path: root/include/configs/exynos-common.h
2019-01-19Kconfig: Migrate BOUNCE_BUFFERPhilipp Tomsich
The bounce buffer is used by a few drivers (most of the MMC drivers) to overcome limitations in their respective DMA implementation. This moves the configuration to Kconfig and makes it user-selectable (even though it will be a required feature to make those drivers work): the expected usage is for drivers depending on this to 'select' it unconditionally from their respective Kconfig (see follow-up patches). This commit includes a full migration using moveconfig.py to ensure that each commit compiles. To ensure bisectability we update dependencies of various drivers to now select BOUNCE_BUFFER when needed. [trini: Squash all patches to ensure bisectability] Signed-off-by: Tom Rini <trini@konsulko.com> Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Otavio Salvador <otavio@ossystems.com.br> [dw_mmc portion] Reviewed-by: Fabio Estevam <festevam@gmail.com> [mxsmmc portion] Reviewed-by: Simon Glass <sjg@chromium.org> [tegra portion]
2018-02-23Remove config_distro_defaults.hAdam Ford
With the contents of config_distro_defaults.h migrated to Kconfig, we can remove this header file completely Signed-off-by: Adam Ford <aford173@gmail.com>
2017-09-03include/configs: drop default definitions of CONFIG_SYS_MAXARGSThomas Petazzoni
Now that include/config_fallbacks.h define a sane fallback for CONFIG_SYS_MAXARGS, we can drop the definition of this constant in all configurations that were using the default value. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-06-03Kconfig: Migrate FS_FAT / FAT_WRITETom Rini
Now that these symbols are in Kconfig, migrate all users. Use imply on a number of platforms that default to having this enabled. As part of this we must migrate some straglers for CMD_FAT and DOS_PARTITION. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05ARM: rename CONFIG_TIMER_CLK_FREQ to COUNTER_FREQUENCYAndre Przywara
Many ARMv8 boards define a constant COUNTER_FREQUENCY to specify the frequency of the ARM Generic Timer (aka. arch timer). ARMv7 boards traditionally used CONFIG_TIMER_CLK_FREQ for the same purpose. It seems useful to unify them. Since there are less occurences of the latter version, lets convert all users over to COUNTER_FREQUENCY. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-01-31mmc: move CONFIG_GENERIC_MMC to KconfigMasahiro Yamada
Now, CONFIG_GENERIC_MMC seems equivalent to CONFIG_MMC. Let's create an entry for "config GENERIC_MMC" with "default MMC", then convert all macro defines in headers to Kconfig. Almost all of the defines will go away. I see only two exceptions: configs/blanche_defconfig configs/sandbox_noblk_defconfig They define CONFIG_GENERIC_MMC, but not CONFIG_MMC. Something might be wrong with these two boards, so should be checked later. Anyway, this is the output of the moveconfig tool. This commit was created as follows: [1] create a config entry in drivers/mmc/Kconfig [2] tools/moveconfig.py -r HEAD GENERIC_MMC [3] manual clean-up of garbage comments in doc/README.* and include/configs/*.h Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-01-11mmc: move DesignWare-based drivers to KconfigMasahiro Yamada
Move (and rename) the following CONFIG options to Kconfig: CONFIG_EXYNOS_DWMMC (renamed to CONFIG_MMC_DW_EXYNOS) CONFIG_HIKEY_DWMMC (renamed to CONFIG_MMC_DW_K3) CONFIG_SOCFPGA_DWMMC (renamed to CONFIG_MMC_DW_SOCFPGA) The "HIKEY" is a board name, so it is not suitable for the MMC controller name. I am following the name used in Linux. This commit was generated as follows: [1] Rename the config options with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_EXYNOS_DWMMC/CONFIG_MMC_DW_EXYNOS/g s/CONFIG_HIKEY_DWMMC/CONFIG_MMC_DW_K3/g s/CONFIG_SOCFPGA_DWMMC/CONFIG_MMC_DW_SOCFPGA/g ' [2] Commit the changes [3] Create the entries in drivers/mmc/Kconfig (with default y for EXYNOS and SOCFPGA) [4] Run the following: tools/moveconfig.py -y -r HEAD MMC_DW_EXYNOS MMC_DW_K3 MMC_DW_SOCFPGA [5] Sort and align drivers/mmc/Makefile for readability [6] Clean-up doc/README.socfpga by hand Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2017-01-11mmc: move CONFIG_DWMMC to Kconfig, renaming to CONFIG_MMC_DWMasahiro Yamada
