path: root/include/configs/gr_xc3s_1500.h
2015-11-13sparc: leon3: Added memory controller initialization using new AMBA PnP ↵Daniel Hellstrom
routines. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
2015-11-13sparc: Kconfig: Move the CMD_AMBAPP command to KconfigFrancois Retief
Add an initr function in the board_r.c file for the AMBA Plug&Play command. Add a Kconfig entry for the ambapp command and remove all CONFIG_CMD_AMBAPP defines from the board configuration headers. Add a Kconfig entry to display the AMBA Plug&Play information on startup. This option is off by default. Remove relevent define from board configuration headers. Signed-off-by: Francois Retief <fgretief@spaceteq.co.za>
2015-11-13sparc: Update LEON serial drivers to use readl/writel macrosFrancois Retief
Update the LEON2/3 serial driver to make use of the readl and writel macros as well as the WATCHDOG_RESET() macro. Add readl/writel and friends to the asm/io.h file. Introduce the gd->arch.uart variable to store register address. Lastly, remove baudrate scaler macro variables from board config. It is now calculated in the serial driver using the global data variable. Signed-off-by: Francois Retief <fgretief@spaceteq.co.za>
2015-05-19net: Remove all references to CONFIG_ETHADDR and friendsJoe Hershberger
We really don't want boards defining fixed MAC addresses in their config so we just remove the option to set it in a fixed way. If you must have a MAC address that was not provisioned, then use the random MAC address functionality. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-03-21sparc: consolidate CONFIG_{LEON, LEON2, LEON3} definitionMasahiro Yamada
CONFIG_LEON is already defined in arch/sparc/cpu/{leon2,leon3}/config.mk. Remove the redundant definition in board header files. All leon3 boards define CONFIG_LEON3 in board header files. Move the definition to arch/sparc/cpu/leon3/config.mk. CONFIG_LEON2 can be move to arch/sparc/cpu/leon2/config.mk as well. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Daniel Hellstrom <daniel@gaisler.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-11-04config: Add a default CONFIG_SYS_PROMPTRob Herring
The definitions for CONFIG_SYS_PROMPT are varied with little reason other than to display the board name. Over half the definitions are "==> ", so make this the default. The rest of the boards remain unchanged to avoid breaking any external scripts expecting a certain prompt. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-12-05sparc: fix unknown escape sequence warningsMike Frysinger
I don't know what exactly the code was going for, but the object code is the same before/after my change, and in looking at the env strings, this seems to be OK. Otherwise gcc warns: cc1: warning: unknown escape sequence: '\$' cc1: warning: unknown escape sequence: '\)' cc1: warning: unknown escape sequence: '\040' cc1: warning: unknown escape sequence: '\$' cc1: warning: unknown escape sequence: '\)' Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22common: cosmetic: CONFIG_BOOTFILE checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_BOOTFILE to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-22common: cosmetic: CONFIG_ROOTPATH checkpatch complianceJoe Hershberger
Remove MK_STR from places that consume CONFIG_ROOTPATH to force all definitions to be string literals. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Wolfgang Denk <wd@denx.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2008-09-10rename CFG_ENV_IS_NOWHERE in CONFIG_ENV_IS_NOWHEREJean-Christophe PLAGNIOL-VILLARD
2008-04-08SPARC/LEON3: added support for GR-XC3S-1500 board with GRLIB template ↵Daniel Hellstrom
design. See www.gaisler.com for board information. Signed-off-by: Daniel Hellstrom <daniel@gaisler.com>
