path: root/include/configs/hermes.h
2007-07-09include/configs/[a-m]*: Directly use CONFIG_BOOTP_* symbols rather than ↵Jon Loeliger
2007-07-05include/configs: Use new CONFIG_CMD_* in various h* named board config files.Jon Loeliger
2002-08-20Initial revisionwdenk