This commit was created as follows: [1] Rename the option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_DWMMC/CONFIG_MMC_DW/g' [2] create the entry for MMC_DW in drivers/mmc/Kconfig (the prompt and help were copied from Linux) [3] run "tools/moveconfig.py -y MMC_DW" [4] add "depends on MMC_DW" to the MMC_DW_ROCKCHIP entry [5] Clean-up doc/README.socfpga by hand Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Marek Vasut <marex@denx.de>
2016-12-29mmc: move some SDHCI related options to KconfigMasahiro Yamada
While I moved the options, I also renamed them so that they are all prefixed with MMC_SDHCI_. This commit was created in the following steps. [1] Rename with the following command find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e ' s/CONFIG_MMC_SDMA/CONFIG_MMC_SDHCI_SDMA/g s/CONFIG_BCM2835_SDHCI/CONFIG_MMC_SDHCI_BCM2835/g s/CONFIG_KONA_SDHCI/CONFIG_MMC_SDHCI_KONA/g s/CONFIG_MV_SDHCI/CONFIG_MMC_SDHCI_MV/g s/CONFIG_S5P_SDHCI/CONFIG_MMC_SDHCI_S5P/g s/CONFIG_SPEAR_SDHCI/CONFIG_MMC_SDHCI_SPEAR/g ' [2] create the Kconfig entries in drivers/mmc/Kconfig [3] Move the options by the following command tools/moveconfig.py -y MMC_SDHCI_SDMA MMC_SDHCI_BCM2835 \ MMC_SDHCI_KONA MMC_SDHCI_MV MMC_SDHCI_S5P MMC_SDHCI_SPEAR [4] Sort drivers/mmc/Makefile for readability Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-29mmc: move CONFIG_SDHCI to Kconfig, renaming to CONFIG_MMC_SDHCIMasahiro Yamada
Move CONFIG_SDHCI to Kconfig and rename it to CONFIG_MMC_SDHCI. My motivation for the rename is, ultimately, to make all the MMC options prefixed with MMC_ and SDHCI options with MMC_SDHCI_, like Linux. This commit was created as follows: [1] Rename the config option with the following command: find . -name .git -prune -o ! -path ./scripts/config_whitelist.txt \ -type f -print | xargs sed -i -e 's/CONFIG_SDHCI/CONFIG_MMC_SDHCI/g' [2] create the entry for MMC_SDHCI in drivers/mmc/Kconfig [3] run "tools/moveconfig.py -y MMC_SDHCI" [4] add "depends on MMC_SDHCI" to existing SDHCI driver entries Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
2016-12-16Kconfig: Move USE_ARCH_MEMCPY/MEMSET to KconfigFabio Estevam
Move USE_ARCH_MEMCPY/MEMSET options to Kconfig. Make it "default y" for the ARMv7 architecture and make it depend on !ARM64 && !SPL. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-07-01autoboot: remove CONFIG_ZERO_BOOTDELAY_CHECKMasahiro Yamada
As the help message of CONFIG_BOOTDELAY says, CONFIG_BOOTDELAY=-2 means the autoboot with no delay, with no abort check even if CONFIG_ZERO_BOOTDELAY_CHECK is defined. To sum up, the autoboot behaves as follows: [1] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=y autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n autoboot with no delay, with no check for abort [3] CONFIG_BOOTDELAY=-1 disable autoboot [4] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort As you notice, [2] and [4] come to the same result, which means we do not need CONFIG_ZERO_BOOTDELAY_CHECK. We can control all the cases only by CONFIG_BOOTDELAY, like this: [1] CONFIG_BOOTDELAY=0 autoboot with no delay, but you can abort it by key input [2] CONFIG_BOOTDELAY=-1 disable autoboot [3] CONFIG_BOOTDELAY=-2 autoboot with no delay, with no check for abort This commit converts the logic as follow: CONFIG_BOOTDELAY=0 && CONFIG_ZERO_BOOTDELAY_CHECK=n --> CONFIG_BOOTDELAY=-2 Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Stefan Roese <sr@denx.de> Acked-by: Igor Grinberg <grinberg@compulab.co.il> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Vladimir Zapolskiy <vz@mleia.com> Reviewed-by: Heiko Schocher <hs@denx.de> Acked-by: Christian Riesch <christian.riesch@omicronenergy.com> Acked-by: Hannes Schmelzer <hannes.schmelzer@br-automation.com>
2016-04-26Merge branch 'master' of git://git.denx.de/u-boot-samsungTom Rini
2016-04-25include/configs: Whitespace fixupTom Rini
A number of moveconfig.py runs have left a instances of multiple empty lines in a row. Correct this to a single empty line. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-04-14exynos: Set CNTFRQAlexander Graf
