path: root/include/configs/imgtec_xilfpga.h
2018-09-22MIPS: cache: remove config option CONFIG_SYS_MIPS_CACHE_MODEDaniel Schwierzeck
Caches should be configured to mode CONF_CM_CACHABLE_NONCOHERENT (or CONF_CM_CACHABLE_COW when a CM is available). There is no need to make this configurable. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-09-21mips: Add MIPSfpga platform supportZubair Lutfullah Kakakhel
MIPSfpga is an FPGA based dev platform. In a nutshell, its a microAptiv cpu core with lots of Xilinx IP blocks The FPGA dev board used is the Nexys4DDR board by Digilent. For more information, check the Readme file in board/imgtec/xilfpga Signed-off-by: Zubair Lutfullah Kakakhel <Zubair.Kakakhel@imgtec.com> Reviewed-by: Paul Burton <paul.burton@imgtec.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
