path: root/include/configs/guruplug.h
2018-01-10ARM: Drop unreferenced CONFIG_MACH_* definesTuomas Tynkkynen
These macros are all defined once and never checked or used anywhere: CONFIG_MACH_ASPENITE CONFIG_MACH_DAVINCI_CALIMAIN CONFIG_MACH_DOCKSTAR CONFIG_MACH_EDMINIV2 CONFIG_MACH_GOFLEXHOME CONFIG_MACH_GONI CONFIG_MACH_GURUPLUG CONFIG_MACH_KM_KIRKWOOD CONFIG_MACH_OPENRD_BASE CONFIG_MACH_SHEEVAPLUG Almost all of them were only used for the mach_is_foo() logic in arch/arm/asm/mach-types.h that were dropped in commit f9dadaef8b75fa ("arm: Re-sync asm/mach-types.h with Linux Kernel v4.9") Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-17arm: kirkwood: Move common definitions into common fileQuentin Armitage
Create include/configs/mv-plug-common.h for common definitions for Sheevaplug, Guruplug and Dreamplug. This will make it easier to ensure the built u-boots stay in track with each other Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-11-17arm: kirkwood: Use common definition for filesystemsQuentin Armitage
include/configs/mv-common.h brings in the required filesystems if CONFIG_SYS_MVFS is defined, so use it for Sheevaplug and Guruplug. Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-11-17arm: kirkwood: Move configuration of some commands to _defconfig filesQuentin Armitage
For Marvell plugs, move the configuration of DHCP, NAND/SF, PING and USB commands, and HUSH_PARSER into the _defconfig file, rather than the include/configs/*plug.h files. This avoids compiler warnings of duplicate definitions if the option is selected in the .config, but also defined in the include/configs/*plug.h file. Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-11-17arm: kirkwood: Remove duplicate definition of CONFIG_CMD_FATQuentin Armitage
include/configs/guruplug.h defined CONFIG_CMD_FAT twice. Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-11-17arm: kirkwood: standardise the configurationQuentin Armitage
The Marvell plugs are very similar systems, and so it makes sense for their u-boots to have the same commands/configuration. Add EXT4 and MII to Dreamplug, DATE to Guruplug and Sheevaplug. Add CONFIG_SYS_ALT_MEMTEST to Sheevaplug. There are still command differences around NAND, SPI/NOR. Also default to building u-boot.kwb for Sheevaplug and Guruplug. Signed-off-by: Quentin Armitage <quentin@armitage.org.uk>
2015-01-26marvell: kirkwood: guruplug refresh for newer kernelGerald Kerma
Refresh for newer kernel. Prepare ENV settings for sheevaplugs to be OpenWRT ready. +----------+ | UBOOT | >> 896 Kb (7x128) = uboot +----------+ | ENV | >> 128 Kb = uboot_env +----------+ | ROOT(FS) | >> 511 Mb @ 1 Mb = root -> rootfs (ubifs) +----------+ With (CC) TRUNK OpenWRT build (QUICK HOWTO) : <INTERRUPT> Marvell>> nand erase.part root Marvell>> ubi part root Marvell>> ubi remove rootfs Marvell>> ubi create rootfs Marvell>> usb reset Marvell>> fatload usb 2:1 0x800000 guruplug/openwrt/openwrt-kirkwood-guruplug-rootfs.ubifs Marvell>> ubi write 0x800000 rootfs ${filesize} Marvell>> reset Changes in v1: - ADD generic board define - ADD FDT support - ADD HUSH interpreter - Define new NAND partition mapping Signed-off-by: Gerald Kerma <dreagle@doukki.net>
2014-08-30kirkwood: kconfig: refactor Kconfig and defconfigMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the KirkWood board select menu to kirkwood/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="kirkwood"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Prafulla Wadasdkar <prafulla@marvell.com> Cc: Luka Perkov <luka@openwrt.org>
2010-10-28kirkwood: guruplug: Relocate NAND environment areaGray Remlin
Current default options increase u-boot size to overlap the location of the environment in NAND, move environment higher up Signed-off-by: Gray Remlin <g_remlin@rocketmail.com>
2010-10-13kirkwood: added common config file mv-common.hPrafulla Wadaskar
It is observed that, in most of the board configs the code is being duplicated, also for any common change all board files needs update This issue was under discussion from long on mailing list and we converge on introducing common config file. With this patch- 1. Total Kirkwood specific configuration code is reduced by 210 lines 2. All common configuration can be shared by multiple boards 3. Easy to manage common updates like ARM relocation changes mv-common.h file is added to include/configs/ It contains all common configuration supported for all Kirkwood boards The respective board configs are updated for its usage Build tested for guruplug, mv88f6281gtw_ge, openrd_base, rd6281a and sheevaplug Binary execution tested for sheevaplug Todo: 1. Other custom Kirkwood boards to be synced 2. The support to be extended for Orion5X based boards Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2010-07-12mvgbe: support SoCs other than kirkwoodAlbert Aribaud
Rename all references to kirkwood in mvgbe symbols throughout the whole codebase. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-04-30Marvell GuruPlug Board SupportSiddarth Gore
GuruPlug Standard: 1 Gb Ethernet, 2 USB 2.0 GuruPlug Plus: 2 Gb Ethernet, 2 USB 2.0, 1 eSATA, 1 uSD slot References: http://www.globalscaletechnologies.com/t-guruplugdetails.aspx http://plugcomputer.org This patch is for GuruPlug Plus, but it supports Standard version as well. Signed-off-by: Siddarth Gore <gores@marvell.com>
