path: root/include/configs/gplugd.h
2015-03-05arm: gplugd: convert to generic boardAjay Bhargav
Enable CONFIG_SYS_GENERIC_BOARD for Marvell gplugD. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Luka Perkov <luka.perkov@sartura.hr>
2012-04-19CMD: Remove CMD_AUTOSCRIPT, it's not usedMarek Vasut
$ git grep AUTOSCRIPT include/configs/at91sam9m10g45ek.h:#undef CONFIG_CMD_AUTOSCRIPT include/configs/gplugd.h:#define CONFIG_CMD_AUTOSCRIPT Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Anatolij Gustschin <agust@denx.de>
2012-03-19Armada100: gplugD: Add FAT & EXT2 command supportAjay Bhargav
This patch adds FAT and ext2 command support for marvell gplugD Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2012-03-19Armada100: gplugD: Add USB command supportAjay Bhargav
This patch adds support for USB commands and USB storage device for Marvell gplugD Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-11-03gplugD: Fix for error:MACH_TYPE_SHEEVAD undeclaredAjay Bhargav
This patch fix the build failure (error: 'MACH_TYPE_SHEEVAD' undeclared (first use in this function)) for gplugD due to recent sync of mach-types.h with its linux original. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-10-27Armada100: Add env storage support for Marvell gplugDAjay Bhargav
This patch adds support for envrionment varaible storage in SPI flash for Marvell gplugD. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-10-27Armada100: Add SPI flash support for Marvell gplugDAjay Bhargav
This patch enables Atmel AT45 SPI flash support for Marvell gplugD Enables SF commands. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-10-27Armada100: Add SPI support for Marvell gplugDAjay Bhargav
This patch add SPI driver support for Marvell gplugD Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-09-30Armada100: Enable 88E3015 PHY support for GplugDAjay Bhargav
This patch adds support for 88E3015 PHY for Marvell GplugD board. This patch depends on series of patch which adds support for Marvell GuruPlug-Display. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-09-30Armada100: Enable Ethernet support for GplugDAjay Bhargav
This patch enables ethernet support for Marvell GplugD board. Network related commands works. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-08-04Armada100: Add Board Support for Marvell GuruPlug-DisplayAjay Bhargav
This patch adds basic board support with DRAM and UART functionality Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com> Acked-by: Tanmay Upadhyay <tanmay.upadhyay@einfochips.com>
