path: root/include/configs/galaxy5200.h
2011-05-12Remove remnants of obsolete CONFIG_SYS_GBL_DATA_SIZE commentsMichael Jones
commit 25ddd1fb0a2281b182529afbc8fda5de2dc16d96 left remnants of many comments about CONFIG_SYS_GBL_DATA_SIZE. Signed-off-by: Michael Jones <michael.jones@matrix-vision.de>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2009-10-28galaxy5200: Add default environment variablesEric Millbrandt
Extend bootdelay to 10 seconds. Set boot retry time to 120 seconds and use reset to retry. Define default bootcommand and bootargs for production. Signed-off-by: Eric Millbrandt <emillbrandt@dekaresearch.com>
2009-10-18galaxy5200: change cs1 configurationEric Millbrandt
Correct the chip select configuration for the nand flash chip select. Signed-off-by: Eric Millbrandt <emillbrandt@dekaresearch.com>
2009-09-24galaxy5200: enable version environment variableEric Millbrandt
Add version environment variable configuration to the galaxy5200 board header file. Signed-off-by: Eric Millbrandt <emillbrandt@dekaresearch.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-06Reset i2c slave devices during init on mpc5xxx cpusEric Millbrandt
Reset any i2c devices that may have been interrupted during a system reset. Normally this would be accomplished by clocking the line until SCL and SDA are released and then sending a start condtiion (From an Atmel datasheet). There is no direct access to the i2c pins so instead create start commands through the i2c interface. Send a start command then delay for the SDA Hold time, repeat this by disabling/enabling the bus a total of 9 times. Signed-off-by: Eric Millbrandt <emillbrandt@dekaresearch.com>
2009-09-04galaxy5200: Add chip select region for an Epson S1D15313Eric Millbrandt
2009-08-26galaxy5200: Cleanup typo and trailing whitespaceEric Millbrandt
2009-08-25Add support for the galaxy5200Eric Millbrandt
Add support for the DEKA Research and Development galaxy5200 board The galaxy5200 is an Freescale mpc5200 based embedded industrial control board. Signed-off-by: Eric Millbrandt <emillbrandt@dekaresearch.com>
