path: root/include/configs/hrcon.h
2016-10-28pci: Move CONFIG_PCI_PNP to KconfigBin Meng
Introduce CONFIG_PCI_PNP in Kconfig and move over boards' defconfig to use that. Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Tom Rini <trini@konsulko.com> [trini: Re-generate configs and include/configs/ changes] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-07-01autoboot: remove CONFIG_ZERO_BOOTDELAY_CHECKMasahiro Yamada
As the help message of CONFIG_BOOTDELAY says, CONFIG_BOOTDELAY=-2 means the autoboot with no delay, with no abort check even if CONFIG_ZERO_BOOTDELAY_CHECK is defined. To sum up, the autoboot behaves as follows: [1] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=y autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n autoboot with no delay, with no check for abort [3] CONFIG_BOOTDELAY=-1 disable autoboot [4] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort As you notice, [2] and [4] come to the same result, which means we do not need CONFIG_ZERO_BOOTDELAY_CHECK. We can control all the cases only by CONFIG_BOOTDELAY, like this: [1] CONFIG_BOOTDELAY=0 autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=-1 disable autoboot [3] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort This commit converts the logic as follow: CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n --> CONFIG_BOOTDELAY=-2 Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Christian Riesch <christian.riesch@omicronenergy.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-12hrcon: Add fan controllersDirk Eibach
Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-11-12hrcon: Add support for the DH variantDirk Eibach
hrcon DH(dual head) has two video outputs per FPGA. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-11-12hrcon: Remove CH7301 configurationDirk Eibach
hrcon has no CH7301 DVI-transmitter. Probably not removed when copying from iocon. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc>
2015-10-29common/board_f.c: change the macro name and remove it for PPC platformsGong Qianyu
For most PPC platforms, they will call the first get_clocks() in init_sequence_f[] as they define CONFIG_PPC. CONFIG_SYS_FSL_CLK is then defined to call the second get_clocks(), which should be redundant for PPC. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
2015-10-24common/board_f.c: modify the macro to use get_clocks() more commonGong Qianyu
get_clocks() should not be limited by ESDHC. Signed-off-by: Gong Qianyu <Qianyu.Gong@freescale.com>
2015-06-08autoboot.c: Move config options to KconfigStefan Roese
This patch moves the following config options to Kconfig: CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_DELAY_STR CONFIG_AUTOBOOT_STOP_STR AUTOBOOT_KEYED_CTRLC Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Drop ip04 and pm9263 configs/ additions, those boards previously set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over all boards that did change. Make digsy_mtc_* string include seconds to match others and not warn. ] Signed-off-by: Tom Rini <trini@konsulko.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2014-11-19mpc83xx: Add gdsys hrcon boardDirk Eibach
The gdsys hrcon board is based on a Freescale MPC8308 SOC. It boots from NOR-Flash, kernel and rootfs are stored on SD-Card. On board peripherals include: - 1x GbE (optional) - Lattice ECP3 FPGA connected via eLBC and PCIe Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Stefan Roese <sr@denx.de>
