path: root/include/configs/guruplug.h
2015-01-26marvell: kirkwood: guruplug refresh for newer kernelGerald Kerma
Refresh for newer kernel. Prepare ENV settings for sheevaplugs to be OpenWRT ready. +----------+ | UBOOT | >> 896 Kb (7x128) = uboot +----------+ | ENV | >> 128 Kb = uboot_env +----------+ | ROOT(FS) | >> 511 Mb @ 1 Mb = root -> rootfs (ubifs) +----------+ With (CC) TRUNK OpenWRT build (QUICK HOWTO) : <INTERRUPT> Marvell>> nand erase.part root Marvell>> ubi part root Marvell>> ubi remove rootfs Marvell>> ubi create rootfs Marvell>> usb reset Marvell>> fatload usb 2:1 0x800000 guruplug/openwrt/openwrt-kirkwood-guruplug-rootfs.ubifs Marvell>> ubi write 0x800000 rootfs ${filesize} Marvell>> reset Changes in v1: - ADD generic board define - ADD FDT support - ADD HUSH interpreter - Define new NAND partition mapping Signed-off-by: Gerald Kerma <dreagle@doukki.net>
2014-08-30kirkwood: kconfig: refactor Kconfig and defconfigMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the KirkWood board select menu to kirkwood/Kconfig. Consolidate also common settings (CONFIG_SYS_CPU="arm926ejs" and CONFIG_SYS_SOC="kirkwood"). Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Prafulla Wadasdkar <prafulla@marvell.com> Cc: Luka Perkov <luka@openwrt.org>
2010-10-28kirkwood: guruplug: Relocate NAND environment areaGray Remlin
Current default options increase u-boot size to overlap the location of the environment in NAND, move environment higher up Signed-off-by: Gray Remlin <g_remlin@rocketmail.com>
2010-10-13kirkwood: added common config file mv-common.hPrafulla Wadaskar
It is observed that, in most of the board configs the code is being duplicated, also for any common change all board files needs update This issue was under discussion from long on mailing list and we converge on introducing common config file. With this patch- 1. Total Kirkwood specific configuration code is reduced by 210 lines 2. All common configuration can be shared by multiple boards 3. Easy to manage common updates like ARM relocation changes mv-common.h file is added to include/configs/ It contains all common configuration supported for all Kirkwood boards The respective board configs are updated for its usage Build tested for guruplug, mv88f6281gtw_ge, openrd_base, rd6281a and sheevaplug Binary execution tested for sheevaplug Todo: 1. Other custom Kirkwood boards to be synced 2. The support to be extended for Orion5X based boards Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com>
2010-07-12mvgbe: support SoCs other than kirkwoodAlbert Aribaud
Rename all references to kirkwood in mvgbe symbols throughout the whole codebase. Signed-off-by: Albert Aribaud <albert.aribaud@free.fr> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-04-30Marvell GuruPlug Board SupportSiddarth Gore
GuruPlug Standard: 1 Gb Ethernet, 2 USB 2.0 GuruPlug Plus: 2 Gb Ethernet, 2 USB 2.0, 1 eSATA, 1 uSD slot References: http://www.globalscaletechnologies.com/t-guruplugdetails.aspx http://plugcomputer.org This patch is for GuruPlug Plus, but it supports Standard version as well. Signed-off-by: Siddarth Gore <gores@marvell.com>
