path: root/include/configs/ids8313.h
2018-04-28Migrate IMAGE_FORMAT_LEGACY to KconfigAlex Kiernan
This converts IMAGE_FORMAT_LEGACY to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Convert CONFIG_HOSTNAME to a string optionMario Six
CONFIG_HOSTNAME is defined as a "plain" preprocessor string, but every use is couched by __stringify(...). Hence, convert it to a proper string option. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-04-08treewide: Migrate CONFIG_TSEC_ENET to KconfigMario Six
Migrate the CONFIG_TSEC_ENET option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-03-16Convert all of CONFIG_CONS_INDEX to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX We have existing entries for this option in a number of places, with different guards on them. They're also sometimes used for things not directly inside of the serial driver. First, introduce a new symbol to guard the use of CONFIG_CONS_INDEX, so that in the case where we don't need this for the serial driver, but for some other use, we can still do it. Next, consolidate all of these into the single entry in drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that we can imply a correct value here to make the defconfig side of this smaller. Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rework a lot of the logic here, such that I took authorship from Adam, but kept his S-o-B line] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-25bootcount: Migrate CONFIG_SYS_BOOTCOUNT_ADDRTom Rini
Migrate the users of CONFIG_SYS_BOOTCOUNT_ADDR to Kconfig. We can provide a default for BOOTCOUNT_AM33XX as that's a specific part of the RTC in use. We can also provide a default for ARCH_LS1043A and ARCH_LS1021A as they had been previously calculated and their symbols are in Kconfig. In the case of other QE-enabled platforms, they are not so we must update the relevant defconfig files. The previous default only applied in some cases, even on a specific SoC family. Reviewed-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Alex Kiernan <alex.kiernan@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-02-24Migrate CONFIG_BOOTCOUNT_ALEN to KconfigAlex Kiernan
Convert CONFIG_BOOTCOUNT_ALEN to Kconfig Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
2018-02-24Convert CONFIG_BOOTCOUNT_I2C to KconfigAlex Kiernan
This converts the following to Kconfig: CONFIG_BOOTCOUNT_I2C Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Lukasz Majewski <lukma@denx.de>
2018-02-15Convert CONFIG_BOOTCOUNT_LIMIT to KconfigLukasz Majewski
This converts the following to Kconfig: CONFIG_BOOTCOUNT_LIMIT Signed-off-by: Lukasz Majewski <lukma@denx.de> Tested-by: Alex Kiernan <alex.kiernan@gmail.com> Reviewed-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2018-02-13spi: Migrate CONFIG_MPC8XXX_SPI to KconfigTuomas Tynkkynen
2018-01-19powerpc: Drop unreferenced CONFIG_* definesTuomas Tynkkynen
The following config symbols are only defined once and never referenced anywhere else: CONFIG_CYRUS CONFIG_IDS8313 CONFIG_MPC8308_P1M CONFIG_MPC8308RDB CONFIG_MPC8349EMDS CONFIG_MPC8349ITXGP CONFIG_SBC8349 CONFIG_SBC8548 CONFIG_SBC8641D CONFIG_TQM834X CONFIG_VE8313 CONFIG_XPEDITE5140 CONFIG_XPEDITE5200 CONFIG_XPEDITE550X Most of them are config symbols named after the respective boards which seems to have been a standard practice at some point. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com> Acked-by: Mario Six <mario.six@gdsys.cc>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_PBSIZEThomas Petazzoni
Now that the fallback value of CONFIG_SYS_PBSIZE in include/config_fallbacks.h has been adjusted, remove its definition from a large number of board configuration files. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_JFFS2 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_JFFS2 Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22Convert CONFIG_CMD_ENV_FLAGS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ENV_FLAGS Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-22lib: move hash CONFIG options to KconfigTom Rini
Commit 94e3c8c4fd7b ("crypto/fsl - Add progressive hashing support using hardware acceleration.") created entries for CONFIG_SHA1, CONFIG_SHA256, CONFIG_SHA_HW_ACCEL, and CONFIG_SHA_PROG_HW_ACCEL. However, no defconfig has migrated to it. Complete the move by first adding additional logic to various Kconfig files to select this when required and then use the moveconfig tool. In many cases we can select these because they are required to implement other drivers. We also correct how we include the various hashing algorithms in SPL. This commit was generated as follows (after Kconfig additions): [1] tools/moveconfig.py -y SHA1 SHA256 SHA_HW_ACCEL [2] tools/moveconfig.py -y SHA_PROG_HW_ACCEL Note: We cannot move SHA_HW_ACCEL and SHA_PROG_HW_ACCEL simultaneously because there is dependency between them. Cc: Poonam Aggrwal <poonam.aggrwal@freescale.com> Cc: Naveen Burmi <NaveenBurmi@freescale.com> Cc: Po Liu <po.liu@freescale.com> Cc: