path: root/include/configs/exynos5-common.h
2016-03-11exynos5: common: Enable CONFIG_USB_ETHER_RTL8152 ethernet supportAnand Moon
Enable CONFIG_USB_ETHER_RTL8152 support for Odroid XU4 which has support for RTL8153-CG gigabit Ethernet adapter, connected over USB 3.0. commit 9dc8ba19c50fc0b1623c654bcfe6caa903a4c36c added support for Realtek 8152/8153 driver. Signed-off-by: Anand Moon <linux.amoon@gmail.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2015-08-31tpm: Convert board config TPM options to KconfigSimon Glass
Convert all TPM options to Kconfig and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard <christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-31tpm: Drop two unused optionsSimon Glass
The address of the I2C TPM is now defined in the device tree so there is no need for the CONFIG options. Remove them from the README and board config to avoid confusion. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Christophe Ricard <christophe-h.ricard@st.com> Reviewed-by: Heiko Schocher <hs@denx.de>
2015-08-05exynos: config: Move common options to the common headers and tidy upSimon Glass
Many options are duplicated on the exynos5 boards. Move these to the common files. Also some options are not used so can be removed. Tidy this up to make the files easier to maintain. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Przemyslaw Marczak <p.marczak@samsung.com>
2015-08-05exynos: Enable new features for exynos5 boardsSimon Glass
Enable PMICs, regulators and the like so that new drivers will be made available. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-22usb: xhci: exynos: Remove common dwc3 drv functions callsRamneek Mehresh
Remove all redundant dwc3 driver function calls that are defined by dwc3 driver Signed-off-by: Ramneek Mehresh <ramneek.mehresh@freescale.com>
2015-05-14exynos5: fix build break by adding CONFIG_POWERPrzemyslaw Marczak
Move the configs listed below from exynos5-dt-common.h to exynos5-common.h: - CONFIG_POWER - CONFIG_POWER_I2C fixes build break for Arndale and Smdk5250 boards. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Simon Glass <sjg@chromium.org>
2015-04-06exynos5: add trace feature #ifdef in exynos5-common.hInha Song
We can enable / disable trace feature from the FTRACE config options. To enable, compile U-Boot with FTRACE=1. This patch add #ifdef FTRACE in exynos5-common.h for enable/disable to use FTRACE configs instead of having to change board config files. Signed-off-by: Inha Song <ideal.song@samsung.com> Acked-by: Simon Glass <sjg@chroimum.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-02-19dm: Move CONFIG_I2C_COMPAT to KconfigSimon Glass
Make this option available in Kconfig and clean up the board that uses it. Note there is also an entry in exynos5-common.h but this affects multiple boards and should be dropped as part of the Samsung I2C migration to driver model. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-01-29exynos5: enable dm i2cPrzemyslaw Marczak
This patch enables CONFIG_DM_I2C and also CONFIG_DM_I2C_COMPAT. The last one should be removed when all the i2c peripheral drivers will use dm i2c framework. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Simon Glass <sjg@chromium.org> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Simon Glass <sjg@chromium.org>
2014-12-30Exynos: Move down common USB configurationSjoerd Simons
USB is a pretty common feature on exynos 5 board, so it seems sensible to configure it directly from exynos5-common. As a side-effect this makes USB available from u-boot on exynos 5420 based boards. While there enable support for common USB ethernet cards to make it more likely the default config allows booting for network and enable XHCI on SMDK5420 which has it defined in the dts but not in its config. Signed-off-by: Sjoerd Simons <sjoerd.simons@collabora.co.uk> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-11-17exynos5: Use config_distro_bootcmd.hIan Campbell
This replaces the existing CONFIG_BOOTCOMMAND for exynos5250 and 5420. exynos4 platforms seem to have existing complex extra env configuration for booting and so are excluded here. Hence the bootcmd.h is added to exynos5-common.h. I have build tested on all exynos platforms (MAKEALL -s exynos), but only boot tested on arndale. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Guillaume GARDET <guillaume.gardet@free.fr> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-11-17exynos: Enable config_distro_defaults.hIan Campbell
...and remove explicit setting of things which this implies. This is done for all exynos platforms (4 & 5) so it is added to exynos-common.h I'm mainly interested in CONFIG_CMD_BOOTZ and CONFIG_SUPPORT_RAW_INITRD I have build tested on all exynos platforms (MAKEALL -s exynos), but only boot tested on arndale. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Guillaume GARDET <guillaume.gardet@free.fr> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-08config: Move arndale to use common exynos5250 fileSimon Glass
Most of the arndale features are common with other exynos5250 boards. To permit easier addition of driver model support, use the common file. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-08exynos: config: Move cros_ec and tps65090 out of smdk boardsSimon Glass
These boards do not in fact have a Chrome OS EC, nor a TPS565090 PMIC, so move the settings into a separate common file to be used by those that need it. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-08exynos: Move common exynos settings into a common fileSimon Glass
Since exynos4 and exyno5 share many settings, we should move these into a common file to avoid duplication. In effect the changes are that all exynos boards now have EXT4 and FAT write support. This affects exynos5250 and exynos5420 which previously did not. This also disables the ext2 commands which are equivalent to ext4 anyway. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-08exynos: Rename -dt config files to -commonSimon Glass
We want exynos5250-dt.h to be a board which can support any exynos5250 device. This matches the naming used by Linux. As a first step, rename the existing -dt files to -common to make it clear they are common files, and not specific boards. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
