Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: U-Boot DM <u-boot-dm@lists.denx.de>
Cc: Tom Rini <trini@ti.com>
Acked-by: Tom Rini <trini@ti.com>
This patch adds SPL support for IGEP-based boards.
Tested on an IGEPv2 Rev.C board with Micron NAND Flash memory.
Signed-off-by: Javier Martinez Canillas <javier@dowhile0.org>
IGEP-based boards can have two different flash memories, a OneNAND or a
NAND device. Add a configuration option for to choose which memory to use.
Acked-by: Enric Balletbo i Serra <eballetbo@gmail.com>
omap2plus_defconfig now has built-in compile support for EXT4 enabled
by default now. So, we can use EXT4 as the default root file system
type for MMC.
An OMAP specific serial driver was merged on the Linux kenel a long
time ago. So, it makes sense to default the console name to OMAP
ttyO instead of the generic ttyS naming.
Exactly one board has defined CONFIG_SYS_PROMPT_HUSH_PS2 to a value
different than "> " which is vision2. I have Cc'd the maintainer here
as I strongly suspect this is a bug rather than intentional behavior.
This patch changes the default mpurate variable from 500 to auto on
all IGEP boards, with this the default rate is autoselected.
Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com>
Based on commit cf073e49bc3502be1b48a0e3faf0cde9edbb89db for beagleboard
Using the new env import command it is possible to use plain text files instead
of script-images. Plain text files are much easier to handle.
E.g. If your boot.scr contains the following:
setenv dvimode 1024x768-16@60
run loaduimage
run mmcboot
you could create a file named uEnv.txt and use that instead of boot.scr:
dvimode=1024x768-16@60
uenvcmd=run loaduimage; run mmcboot
The variable uenvcmd (if existent) will be executed (using run) after uEnv.txt
was loaded. If uenvcmd doesn't exist the default boot sequence will be started,
therefore you could just use
as uEnv.txt because loaduimage and mmcboot is part of the default boot sequence
This is rework on config files of IGEP-based boards with the aim to remove
duplicated code to be more maintainable. Basically this patch creates a
common configuration file for both boards and only sets the specific option
in the board config file.
On board files the hardcored mach type was replaced in favour of using the
CONFIG_MACH_TYPE option.
More than 200 duplicated lines have been deleted.
Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com>
