path: root/include/configs/gr_xc3s_1500.h
2014-03-21sparc: consolidate CONFIG_{LEON, LEON2, LEON3} definitionMasahiro Yamada
CONFIG_LEON is already defined in arch/sparc/cpu/{leon2,leon3}/config.mk. Remove the redundant definition in board header files. All leon3 boards define CONFIG_LEON3 in board header files. Move the definition to arch/sparc/cpu/leon3/config.mk. CONFIG_LEON2 can be move to arch/sparc/cpu/leon2/config.mk as well. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Hellstrom <daniel@gaisler.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-12-05sparc: fix unknown escape sequence warningsMike Frysinger
I don't know what exactly the code was going for, but the object code is the same before/after my change, and in looking at the env strings, this seems to be OK. Otherwise gcc warns: cc1: warning: unknown escape sequence: '\$' cc1: warning: unknown escape sequence: '\)' cc1: warning: unknown escape sequence: '\040' cc1: warning: unknown escape sequence: '\$' cc1: warning: unknown escape sequence: '\)' Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22common: cosmetic: CONFIG_BOOTFILE checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22common: cosmetic: CONFIG_ROOTPATH checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2008-09-10rename CFG_ENV_IS_NOWHERE in CONFIG_ENV_IS_NOWHEREJean-Christophe PLAGNIOL-VILLARD
2008-04-08SPARC/LEON3: added support for GR-XC3S-1500 board with GRLIB template ↵Daniel Hellstrom
design. See www.gaisler.com for board information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
