path: root/include/configs/exynos5420-common.h
2015-08-05exynos: Drop old exynos5420-specific board codeSimon Glass
Now that exynos5420 boards can use the generic exynos5 code, switch over to it and remove the old code. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2015-08-05exynos: config: Move common options to the common headers and tidy upSimon Glass
Many options are duplicated on the exynos5 boards. Move these to the common files. Also some options are not used so can be removed. Tidy this up to make the files easier to maintain. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2015-04-18exynos: cros_ec: Drop unnecessary initSimon Glass
Since driver model will probe the EC when it is first used, we do not need to init it explicitly. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-28Exynos542x: Config: Add various configsAkshay Saraswat
This patch adds "iRAM, CPU state and low power" configs which are the addresses acting as flag registers. iROM code checks CONFIG_LOWPOWER_FLAG address. If it is equal to CONFIG_LOWPOWER_EN then it jumps to the address (0x02020000+CPUID*4). This is a part of iROM logic. Rest other flags are being used at various places during kernel switching and reset. They are nowhere documented because they are part programming. These configs are serving as flags for us because they are representing the addresses in iRAM which we are using for storing and extracting CPU Status and GIC status. Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-12-30Exynos: Move down common USB configurationSjoerd Simons
USB is a pretty common feature on exynos 5 board, so it seems sensible to configure it directly from exynos5-common. As a side-effect this makes USB available from u-boot on exynos 5420 based boards. While there enable support for common USB ethernet cards to make it more likely the default config allows booting for network and enable XHCI on SMDK5420 which has it defined in the dts but not in its config. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-12-22config: exynos5420: move non common configs to specific board filesHyungwon Hwang
The media for boot and environment is a board-specific feature, not a processor-specific. This is same to console port number and some other addresses. This patch moves the that kinds of configs to each board-specific files from the common config file for Exynos5420. Signed-off-by: Hyungwon Hwang <human.hwang@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Kevin Hilman <khilman@linaro.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-11-17exynos5: Use config_distro_bootcmd.hIan Campbell
This replaces the existing CONFIG_BOOTCOMMAND for exynos5250 and 5420. exynos4 platforms seem to have existing complex extra env configuration for booting and so are excluded here. Hence the bootcmd.h is added to exynos5-common.h. I have build tested on all exynos platforms (MAKEALL -s exynos), but only boot tested on arndale. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Guillaume GARDET <guillaume.gardet@free.fr> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-11-17Config: Exynos5420: Refactor SDRAM Bank and SizeAkshay Saraswat
Since, not every board may have all memory channels configured and all available banks of DMC used, we wish to refactor configs for Memory Bank size and numbers as per board memory config. For Example, Peach-Pit has 2GB memory and will be using only 4 banks but Peach-Pi has 3.5GB memory and will be using all 7 available SDRAM banks. Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-11-17Config: Exynos5800: Enable build for Peach-PiAkshay Saraswat
This adds following things : - New config and defconfig for Peach-Pi board. - Alterations in Kconfig and MAINTAINERS. - Addition of CONFIG_EXYNOS5800. - ADdition of exynos5800-peach-pi in dts list. Signed-off-by: Akshay Saraswat <akshay.s@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-08config: Move arndale to use common exynos5250 fileSimon Glass
Most of the arndale features are common with other exynos5250 boards. To permit easier addition of driver model support, use the common file. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-08exynos: Move common smdk5420 things to common fileSimon Glass
A few things are common but are not in the common file. Fix this and rename the file to fit with the other exynos*-common files. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
