path: root/include/configs/igep00x0.h
2012-11-26spl/nand: introduce CONFIG_SPL_NAND_DRIVERS, _BASE, and _ECC.Scott Wood
Some small SPLs do not use nand_base.c, and a subset of those also require a special driver. Some SPLs need software ECC but others can't fit it. All existing boards that specify CONFIG_SPL_NAND_SUPPORT have these symbols added to preserve existing behavior. Signed-off-by: Scott Wood <scottwood@freescale.com> -- v2: use positive logic for including bits of NAND, rather than a MINIMAL symbol that excludes things.
2012-10-23configs: Fix usage of mmc rescanAndrew Bradford
Fix usage of 'mmc rescan' by many configs. Proper use is 'mmc dev ${mmcdev}; mmc rescan' to set the mmc device and then rescan the device. 'mmc rescan' itself does not take any arguments. Signed-off-by: Andrew Bradford <andrew@bradfordembedded.com>
2012-09-27SPL: Move the omap SPL framework to common/splTom Rini
Add a new flag, CONFIG_SPL_FRAMEWORK to opt into the common/spl SPL framework, enable on all of the previously using boards. We move the spl_ymodem.c portion to common/ and spl_mmc.c to drivers/mmc/. We leave the NAND one in-place as we plan to replace it later in this series. We use common/spl to avoid linker problems with respect to merging constant strings in objects. Otherwise all strings in common/ will be linked in and kept which grows SPL in size too much. Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-09-01dm: Move OMAP GPIO driver to drivers/gpio/Marek Vasut
Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: U-Boot DM <u-boot-dm@lists.denx.de> Cc: Tom Rini <trini@ti.com> Acked-by: Tom Rini <trini@ti.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01OMAP3: igep00x0: add SPL support for IGEP-based boardsJavier Martinez Canillas
This patch adds SPL support for IGEP-based boards. Tested on an IGEPv2 Rev.C board with Micron NAND Flash memory. Signed-off-by: Javier Martinez Canillas <javier@dowhile0.org>
2012-09-01OMAP3: igep00x0: Add config option to choose flash storage memoryJavier Martinez Canillas
IGEP-based boards can have two different flash memories, a OneNAND or a NAND device. Add a configuration option for to choose which memory to use. Signed-off-by: Javier Martinez Canillas <javier@dowhile0.org> Acked-by: Enric Balletbo i Serra <eballetbo@gmail.com>
2012-09-01igep00x0: default mmcrootfstype to EXT4Javier Martinez Canillas
omap2plus_defconfig now has built-in compile support for EXT4 enabled by default now. So, we can use EXT4 as the default root file system type for MMC. Signed-off-by: Javier Martinez Canillas <javier@dowhile0.org> Acked-by: Enric Balletbo i Serra <eballetbo@gmail.com>
2012-09-01igep00x0: default to OMAP-specific serial driverJavier Martinez Canillas
An OMAP specific serial driver was merged on the Linux kenel a long time ago. So, it makes sense to default the console name to OMAP ttyO instead of the generic ttyS naming. Signed-off-by: Javier Martinez Canillas <javier@dowhile0.org> Acked-by: Enric Balletbo i Serra <eballetbo@gmail.com>
2012-05-15igep00x0: change mpurate from 500 to autoEnric Balletbo i Serra
This patch changes the default mpurate variable from 500 to auto on all IGEP boards, with this the default rate is autoselected. Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-05-15igep00x0: enable the use of a plain text fileEnric Balletbo i Serra
Based on commit cf073e49bc3502be1b48a0e3faf0cde9edbb89db for beagleboard Using the new env import command it is possible to use plain text files instead of script-images. Plain text files are much easier to handle. E.g. If your boot.scr contains the following: ----------------------------------- setenv dvimode 1024x768-16@60 run loaduimage run mmcboot ----------------------------------- you could create a file named uEnv.txt and use that instead of boot.scr: ----------------------------------- dvimode=1024x768-16@60 uenvcmd=run loaduimage; run mmcboot ----------------------------------- The variable uenvcmd (if existent) will be executed (using run) after uEnv.txt was loaded. If uenvcmd doesn't exist the default boot sequence will be started, therefore you could just use ----------------------------------- dvimode=1024x768-16@60 ----------------------------------- as uEnv.txt because loaduimage and mmcboot is part of the default boot sequence Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2012-05-15OMAP3: igep00x0: Reduce lines of code for IGEP-based boards.Enric Balletbò i Serra
This is rework on config files of IGEP-based boards with the aim to remove duplicated code to be more maintainable. Basically this patch creates a common configuration file for both boards and only sets the specific option in the board config file. On board files the hardcored mach type was replaced in favour of using the CONFIG_MACH_TYPE option. More than 200 duplicated lines have been deleted. Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com>
