path: root/include/configs/fennec_rk3288.h
2017-04-30Convert CONFIG_SYS_WHITE_ON_BLACK to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_WHITE_ON_BLACK Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y on various SoCs] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-04rockchip: configs: correct mmc env dev for rk3288 based boardsJacob Chen
we are using mmc alias , so mmc index have been changed. now mmc dev 0 is emmc and mmc dev 1 is sdmmc. Signed-off-by: Jacob Chen <jacob2.chen@rock-chips.com>
2017-02-09rockchip: configs: move env offset to common headerJacob Chen
To reduce redundant code. Signed-off-by: Jacob Chen <jacob2.chen@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-01-11rockchip: configs: correct env offset when enable ↵Jacob Chen
CONFIG_ROCKCHIP_SPL_BACK_TO_BROM With CONFIG_ROCKCHIP_SPL_BACK_TO_BROM enabled, the environment is inside u-boot. So solve it by moving environment after u-boot. Signed-off-by: Jacob Chen <jacob2.chen@rock-chips.com>
2016-10-23Convert CONFIG_CONSOLE_SCROLL_LINES to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CONSOLE_SCROLL_LINES Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-07-31rockchip: add basic support for fennec-rk3288 boardjk.kernel@gmail.com
Fennec is a RK3288-based development board with 2 USB ports, HDMI, micro-SD card, audio and WiFi and Gigabit Ethernet. It also includes on-board 8GB eMMC and 2GB of SDRAM. Expansion connectors provides access to display pins, I2C, SPI, UART and GPIOs. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
