path: root/include/configs/favr-32-ezkit.h
2008-09-07ap325rxa/favr-32-ezkit: Use CONFIG_FLASH_CFI_DRIVERJean-Christophe PLAGNIOL-VILLARD
2008-08-20favr-32-ezkit: Fix printf format warningsHaavard Skinnemoen
Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2008-08-06avr32: add support for EarthLCD Favr-32 boardHans-Christian Egtvedt
This patch adds support for the Favr-32 board made by EarthLCD. This kit, which is also called ezLCD-101 when running with EarthLCD firmware, has a 10.4" touch screen LCD panel, 16 MB 32-bit SDRAM, 8 MB parallel flash, Ethernet, audio out, USB device, SD-card slot, USART and various other connectors for cennecting stuff to SPI, I2C, GPIO, etc. Signed-off-by: Hans-Christian Egtvedt <hans-christian.egtvedt@atmel.com> Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
