path: root/include/configs/harmony.h
2015-03-04ARM: tegra: move common config defines centrallyStephen Warren
All boards need CONFIG_BOARD_EARLY_INIT_F, and many actively need CONFIG_BOARD_LATE_INIT. Move both of these into tegra-common.h so that board config headers don't need to repeatedly define them. Later commits will add new code in board_late_init() which applies to all boards, so CONFIG_BOARD_LATE_INIT should be enabled for all Tegra boards. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-09-25kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfigMasahiro Yamada
This option specifies the default Device Tree used for the run-time configuration of U-Boot. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Michal Simek <michal.simek@xilinx.com>
2014-09-25kconfig: move CONFIG_OF_* to KconfigMasahiro Yamada
This commit moves: CONFIG_OF_CONTROL CONFIG_OF_SEPARATE CONFIG_OF_EMBED CONFIG_OF_HOSTFILE Because these options are currently not supported for SPL, the "Device Tree Control" menu does not appear in the SPL configuration. Note: zynq-common.h should be adjusted so as not to change the default value of CONFIG_SPL_FAT_LOAD_PAYLOAD_NAME. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@nvidia.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Acked-by: Michal Simek <michal.simek@xilinx.com>
2014-03-12tegra: imx: omap: enable Moschip USB ethernet support for several boardsGerhard Sittig
enable support for the Moschip USB ethernet adapter for those boards which previously had support for "all other" USB ethernet adapters (that's Asix _and_ SMSC) enabled -- which applies to harmony, m53evk, mx53loco, nitrogen6x, omap3_beagle Signed-off-by: Gerhard Sittig <gsi@denx.de> Acked-by: Marek Vasut <marex@denx.de>
2014-03-12tegra: omap: alpha-sort USB ethernet items for Asix and SMSCGerhard Sittig
adjust the harmony and omap3_beagle board configs to make their CONFIG_USB_ETHER_* items appear in alphabetical order Signed-off-by: Gerhard Sittig <gsi@denx.de> Acked-by: Simon Glass <sjg@chromium.org> Acked-by: Marek Vasut <marex@denx.de>
2014-03-04sizes.h - consolidate for all architecturesAlexey Brodkin
Copied from Linux sources "include/linux/sizes.h" commit 413541dd66d51f791a0b169d9b9014e4f56be13c Signed-off-by: Alexey Brodkin <abrodkin@synopsys.com> Cc: Vineet Gupta <vgupta@synopsys.com> Cc: Tom Rini <trini@ti.com> Cc: Stefan Roese <sr@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Acked-by: Tom Rini <trini@ti.com> Acked-by: Stefan Roese <sr@denx.de> [trini: Add bcm Kona platforms to the patch] Signed-off-by: Tom Rini <trini@ti.com>
2013-07-11ARM: tegra: enable LCD panel on HarmonyStephen Warren
2013-03-14ARM: tegra: enable a common set of disk-related commands everywhereStephen Warren
Enable a common set of partition types, filesystems, and related commands in tegra-common.h, so that they are available on all Tegra boards. This allows boot.scr (loaded and executed by the default built-in environment) on those boards to assume that certain features are always available. Do this in tegra-common.h, so that individual board files can undefine the features if they really don't want any of them. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: use generic fs commands in BOOTCOMMANDStephen Warren
Modify tegra-common-post.h's BOOTCOMMAND definition to use the generic filesystem command load rather than separate fatload and ext2load. This removes the need to iterate over supported filesystem types in the boot command. This requires editing all board config headers to enable the new commands. The now-unused commands are left enabled to assue backwards compatibility with any user scripts. Boards (all from Avionic Design) which define custom BOOTCOMMAND values are not affected. Signed-off-by: Stephen Warren <swarren@nvidia.com> tegra generic fs cmds fixup Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-11-19tegra: Remove unnecessary CONFIG_SYS_NAND_BASESimon Glass
Now that we are using the new CONFIG_SYS_NAND_SELF_INIT setup, we don't need CONFIG_SYS_NAND_BASE. Punt it. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-29ARM: tegra: Harmony: enable ULPI USB portStephen Warren
