Now that the other architecture-specific lib directories have been
moved out of the top-level directory there's not much reason to have the
'_generic' suffix on the common lib directory.
Use the common config option for extracting the environment for embedding
into LDR files and clarify the LDR-specific option.
All the Blackfin linker scripts were duplicated across the board dirs with
no difference save from the semi-often used ENV_IS_EMBEDDED option. So
unify all of them in the lib_blackfin/ dir and for the few boards that
need to embedded the environment directly, add a LDS_BOARD_TEXT define for
them to customize via their board config file. This is much simpler than
forcing them to duplicate the rest of the linker script.
The Blackfin port was using asm/blackfin-config-{pre,post}.h to setup
common Blackfin board defines. The common method now is to use config.h,
so convert blackfin-config-post.h to that. Rename the still Blackfin
specific blackfin-config-pre.h to config-pre.h so the naming conventions
at least line up.
Signed-off-by: Hoan Hoang <hnhoan@i-syst.com>
