path: root/include/configs/gw_ventana.h
2016-05-31imx: ventana: config: add PREBOOT supportTim Harvey
This allows the 'preboot' env variable to be executed prior to bootcmd if defined. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2016-05-31imx: ventana: config: use explicit addr in loadscriptTim Harvey
If we are loading a script to ${loadaddr} then we need to use that address explicitly when calling the source command in case user has changed loadaddr Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2016-05-31imx: ventana: config: use fs env var for block dev filesystem typeTim Harvey
In order to make the default boot scripts more flexible, use the variable 'fs' to specify the filesystem type to use for block storage devices (USB/MMC/SATA) when loading files. Additionally default this to ext4 and enable ext4 filesystem support (which encompasses ext2 support) instead of just ext2 support. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2016-05-31imx: ventana: config: use bootdir env var for directory of fdt filesTim Harvey
In order to make the default boot scripts more flexible, use the variable 'bootdir' to specify the filesystem directory to look for fdt files in. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2016-05-31imx: ventana: config: add fixfdt script to apply manual fdt fixupsTim Harvey
2016-05-31imx: ventana: config: add env vars for disk and partTim Harvey
In order to make the default boot scripts more flexible, use the variable 'disk' to specify the disk device number and the variable 'part' to specify the partition number. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2016-05-24imx: ventana: remove SPL_EXT_SUPPORTTim Harvey
Remove SPL_EXT_SUPPORT to resolve build issue. It may be useful to bring it back in the future after comparing its merits to storing the args/kernel in fixed raw locations. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2016-05-24imx: ventana: use EEPROM register for falcon boot modeTim Harvey
NAND+MMC env support costs 12KB in the SPL which is fairly expensive just for the ability to specify whether or not to boot to uboot or directly to linux. The Ventana boards have plenty of EEPROM storage so we will use a byte there to signify if we should boot to the bootloader or to the OS. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2016-05-24imx: ventana: config: remove redundant configTim Harvey
remove redundant define that exists in mx6_common.h Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2016-04-20usb: gadget Move: CONFIG_G_DNL_* to KconfigSam Protsenko
And also reformat defconfigs using "make savedefconfig" rule. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DOWNLOAD to KconfigSam Protsenko
While at it, remove obsolete CONFIG_USBDOWNLOAD_GADGET option from some config headers. This is also probably fixes am335x_baltos board. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_DUALSPEED to KconfigSam Protsenko
Move CONFIG_USB_GADGET_DUALSPEED option to Kconfig and make all UDC controllers select USB_GADGET_DUALSPEED: - add next options to Kconfig selecting USB_GADGET_DUALSPEED: - USB_GADGET_ATMEL_USBA - USB_GADGET_DWC2_OTG - USB_DWC3 - CI_UDC - make USB_MUSB_GADGET select USB_GADGET_DUALSPEED While at it, make some related fixes: - remove DUALSPEED from configs that don't enable gadget support: - kwb.h - tseries.h - add missing USB_GADGET option to next configs: - novena_defconfig - pcm051_rev*_defconfig - xfi3_defconfig Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-04-20usb: gadget: Move CONFIG_USB_GADGET_VBUS_DRAW to KconfigSam Protsenko
The description was borrowed from kernel. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Boards using 0 mA as CONFIG_USB_GADGET_VBUS_DRAW value were moved to use 2 mA (as minimal allowed by Kconfig). Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org>
2016-03-25usb: gadget: Move CONFIG_USB_GADGET to KconfigSam Protsenko
The description was borrowed from kernel. "tristate" type was changed to "bool" (I believe we don't support modules for u-boot yet, right?). CONFIG_USB_GADGET requires CONFIG_USB to be defined too, so add it along as well. Definitions were added to defconfig files in a way that "make savedefconfig" generates exactly the same file as used defconfig. Signed-off-by: Sam Protsenko <semen.protsenko@linaro.org> [trini: Add zynq_zc702 conversion] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-10-02I2C: mxc_i2c: make I2C1 and I2C2 optionalAlbert ARIBAUD \\(3ADEV\\)
The driver assumed that I2C1 and I2C2 were always enabled, and if they were not, then an asynchronous abort was (silently) raised, to be caught much later on in the Linux kernel. Fix this by making I2C1 and I2C2 optional just like I2C3 and I2C4 are. To make the change binary-invariant, declare I2C1 and I2C2 in every include/configs/ file which defines CONFIG_SYS_I2C_MXC. Also, while updating README about CONFIG_SYS_I2C_MXC_I2C1 and CONFIG_SYS_I2C_MXC_I2C2, add missing descriptions for I2C4 speed (CONFIG_SYS_MXC_I2C4_SPEED) and slave (CONFIG_SYS_MXC_I2C4_SLAVE) config options. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-09-13thermal: imx_thermal: rework driver to be reusedAdrian Alonso
