path: root/include/configs/grsim_leon2.h
2014-05-20fpga: Guard the LOADMK functionality with CMD_FPGA_LOADMKSiva Durga Prasad Paladugu
Guard the LOADMK functionality with config to provide an option to enable or disable it. Enable it for all platforms in mainline which enable CONFIG_CMD_FPGA. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-03-21sparc: consolidate CONFIG_{LEON, LEON2, LEON3} definitionMasahiro Yamada
CONFIG_LEON is already defined in arch/sparc/cpu/{leon2,leon3}/config.mk. Remove the redundant definition in board header files. All leon3 boards define CONFIG_LEON3 in board header files. Move the definition to arch/sparc/cpu/leon3/config.mk. CONFIG_LEON2 can be move to arch/sparc/cpu/leon2/config.mk as well. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Hellstrom <daniel@gaisler.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-12-05sparc: fix unknown escape sequence warningsMike Frysinger
I don't know what exactly the code was going for, but the object code is the same before/after my change, and in looking at the env strings, this seems to be OK. Otherwise gcc warns: cc1: warning: unknown escape sequence: '\$' cc1: warning: unknown escape sequence: '\)' cc1: warning: unknown escape sequence: '\040' cc1: warning: unknown escape sequence: '\$' cc1: warning: unknown escape sequence: '\)' Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22common: cosmetic: CONFIG_BOOTFILE checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22common: cosmetic: CONFIG_ROOTPATH checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2009-04-03Add "source" command; prepare removal of "autoscr" commandWolfgang Denk
According to the doc/feature-removal-schedule.txt, the "autoscr" command will be replaced by the "source" command in approximately 6 months from now. This patch prepares this change and starts a 6 month transition period as follows: - The new "source" command has been added, which implements exactly the same functionlaity as the old "autoscr" command before - The old "autoscr" command name is kept as an alias for compatibility - Command sequences, script files atc. have been adapted to use the new "source" command - Related environment variables ("autoscript", "autoscript_uname") have *not* been adapted yet; these will be renamed resp. removed in a separate patch when the support for the "autoscr" command get's finally dropped. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-09-10cleanup use of CFG_ENV_IS_IN_FLASHJean-Christophe PLAGNIOL-VILLARD
- #if CFG_ENV_IS_IN_FLASH - #if (CFG_ENV_IS_IN_FLASH == 1) - #define CFG_ENV_IS_IN_FLASH 0 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-10rename CFG_ENV_IS_NOWHERE in CONFIG_ENV_IS_NOWHEREJean-Christophe PLAGNIOL-VILLARD
2008-04-13Coding Style cleanup; update CHANGELOGWolfgang Denk
2008-04-08SPARC/LEON2: added support for Gaisler simulator GRSIM/TSIM for SPARC/LEON2 ↵Daniel Hellstrom
targets. See www.gaisler.com for information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
