path: root/include/configs/hcu4.h
2008-09-10rename CFG_ENV_IS_NOWHERE in CONFIG_ENV_IS_NOWHEREJean-Christophe PLAGNIOL-VILLARD
2008-09-10rename CFG_ENV_IS_IN_NVRAM in CONFIG_ENV_IS_IN_NVRAMJean-Christophe PLAGNIOL-VILLARD
2008-03-15ppc4xx: HCU4/5. Use FLASH_CFI_LEGACYNiklaus Giger
Cleanup: Remove custom flash driver for 8 bit boot-eprom and replace it with the FLASH_CFI_LEGACY et al. config options. Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2008-03-06Replace "run load; run update" with conditionalized "run load update".Detlev Zundel
The latter version stops when "run load" fails for whatever reasons rendering the combination *a lot* more secure. Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-03-03Fix quoting problem (preboot setting) in many board config files.Wolfgang Denk
2008-02-16ppc4xx: HCU4/5. Cleanup configsNiklaus Giger
- hcu4.h: Removed define of CONFIG_PPC405GPr - Corrected phy addresses - Fix boot variables - Respect line length of 80 chars Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2008-01-17ppc4xx: Netstal HCU4 board. Added POST. Various fixesNiklaus Giger
- Various fixes - Reduced rom_size from 384 to 320 kB - Environment is now in flash - Added POST - Support for OF Signed-off-by: Niklaus Giger <niklaus.giger@netstal.com>
2007-10-31ppc4xx: Remove cache definition from 4xx board config filesStefan Roese
All 4xx board config files don't need the cache definitions anymore. These are now defined in common headers. Signed-off-by: Stefan Roese <sr@denx.de>
2007-08-14Merge with git://www.denx.de/git/u-boot.gitStefan Roese
2007-08-10Coding style cleanupStefan Roese
2007-08-10Add PPC4xx-HCU4 and HCU5 boards: HCU4 configNiklaus Giger
