path: root/include/configs/hmi1001.h
2008-06-03PPC: Create and use CONFIG_HIGH_BATSBecky Bruce
Change all code that conditionally operates on high bat registers (that is, BATs 4-7) to look at CONFIG_HIGH_BATS instead of the myriad ways this is done now. Define the option for every config for which high bats are supported (and enabled by early boot, on parts where they're not always enabled) Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-04-13Update CONFIG_PCIAUTO_SKIP_HOST_BRIDGE to related boardsTsiChung Liew
Remove test for CONFIG_MPC5200 in drivers/pci/pci_auto.c and define CONFIG_PCIAUTO_SKIP_HOST_BRIDGE in related board configuration files. Signed-off-by: TsiChung Liew <Tsi-Chung.Liew@freescale.com>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2007-07-10include/configs/[g-o]*: Cleanup BOOTP and lingering CFG_CMD_*.Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various h* named board config files.Jon Loeliger
2007-05-28Merge with /home/tur/git/u-boot#motionproWolfgang Denk
2007-05-27MPC5xxx: Change names of defines related to IPB and PCI clocks.Bartlomiej Sieka
Both CFG_PCISPEED_66 and CFG_IPBSPEED_133 are misnamed, as defining them does not cause PCI or IPB clocks to run at the specified speed. Instead, they configure divisors used to calculate said clocks. This patch renames the defines according to their real function. Signed-off-by: Grzegorz Bernacki <gjb@semihalf.com> Acked-by: Bartlomiej Sieka <tur@semihalf.com>
2007-03-07HMI1001: fix build error, cleanup compiler warnings.Wolfgang Denk
2005-09-03Enable SM712 driver support for HMI1001 board.Wolfgang Denk
2005-08-30Adjust CS3 timings on HMI1001 board for dot matrix display under LinuxWolfgang Denk
2005-08-30Add keyboard and dot matrix display support for HMI1001 board.Wolfgang Denk
2005-08-16Enable PCI on hmi1001 boardWolfgang Denk
2005-08-10Fix CompactFlash problem on HMI1001 boardWolfgang Denk
2005-07-21Add CompactFlash support for HMI1001 board.Wolfgang Denk
2005-06-27* Fix baudrate calculation problem on MPC5200 systemswdenk
* Add MPC8220 boards to MAKEALL script * Add EEPROM and RTC support for HMI1001 board * Patch by Detlev Zundel, 20 Jun 2005: Fix initialization of low active GPIO pins on inka4x0 board
2005-06-20Enable redundant environment, disable HW flash protection of HMI1001 boardwdenk
2005-06-10* Add support for HMI1001 boardwdenk
* Disable "date" and "sntp" commands on TQM866M which has no RTC
