CONFIG_SYS_NAND_U_BOOT_LOCATIONS
CONFIG_SYS_NAND_U_BOOT_OFFS
CONFIG_SYS_NAND_5_ADDR_CYCLE
CONFIG_SYS_NAND_BAD_BLOCK_POS
In order to do this, introduce a choice for HAS_LARGE/SMALL_BADBLOCK_POS
as those are the only valid values. Use LARGE as the default as no
in-tree boards use SMALL, but it is possible.
CONFIG_SYS_NAND_PAGE_COUNT
CONFIG_SPL_NAND_LOAD
CONFIG_SYS_NAND_BLOCK_SIZE
CONFIG_SYS_NAND_PAGE_SIZE
CONFIG_SYS_NAND_OOBSIZE
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
CONFIG_SKIP_LOWLEVEL_INIT
CONFIG_SKIP_LOWLEVEL_INIT_ONLY
In order to do this, we need to introduce SPL and TPL variants of these
options so that we can clearly disable these options only in SPL in some
cases, and both instances in other cases.
Now that we have consistent usage, migrate this symbol to Kconfig.
CONFIG_SPL_NAND_BASE
CONFIG_SPL_NAND_IDENT
CONFIG_SPL_NAND_DRIVERS
CONFIG_SPL_NAND_ECC
CONFIG_SPL_NAND_SIMPLE
Move this uncommon header out of the common header.
As previous CONFIG_SYS_UBOOT_START is now set by default to
CONFIG_SYS_TEXT_BASE when not defined, CONFIG_SYS_UBOOT_START
can be removed from include/configs board files.
Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
Acked-by: Lukasz Majewski <lukma@denx.de>
Enable the extended ENV options for AT91 and OMAP2PLUS in order to be
able to use CONFIG_ENV_UBI_* on these architectures.
As this change also makes the configs ENV_SIZE, ENV_SECT_SIZE,
ENV_OFFSET visible to AT91 and OMAP2PLUS, migrate users of these to
KConfig.
This migration was run using an extended moveconfig.py which evaluates
expressions such as "(512 << 10)". See patch ("moveconfig: expand
simple expressions").
All modified boards were built with SOURCE_DATE_EPOCH=0 before and
after the change and successfully confirmed that the identical binary
is generated (the only exception was igep00x0, which does not define
CONFIG_ENV_IS_IN_UBI in the original board header. Once that is
defined, the test passes too).
hs: rebased patch to:
68b90e57bc: "configs: tinker-rk3288 disable CONFIG_SPL_I2C_SUPPORT"
Signed-off-by: Markus Klotzbuecher <markus.klotzbuecher@kistler.com>
Cc: Eugen Hristev <eugen.hristev@microchip.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
The GARDENA smart Gateway boards are equipped with an Atmel / Microchip
AT91SAM9G25 SoC and with 128 MiB of RAM and 256 MiB of NAND storage.
This patch adds support for this board including SPL support. Therefore
the AT91Boostrap is not needed on this platform any more.
Cc: Andreas Bießmann <andreas@biessmann.org>
