path: root/include/configs/exynos5-dt-common.h
2016-05-25exynos: video: Convert several boards to driver model for videoSimon Glass
Update several boards to use driver model for video. This involves changes to the EDP and FIMD (frame buffer) drivers. Existing PWM, simple-panel and pwm-backlight drivers are used. These work without additional configuration since they use the device tree settings in the same way as Linux. Boards converted are: - snow - spring - peach-pit - peach-pi All have been tested. Not converted: - MIPI display driver - s5pc210_universal - smdk5420 - smdk5250 - trats - trats2 Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-08-05exynos: Drop old exynos5250-specific board codeSimon Glass
Now that most exynos5250 boards can use the generic exynos5 code, switch over to it and remove the old code. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05exynos: config: Move common options to the common headers and tidy upSimon Glass
Many options are duplicated on the exynos5 boards. Move these to the common files. Also some options are not used so can be removed. Tidy this up to make the files easier to maintain. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2015-08-05exynos: Enable new features for exynos5 boardsSimon Glass
Enable PMICs, regulators and the like so that new drivers will be made available. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-19dm: cros_ec: Convert to KconfigSimon Glass
Since both I2C and SPI are converted to Kconfig, we can convert cros_ec to Kconfig for these buses. LPC will need to wait until driver mode PCI is available. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-17exynos5: Use config_distro_bootcmd.hIan Campbell
This replaces the existing CONFIG_BOOTCOMMAND for exynos5250 and 5420. exynos4 platforms seem to have existing complex extra env configuration for booting and so are excluded here. Hence the bootcmd.h is added to exynos5-common.h. I have build tested on all exynos platforms (MAKEALL -s exynos), but only boot tested on arndale. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Guillaume GARDET <guillaume.gardet@free.fr> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-08exynos: config: Move cros_ec and tps65090 out of smdk boardsSimon Glass
These boards do not in fact have a Chrome OS EC, nor a TPS565090 PMIC, so move the settings into a separate common file to be used by those that need it. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
