path: root/include/configs/gplugd.h
2019-05-18CONFIG_SYS_[DI]CACHE_OFF: convert to KconfigTrevor Woerner
CONFIG_SYS_[DI]CACHE_OFF had been partially converted to Kconfig parameters; only for the ARC architecture. This patch turns these two parameters into Kconfig items everywhere else they are found. All of the include/configs/* and defconfig changes in this patch are for arm machines only. The Kconfig changes for arc, nds32, riscv, and xtensa have been included since these symbols are found in code under arch/{arc,nds32,riscv,xtensa}, however, no currently-defined include/configs/* or defconfigs for these architectures exist which include these symbols. These results have been confirmed with tools/moveconfig.py. Acked-by: Alexey Brodkin <abrodkin@snopsys.com> Signed-off-by: Trevor Woerner <trevor@toganlabs.com> [trini: Re-migrate for a few more boards] Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-22fs: fat: Drop CONFIG_SUPPORT_VFATTuomas Tynkkynen
fat.h unconditionally defines CONFIG_SUPPORT_VFAT (and has done since 2003), so as a result VFAT support is always enabled regardless of whether a board config defines it or not. Drop this unnecessary option. Signed-off-by: Tuomas Tynkkynen <tuomas@tuxera.com>
2017-05-15Kconfig: USB: Migrate CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCDTom Rini
In order to be able to migrate the various SoC EHCI CONFIG options we first need to finish the switch from CONFIG_USB_EHCI to CONFIG_USB_EHCI_HCD. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-01-28arm: Clean up MACH_TYPE_xxx usage after re-sync of mach-typesTom Rini
With the latest mach-types values we have many instances where we no longer need to define a value and a few cases where the name (but not value) have changed slightly. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-25Convert CONFIG_ARCH_MISC_INIT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ARCH_MISC_INIT Signed-off-by: Simon Glass <sjg@chromium.org>
2016-12-27Update Maintainer and Author's email addressAjay Bhargav
I am not longer using my old email address "ajay.bhargav@einfochips.com". For U-Boot development email address is now updated to contact@8051projects.net Signed-off-by: Ajay Bhargav <contact@8051projects.net>
2016-12-21spi: Zap armada100_spi.c and envJagan Teki
armada100_spi.c and related env is zapping becuase of "no DM conversion". Cc: Ajay Bhargav <ajay.bhargav@einfochips.com> Signed-off-by: Jagan Teki <jagan@openedev.com>
2015-03-05arm: gplugd: convert to generic boardAjay Bhargav
Enable CONFIG_SYS_GENERIC_BOARD for Marvell gplugD. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com> Acked-by: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Luka Perkov <luka.perkov@sartura.hr>
2012-04-19CMD: Remove CMD_AUTOSCRIPT, it's not usedMarek Vasut
$ git grep AUTOSCRIPT include/configs/at91sam9m10g45ek.h:#undef CONFIG_CMD_AUTOSCRIPT include/configs/gplugd.h:#define CONFIG_CMD_AUTOSCRIPT Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Prafulla Wadaskar <prafulla@marvell.com> Acked-by: Anatolij Gustschin <agust@denx.de>
2012-03-19Armada100: gplugD: Add FAT & EXT2 command supportAjay Bhargav
This patch adds FAT and ext2 command support for marvell gplugD Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2012-03-19Armada100: gplugD: Add USB command supportAjay Bhargav
This patch adds support for USB commands and USB storage device for Marvell gplugD Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-11-03gplugD: Fix for error:MACH_TYPE_SHEEVAD undeclaredAjay Bhargav
This patch fix the build failure (error: 'MACH_TYPE_SHEEVAD' undeclared (first use in this function)) for gplugD due to recent sync of mach-types.h with its linux original. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-10-27Armada100: Add env storage support for Marvell gplugDAjay Bhargav
This patch adds support for envrionment varaible storage in SPI flash for Marvell gplugD. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-10-27Armada100: Add SPI flash support for Marvell gplugDAjay Bhargav
This patch enables Atmel AT45 SPI flash support for Marvell gplugD Enables SF commands. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-10-27Armada100: Add SPI support for Marvell gplugDAjay Bhargav
This patch add SPI driver support for Marvell gplugD Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-09-30Armada100: Enable 88E3015 PHY support for GplugDAjay Bhargav
This patch adds support for 88E3015 PHY for Marvell GplugD board. This patch depends on series of patch which adds support for Marvell GuruPlug-Display. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-09-30Armada100: Enable Ethernet support for GplugDAjay Bhargav
This patch enables ethernet support for Marvell GplugD board. Network related commands works. Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com>
2011-08-04Armada100: Add Board Support for Marvell GuruPlug-DisplayAjay Bhargav
This patch adds basic board support with DRAM and UART functionality Signed-off-by: Prafulla Wadaskar <prafulla@marvell.com> Signed-off-by: Ajay Bhargav <ajay.bhargav@einfochips.com> Acked-by: Tanmay Upadhyay <tanmay.upadhyay@einfochips.com>