The ULPI port is routed onto pins on the mini PCI Express connector. A standard breakout board may be used to access the port. * Add required DT entries to configure the ULPI port. * Setup up the ULPI pinmux in the board code. * Enable multiple USB controller and ULPI support in the board config. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from config filesMarek Vasut
Remove any notion of CONFIG_SERIAL_MULTI from board config files. Since CONFIG_SERIAL_MULTI is now enabled by default, it is useless to specify this config option in the board config files. Therefore remove it. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-10Tegra: Change Tegra20 to Tegra in common code, prep for T30Tom Warren
Convert TEGRA20_ defines to either TEGRA_ or NV_PA_ where appropriate. Convert tegra20_ source file and function names to tegra_, also. Upcoming Tegra30 port will use common code/defines/names where possible. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com>
2012-09-07tegra: enable NAND on HarmonyStephen Warren
2012-09-01tegra20: rename tegra2 -> tegra20Allen Martin
This is make naming consistent with the kernel and devicetree and in preparation of pulling out the common tegra20 code. Signed-off-by: Allen Martin <amartin@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-07arm: Tegra: Use ODMDATA from BCT in IRAMTom Warren
Walk the BIT and BCT to find the ODMDATA word in the CustomerData field and put it into Scratch20 reg for use by kernel, etc. Built all Tegra builds OK; Booted on Seaboard and saw ODMDATA in PMC scratch20 was the same as the value in my burn-u-boot.sh file (0x300D8011). NOTE: All flash utilities will have to specify the odmdata (nvflash --odmdata n) on the command line or via a cfg file, or built in to their BCT. Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org>
2012-07-07mmc: tegra2: rename tegra2_mmc.* to tegra_mmc.*Tom Warren
In anticipation of Tegra3 support, continue removing/renaming Tegra2-specific files. No functional changes (yet). Updated copyrights to 2012. Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-07tegra: harmony: add device tree supportStephen Warren
... to enable USB host support, which enables Ethernet support. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-07tegra: flesh out bootcmdStephen Warren
This implements a useful bootcmd for Tegra. The boot order is: * If USB enabled, USB storage * Internal MMC (SD card or eMMC) * If networking is enabled, BOOTP/TFTP When booting from USB or MMC, the boot script is assumed to be in partition 1 (although this may be overridden via the rootpart variable), both ext2 and FAT filesystems are supported, the boot script may exist in either / or /boot, and the boot script may be named boot.scr.uimg or boot.scr. When booting over the network, it is assumed that boot.scr.uimg exists on the TFTP server. There is less flexibility here since those setting up network booting are expected to need less hand-holding. In all cases, it is expected that the initial file loaded is a U-Boot image containing a script that will load the kernel, load any required initrd, load any required DTB, and finally bootm the kernel. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-07-07tegra: remove some cruft from CONFIG_EXTRA_ENV_SETTINGSStephen Warren
console isn't used by anything, and the kernel should be set appropriately by whatever script is booting the kernel, not imposed by the bootloader. mem might be useful, but the current value is pretty bogus, since it includes nvmem options that make no sense for an upstream kernel, and equally should not be required for any downstream kernel. Either way, this is also best left to the kernel boot script. smpflag isn't used by anything, and again was probably intended to be a kernel command-line option better set by the kernel boot script. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-12-24tegra2: Enable SPI environment on SeaboardSimon Glass
This uses the SPI flash on Seaboard to store an 8KB environment. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2011-07-15mmc: Tegra2: Enable SD/MMC driver for Seaboard and HarmonyTom Warren
Signed-off-by: Tom Warren <twarren@nvidia.com> Acked-by: Andy Fleming <afleming@freescale.com>
2011-04-27arm: Tegra2: add support for A9 CPU initTom Warren
2011-02-21arm: Tegra2: Add support for NVIDIA Harmony boardTom Warren
