference to `reset_cpu' scripts/Makefile.spl:244: recipe for target 'spl/u-boot-spl' failed " Enable CONFIG_SPL_WATCHDOG_SUPPORT to fix this issue. Signed-off-by: Peng Fan <peng.fan@nxp.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Marek Vasut <marex@denx.de> Cc: Tim Harvey <tharvey@gateworks.com> Acked-by: Eric Nelson <eric@nelint.com>
2015-11-23arm: mx6: Reduce SPL malloc pool sizeMarek Vasut
Using 50 MiB malloc pool in SPL is nonsense. Since the caches are not enabled in SPL, it takes 2 seconds to init the pool and has no obvious benefit. Reduce the size to 1 MiB. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Tim Harvey <tharvey@gateworks.com> Tested-by: Stefano Babic <sbabic@denx.de> Acked-by: Tim Harvey <tharvey@gateworks.com>
2015-09-02imx: mx6slevk: add SPL supportPeng Fan
Add SPL boot support for mx6slevk board. 1. Introduce a configuration file mx6slevk_spl_defconfig. 2. i.MX6SL has same DRAM space with i.MX6SX, need to change SPL DRAM SPACE. 3. Include imx6_spl.h and related SPL macro in mx6slevk.h. 4. select SUPPORT_SPL for TARGET_MX6SLEVK. 5. Add SPL board code to do related initialization. Boot Log: U-Boot SPL 2015.07-00544-g1594a76 (Aug 17 2015 - 01:56:59) reading u-boot.img reading u-boot.img U-Boot 2015.07-00544-g1594a76 (Aug 17 2015 - 01:56:59 +0000) CPU: Freescale i.MX6SL rev1.2 996 MHz (running at 396 MHz) CPU: Commercial temperature grade (0C to 95C) at 50C Reset cause: POR Board: MX6SLEVK I2C: ready DRAM: 1 GiB PMIC: PFUZE100 ID=0x10 MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2 *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: FEC [PRIME] Hit any key to stop autoboot: 0 Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Fabio Estevam <fabio.estevam@freescale.com>
2015-08-02imx: imx6_spl add mx6ul supportPeng Fan
i.MX6UL's DRAM space starts from 0x80000000, same to i.MX6SX, so use same address with i.MX6SX. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-01-22imx:mx6 add mx6sx in imx spl header filePeng Fan
Since mx6sx's memory space is different to mx6dq, redefine the SPL related macro for mx6sx chip. Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2014-12-08imx6: remove redudant CONFIG_SPL_START_S_PATH defineMasahiro Yamada
The CPU directory of IMX6 is arch/arm/cpu/armv7, so setting CONFIG_SPL_START_S_PATH to arch/arm/cpu/armv7 is totally redundant. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Stefano Babic <sbabic@denx.de>
2014-12-04MMC SD fs boot partition config coding style and proper descriptionPaul Kocialkowski
CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION ought to be called CONFIG_SYS_MMCSD_FS_BOOT_PARTITION to keep it consistent with other config options such as: CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR. In addition, it is not related to raw mode booting but to fs mode instead. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Reviewed-by: Tom Rini <trini@ti.com>
2014-11-05Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2014-10-30ARM: mx6: Add support for Kosagi NovenaMarek Vasut
Add support for the Kosagi Novena board. Currently supported are: - I2C busses - FEC Ethernet - MMC0, MMC1, Booting from MMC - SATA - USB ports - USB Ethernet Signed-off-by: Marek Vasut <marex@denx.de> Cc: Stefano Babic <sbabic@denx.de> Cc: Sean Cross <xobs@kosagi.com> Cc: Nikolay Dimitrov <picmaster@mail.bg> Reviewed-by: Nikolay Dimitrov <picmaster@mail.bg>
2014-10-27Rename some defines containing FAT in their name to be filesystem genericGuillaume GARDET
Rename some defines containing FAT in their name to be filesystem generic: MMCSD_MODE_FAT => MMCSD_MODE_FS CONFIG_SPL_FAT_LOAD_ARGS_NAME => CONFIG_SPL_FS_LOAD_ARGS_NAME CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME => CONFIG_SPL_FS_LOAD_PAYLOAD_NAME CONFIG_SYS_MMC_SD_FAT_BOOT_PARTITION => CONFIG_SYS_MMC_SD_FS_BOOT_PARTITION Signed-off-by: Guillaume GARDET <guillaume.gardet@free.fr> Cc: Tom Rini <trini@ti.com>
2014-08-20ARM: mx6: Enable Thumb build for SPLMarek Vasut
Building the SPL in Thumb mode saves roughly 30% in size of the resulting SPL binary. As the size of SPL it limited on the MX6, this helps a lot. Signed-off-by: Marek Vasut <marex@denx.de> Acked-by: Tim Harvey <tharvey@gateworks.com>
2014-06-06mx6: add common SPL configurationTim Harvey
Add a common header which can hopefully be shared amon imx6 SPL users Cc: Stefan Roese <sr@denx.de> Cc: Otavio Salvador <otavio@ossystems.com.br> Cc: Andy Ng <andreas2025@gmail.com> Cc: Eric Nelson <eric.nelson@boundarydevices.com> Cc: Tapani Utriainen <tapani@technexion.com> Cc: Tom Rini <trini@ti.com> Signed-off-by: Tim Harvey <tharvey@gateworks.com> Acked-by: Stefano Babic <sbabic@denx.de> Acked-by: Nikita Kiryanov <nikita@compulab.co.il>
