path: root/include/configs/ib62x0.h
2015-01-25kirkwood: ib62x0: add CONFIG_SYS_GENERIC_BOARD defineLuka Perkov
Signed-off-by: Luka Perkov <luka@openwrt.org> Acked-by: Stefan Roese <sr@denx.de> CC: Prafulla Wadaskar <prafulla@marvell.com>
2014-08-30kirkwood: kconfig: refactor Kconfig and defconfigMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the KirkWood board select menu to kirkwood/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="kirkwood"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Prafulla Wadasdkar <prafulla@marvell.com> Cc: Luka Perkov <luka@openwrt.org>
2014-01-06kirkwood: ib62x0: use device tree and update configLuka Perkov
Signed-off-by: Luka Perkov <luka@openwrt.org> CC: Prafulla Wadaskar <prafulla@marvell.com> Acked-By: Prafulla Wadaskar <prafulla@marvell.com>
2013-03-04ubifs: Allow ubifsmount volume reference by numberJoe Hershberger
UBI can mount volumes by name or number The current code forces you to name the volume by prepending every name with "ubi:". >From fs/ubifs/super.c * There are several ways to specify UBI volumes when mounting UBIFS: * o ubiX_Y - UBI device number X, volume Y; * o ubiY - UBI device number 0, volume Y; * o ubiX:NAME - mount UBI device X, volume with name NAME; * o ubi:NAME - mount UBI device 0, volume with name NAME. Now any name passed in any of the above forms are allowed. Also update the configs that referenced ubifsmount. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com>
2012-12-07Change e-mail address of Luka PerkovLuka Perkov
Change e-mail address of Luka Perkov. Signed-off-by: Luka Perkov <luka@openwrt.org> CC: Luka Perkov <uboot@lukaperkov.net>
2012-05-15kirkwood: add NAS62x0 board supportLuka Perkov
Add support for new boards RaidSonic ICY BOX NAS6210 and NAS6220. NAS6210 has 1 SATA and 1 eSATA port while NAS6220 has 2 SATA ports. More information about the boards can be found here: http://www.raidsonic.de/en/products/nas-systems.php?we_objectID=7036 http://www.raidsonic.de/en/products/nas-systems.php?we_objectID=7515 Signed-off-by: Luka Perkov <uboot@lukaperkov.net> Signed-off-by: Gerald Kerma <dreagle@doukki.net> Signed-off-by: Simon Baatz <gmbnomis@gmail.com>
