path: root/include/configs/igep0030.h
2010-11-29ARMV7: OMAP3: Fix build failure for igep0030 machineEnric Balletbo i Serra
Seems that if CONFIG_CMD_NET is undefined we should also undefine CONFIG_CMD_NFS, otherwise build fails with various undefined reference like: net/libnet.o: In function `rpc_req': u-boot/net/nfs.c:193: undefined reference to `NetEthHdrSize' u-boot/net/nfs.c:202: undefined reference to `NetSendUDPPacket' u-boot/net/nfs.c:203: undefined reference to `NetTxPacket' u-boot/net/nfs.c:203: undefined reference to `NetServerEther' This patch adds the undef CONFIG_CMD_NFS in configuration file. Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04ARMV7: OMAP3: Use generic mmc driver on OMAP3 IGEP moduleEnric Balletbo i Serra
This patch switches from the legacy mmc driver to the new generic mmc driver Signed-off-by: Enric Balletbo i Serra <eballetbo@iseebcn.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-11-04ARMV7: OMAP: Fix build after introduction of GENERATED_GBL_DATA_SIZESteve Sakoman
This patch fixes the issue by defining and using CONFIG_SYS_INIT_RAM_SIZE and CONFIG_SYS_INIT_RAM_ADDR. Based on an email discussion with Wolfgang Denk and Heiko Schocher. Signed-off-by: Steve Sakoman <steve.sakoman@linaro.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2010-10-17OMAP3: Add support for the OMAP3 IGEP module.Enric Balletbo i Serra
The IGEP module is a low-power, high performance production-ready system-on-module (SOM) based on TI's OMAP3 family.The IGEP module solution based upon TI OMAP3 provides a low-power/low-cost platform for a variety of consumer/industrial/medical devices. Signed-off-by: Enric Balletbo i Serra <eballetbo@gmail.com> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
