path: root/include/configs/ibf-dsp561.h
2011-04-08Blackfin: bf561-ezkit/ibf-dsp561: invert env offset/addr logicMike Frysinger
Have CONFIG_ENV_ADDR be based on CONFIG_ENV_OFFSET rather than the other way around so that we can use CONFIG_ENV_OFFSET during build. It also avoids a little address duplication. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: move CONFIG_BFIN_CPU back to board config.hMike Frysinger
This is a revert of 821ad16fa9900c as Wolfgang doesn't like the new code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-19Blackfin: tweak objects specified before embedded environmentMike Frysinger
The partial linking patch changes how objects are specified to the linker and breaks boards with an embedded environment. So we need to tweak the list of objects we specify via the linker script that go in the gap before the embedded env to work with this new behavior. This fixes linker errors for all the boards in question. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: move CONFIG_BFIN_CPU to board config.mkMike Frysinger
The CONFIG_BFIN_CPU option is largely used in the build system, so move it out of the board config.h and into the board config.mk. It'd be nice to keep everything in the config.h, but the patch to extract that value early was rejected. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-25Blackfin: bf533/bf561 boards: convert to new soft gpio i2c codeMike Frysinger
Use the new common gpio framework to simplify and unify the soft i2c configuration settings. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Heiko Schocher <hs@denx.de>
2010-07-13Blackfin: unify default I2C settings for ADI boardsMike Frysinger
2010-07-05Blackfin: ibf-dsp561: enable AX88180 net driverHoan Hoang
Signed-off-by: Hoan Hoang <hnhoan@i-syst.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-04-13blackfin: Move cpu/blackfin/* to arch/blackfin/cpu/*Peter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-01-17Blackfin: tweak embedded LDR env config optionMike Frysinger
Use the common config option for extracting the environment for embedding into LDR files and clarify the LDR-specific option. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: unify u-boot linker scriptsMike Frysinger
All the Blackfin linker scripts were duplicated across the board dirs with no difference save from the semi-often used ENV_IS_EMBEDDED option. So unify all of them in the lib_blackfin/ dir and for the few boards that need to embedded the environment directly, add a LDS_BOARD_TEXT define for them to customize via their board config file. This is much simpler than forcing them to duplicate the rest of the linker script. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: convert specific pre/post config headers to common methodMike Frysinger
The Blackfin port was using asm/blackfin-config-{pre,post}.h to setup common Blackfin board defines. The common method now is to use config.h, so convert blackfin-config-post.h to that. Rename the still Blackfin specific blackfin-config-pre.h to config-pre.h so the naming conventions at least line up. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-06-14Blackfin: ibf-dsp561: new board portHoan Hoang
