path: root/include/configs/highbank.h
2015-08-12ARM: highbank: remove DRAM bank setupRob Herring
On the highbank platform the SoC's management controller firmware will probe the DRAM modules and populates the initial device tree with the correct values. Therefore the memory sizes in the DT are already correct, so remove U-Boot's DRAM bank setup so the memory node is not "fixed up" by u-boot. Signed-off-by: Rob Herring <robh@kernel.org> Signed-off-by: Andre Przywara <osp@andrep.de>
2015-06-08autoboot.c: Move config options to KconfigStefan Roese
This patch moves the following config options to Kconfig: CONFIG_AUTOBOOT_KEYED CONFIG_AUTOBOOT_PROMPT CONFIG_AUTOBOOT_DELAY_STR CONFIG_AUTOBOOT_STOP_STR AUTOBOOT_KEYED_CTRLC Signed-off-by: Stefan Roese <sr@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Drop ip04 and pm9263 configs/ additions, those boards previously set CONFIG_AUTOBOOT_PROMPT but never used it, re-run savedefconfig over all boards that did change. Make digsy_mtc_* string include seconds to match others and not warn. ] Signed-off-by: Tom Rini <trini@konsulko.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com>
2014-05-25ARM: highbank: convert to generic boardRob Herring
Enable CONFIG_SYS_GENERIC_BOARD on highbank. Signed-off-by: Rob Herring <robh@kernel.org>
2014-05-02ARM: highbank: use default promptRob Herring
Since highbank is actually shared between Highbank and Midway platforms, remove the Highbank name from the prompt and use the default. Signed-off-by: Rob Herring <robh@kernel.org>
2014-05-02ARM: highbank: use config_distro_defaults.hRob Herring
Adapt highbank to use config_distro_defaults.h and remove the redundant defines. Signed-off-by: Rob Herring <robh@kernel.org>
2013-11-15configs: clean up unused macro CONFIG_L2_OFFMasahiro Yamada
Since commit c2dd0d455 and 45bf05854 introduced the new cache maintainance framework to ARM, CONFIG_L2_OFF has not been used at all. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-08highbank: set AUTOBOOT_KEYED_CTRLC config optionMark Langsdorf
Let highbank users break into the autoboot script with ctrl-c. Signed-off-by: Mark Langsdorf <mark.langsdorf@calxeda.com>
2013-11-04ARM: highbank: convert to common timer codeRob Herring
Convert highbank to use the commmon timer code. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-09-06ahci: convert to use libata functions and definitionsRob Herring
libata already has similar functions as implemented in the ahci code. Refactor the code to use the libata variants and remove the dependency on ata.h. Convert some defines to use the version from libata.h. Also, remove some unnecessary memset's of bss data. This is a step toward hopefully merging ahci.c and dw_ahsata.c which are essentially the same driver. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Tom Rini <trini@ti.com>
2013-07-25Merge branch 'u-boot/master' into u-boot-arm/masterAlbert ARIBAUD
2013-07-25highbank: enable keyed autoboot stopRob Herring
Restrict autoboot interruption to "s" or "d" keys. This will prevent some unwanted stopping and also allow disabling the reset on command timeout. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-07-25ARM: highbank: setup peripherals based on power domain statusRob Herring
Accessing powered down peripherals will hang the bus, so check power domain status before initializing SATA and fixup the FDT to disable unused peripherals. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-07-25ARM: highbank: enable reset on command timeoutRob Herring
Enable resetting on command timeout. The timeout is set with environment setting bootretry. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-07-25ARM: highbank: update config optionsRob Herring
Various changes to highbank config: Enable EFI partitions Enable ext4 and FAT filesystems Enable bootz command and raw initrd Increase cmd and print buffer size to 1K Change serial baudrate to 115200 Enable hush shell Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-09-01Consolidate bootcount code into drivers/bootcountStefan Roese
This patch moves all bootcount implementations into a common directory: drivers/bootcount. The generic bootcount driver is now usable not only by powerpc platforms, but others as well. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Valentin Longchamp <valentin.longchamp@keymile.com> Cc: Christian Riesch <christian.riesch@omicron.at> Cc: Manfred Rudigier <manfred.rudigier@omicron.at> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Reinhard Meyer <reinhard.meyer@emk-elektronik.de> Tested-by: Valentin Longchamp <valentin.longchamp@keymile.com> Tested-by: Christian Riesch <christian.riesch@omicron.at> Acked-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-03-28ARM: highbank: change env config to use nvramJason Hobbs
Update the highbank config to use env from NVRAM. Also remove extra env settings as they are not used unless the default env is used. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-03-28ARM: highbank: Add boot counter supportRob Herring
Add boot counter support using an sysreg which is persistent across reset. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-03-28ARM: highbank: change TEXT_BASE to 0x8000Rob Herring
Make some space at the beginning of RAM so the FDT can be loaded to a known fixed address at 0x1000. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-01-05ARM: highbank: enable networking and pxeRob Herring
This enables the XGMAC ethernet driver and networking related config options. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2011-10-27ARM: Add Calxeda Highbank platformRob Herring
Add basic support for Calxeda Highbank platform. Only minimal support with serial and SATA are included. Signed-off-by: Jason Hobbs <jason.hobbs@calxeda.com> Signed-off-by: Rob Herring <rob.herring@calxeda.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