Rework imx_thermal driver to be used across i.MX processor that support thermal sensor Signed-off-by: Adrian Alonso <aalonso@freescale.com> Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
2015-08-02Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-07-22usb: USB download gadget and functions config options coherent namingPaul Kocialkowski
This introduces a coherent scheme for naming USB download gadget and functions config options. The download USB gadget config option is moved to CONFIG_USB_GADGET_DOWNLOAD for better consistency with other gadgets and each function's config option is moved to a CONFIG_USB_FUNCTION_ prefix. Signed-off-by: Paul Kocialkowski <contact@paulk.fr> Tested-by: Lukasz Majewski <l.majewski@samsung.com> Test HW: Odroid_XU3 (Exynos5422), trats (Exynos4210)
2015-07-10imx6: standardise OCOTP and fuse config to mx6_commonPeter Robinson
According to README.mxc_ocotp the OCOTP is a stanard i.MX6 SoC feature so centralise the config in mx6_common.h so functionality is standard across all boards Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Acked-by: Stefano Babic <sbabic@denx.de>
2015-05-26mx6: standardise CONFIG_CMD_CACHEPeter Robinson
Move CONFIG_CMD_CACHE to mx6_common and standardise the way it's defined. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: generic MMC config options to mx6_commonPeter Robinson
Move all standard mx6 MMC configs to mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: standardise filesystem and boot optionsPeter Robinson
Move all standard filesystem, partition and fdt options to mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move generic miscellaneous and overwrite optionsPeter Robinson
Move generic miscellaneous options that are standard across most, if not all, mx6 boards to central mx6_common define to ensure consistent features. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: centralise common boot options in mx6_common.hPeter Robinson
Define common LOADADDR and BOOTDELAY to ensure a consistent experience across mx6 boards Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx6: move standard ATAG configs to mx6_common.hPeter Robinson
Define the standard ATAG consfigs in mx6_common. Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: move generic imx6 options to mx6_common.hPeter Robinson
All boards define CONFIG_MX6, CONFIG_DISPLAY_BOARDINFO, CONFIG_DISPLAY_CPUINFO and CONFIG_SYS_GENERIC_BOARD so define them in mx6_common Signed-off-by: Peter Robinson <pbrobinson@gmail.com> Reviewed-by: Tom Rini <trini at konsulko.com>
2015-05-26imx6: move all standard includes to mx6_common.hPeter Robinson
The linux/sizes.h, asm/arch/imx-regs.h, asm/imx-common/gpio.h, config_cmd_default.h includes are used fairly universally across imx6 boards so include them in mx6_common.h by default. We define CONFIG_SYS_NO_FLASH before config_cmd_default.h so that we don't have to undef CONFIG_CMD_FLASH / CONFIG_CMD_IMLS everywhere. Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
2015-05-26imx: ventana: update MMC env configurationTim Harvey
We will use the same env size and redundancy used for NAND env for MMC. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-21imx: ventana: config: enable Falcon modeTim Harvey
Falcon mode entails the SPL booting the OS directly instead of U-Boot. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-19imx: ventana: add pmic_setup to SPLTim Harvey
We need to do any PMIC setup in the SPL if we are to bypass U-Boot for falcon mode. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-19imx: ventana: (cosmetic) clean up size defines for improved readabilityTim Harvey
Use the SZ_1M and SZ_1K macros from linuz/sizes.h for improved readability Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-19imx: ventana: config: use MMC SPL RAW supportTim Harvey
Switch to MMC RAW support for SPL. We will place the uboot.img at 69KB. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-15imx: ventana: config: enable Thermal supportTim Harvey
2015-05-15imx: ventana: enable DM_SERIALTim Harvey
mxc_serial supports DM so lets use it. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-15imx: ventana: config: enable driver modelTim Harvey
Enable U-Boot Driver Model (DM). Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-15imx: ventana: config: enable gpio commandTim Harvey
2015-05-15imx: ventana: display SPL boot deviceTim Harvey
Display what device the SPL will fetch uboot.img from Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-05-15imx: ventana: set dtype env var to boot mediaTim Harvey
Bootscripts for some distro's such as Android can benefit from knowing what boot media its script was loaded from. Signed-off-by: Tim Harvey <tharvey@gateworks.com>
2015-04-28Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2015-04-23driver/i2c/mxc: Enable I2C bus 3 and 4York Sun
Some SoCs have more than two I2C busses. Instead of adding ifdef to the driver, macros are put into board header file where CONFIG_SYS_I2C_MXC is defined. Signed-off-by: York Sun <yorksun@freescale.com> CC: Heiko Schocher <hs@denx.de>