Shengzhou Liu <Shengzhou.Liu@freescale.com> Cc: Priyanka Jain <Priyanka.Jain@freescale.com> Cc: Shaohui Xie <Shaohui.Xie@freescale.com> Cc: Chunhe Lan <Chunhe.Lan@freescale.com> Cc: Chander Kashyap <k.chander@samsung.com> Cc: Steve Rae <steve.rae@raedomain.com> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Feng Li <feng.li_2@nxp.com> Cc: Alison Wang <alison.wang@freescale.com> Cc: Sumit Garg <sumit.garg@nxp.com> Cc: Mingkai Hu <Mingkai.Hu@freescale.com> Cc: York Sun <york.sun@nxp.com> Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com> Cc: Jaehoon Chung <jh80.chung@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Heiko Schocher <hs@denx.de> Cc: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-15i2c: Drop use of CONFIG_I2C_HARDSimon Glass
This option is pretty old. It predates CONFIG_SYS_I2C which is itself deprecated in favour of driver model. Disable it for all boards. Also drop I2C options which depend on this. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-09-26kconfig: introduce kconfig for UBIHeiko Schocher
move the UBI config options into Kconfig. Signed-off-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Andrew F. Davis <afd@ti.com> Reviewed by: Evgeni Dobrev <evgeni at studio-punkt.com>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-18cmd: fdt: Use separate CMD_FDT Kconfig entry instead of OF_LIBFDTMichal Simek
Create CMD_FDT Kconfig entry to have an option to disable fdt command which is not required for small configuration which requires libfdt only. Enable it by default for all targets which enables OF_LIBFDT. Signed-off-by: Michal Simek <michal.simek@xilinx.com> [trini: Fixup flea3/sandbox/id8313/siemens-am33xx/smartweb] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-06-08autoboot.c: Move config options to KconfigStefan Roese
This patch moves the following config options to Kconfig: CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_DELAY_STR CONFIG_AUTOBOOT_STOP_STR AUTOBOOT_KEYED_CTRLC Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Drop ip04 and pm9263 configs/ additions, those boards previously set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over all boards that did change. Make digsy_mtc_* string include seconds to match others and not warn. ] Signed-off-by: Tom Rini <trini@konsulko.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-06-02configs: remove CONFIG_NET_MULTILars Poeschel
CONFIG_NET_MULTI is not used anywhere and thus can safely be removed from the configs. Acked-by: Marek Vasut <marex@denx.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Lars Poeschel <poeschel@lemonage.de>
2015-03-30nand: Remove CONFIG_MTD_NAND_VERIFY_WRITEPeter Tyser
The CONFIG_MTD_NAND_VERIFY_WRITE has been removed from Linux for some time and a more generic method of NAND verification now exists in U-Boot. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Tested-by: Heiko Schocher <hs@denx.de> Acked-by: Heiko Schocher <hs@denx.de>
2015-01-29configs: Move CONFIG_FIT_SIGNATURE to defconfigRuchika Gupta
For the platforms which use,CONFIG_FIT_SIGNATURE, the required configs are moved to the platform's defconfig file. Selecting CONFIG_FIT_SIGNATURE using defconfig automatically resolves the dependencies for signature verification. The RSA library gets automatically selected and user does not have to define CONFIG_RSA manually. Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> CC: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-11-23config: remove redundant CONFIG_SYS_PROMPT definesMasahiro Yamada
Since commit 0defddc851ed (config: Add a default CONFIG_SYS_PROMPT), each board header does not need to define CONFIG_SYS_PROMPT as long as it uses the default prompt "=> ". Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-06-23mpc8313: add CONFIG_SYS_GENERIC_BOARD to ids8313 boardHeiko Schocher
- add CONFIG_SYS_GENERIC_BOARD - remove CONFIG_OF_CONTROL to boot again Signed-off-by: Heiko Schocher <hs@denx.de> Acked-by: Kim Phillips <kim.phillips@freescale.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-06-05mpc8313, signed fit: enable legacy image format on ids8313 boardHeiko Schocher
Enable legacy image format with CONFIG_IMAGE_FORMAT_LEGACY on the ids8313 board, as it uses signed FIT images for booting Linux and need the legacy image format. Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Michael Conrad <Michael.Conrad@ids.de> Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org>
2014-05-12config: remove platform CONFIG_SYS_HZ definition part 4Masahiro Yamada
Some new boards define CONFIG_SYS_HZ again! Remove. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Bo Shen <voice.shen@atmel.com>
2014-04-23mpc83xx: add ids8313 supportHeiko Schocher
add support for the ids8313 board. CPU: e300c3, MPC8313, Rev: 2.1 at 396 MHz, CSB: 132 MHz I2C: ready SPI: ready DRAM: 128 MiB (DDR2, 32-bit, ECC off, 264 MHz) Flash: 8 MiB NAND: 128 MiB Net: TSEC0, TSEC1 [PRIME] public key on NOR flash start Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