Commit 73a1cb27 moved the check whether we should set the architected timer frequency from CONFIG_SYS_CLK_FREQ to CONFIG_TIMER_CLK_FREQ, but did not update all users of it. The one where I (finally) realized why KVM didn't work is the Arndale board, so this patch adds the respective define to it. Signed-off-by: Alexander Graf <agraf@suse.de> Fixes: 73a1cb27 Reviewed-by: York Sun <york.sun@nxp.com> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2015-03-09exynos: config: enable arch memcpy and arch memsetPrzemyslaw Marczak
This commit enables the following configs: - CONFIG_USE_ARCH_MEMCPY - CONFIG_USE_ARCH_MEMSET This increases the performance of memcpy/memset and also reduces the boot time. This was tested on Trats2. A quick test with trace. Boot time from start to main_loop() entry: - ~1527ms - before this change (arch memset enabled for .bss clear) - ~1384ms - after this change Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Reviewed-by: Simon Glass <sjg@chromium.org> Cc: Minkyu Kang <mk7.kang@samsung.com> Cc: Akshay Saraswat <akshay.s@samsung.com> Cc: Simon Glass <sjg@chromium.org> Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
2015-02-12dm: Kconfig: Move CONFIG_SYS_MALLOC_F_LEN to KconfigSimon Glass
Move this option to Kconfig and update all boards. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-02-12dm: exynos: Move driver model CONFIGs to KconfigSimon Glass
Remove driver model CONFIGs from the board config headers and use Kconfig instead. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-11-17exynos: Increase command line buffer size (CONFIG_SYS_CBSIZE)Ian Campbell
I was running into this limit with a not overly long PXE append line. Since the PXE code wants to print the resulting command line increase CONFIG_SYS_PBSIZE too. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-11-17exynos: Enable config_distro_defaults.hIan Campbell
...and remove explicit setting of things which this implies. This is done for all exynos platforms (4 & 5) so it is added to exynos-common.h I'm mainly interested in CONFIG_CMD_BOOTZ and CONFIG_SUPPORT_RAW_INITRD I have build tested on all exynos platforms (MAKEALL -s exynos), but only boot tested on arndale. Signed-off-by: Ian Campbell <ian.campbell@citrix.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Guillaume GARDET <guillaume.gardet@free.fr> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-27exynos: common: enable generic fs operationsPrzemyslaw Marczak
This config is required by Odroid, and could be also useful for the other boards. Signed-off-by: Przemyslaw Marczak <p.marczak@samsung.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-10-22dm: exynos: config: Use driver model for SPI flashSimon Glass
Use driver model for exynos5 board SPI flash. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2014-10-22dm: exynos: Convert SPI to driver modelSimon Glass
Move the exynos SPI driver over to driver model. This removes quite a bit of boilerplate from the driver, although it adds some for driver model. A few device tree additions are needed to make the SPI flash available. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagannadha Sutradharudu Teki <jagannadh.teki@gmail.com>
2014-10-22dm: exynos: Move serial to driver modelSimon Glass
Change the Exynos serial driver to work with driver model and switch over all relevant boards to use it. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-22dm: exynos: gpio: Convert to driver modelSimon Glass
Convert the exynos GPIO driver to driver model. This implements the generic GPIO interface but not the extra Exynos-specific functions. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-08exynos: Enable pre-relocation malloc()Simon Glass
Enable this feature to support driver model before relocation. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-08config: Move arndale to use common exynos5250 fileSimon Glass
Most of the arndale features are common with other exynos5250 boards. To permit easier addition of driver model support, use the common file. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2014-10-08exynos: Move common exynos settings into a common fileSimon Glass
Since exynos4 and exyno5 share many settings, we should move these into a common file to avoid duplication. In effect the changes are that all exynos boards now have EXT4 and FAT write support. This affects exynos5250 and exynos5420 which previously did not. This also disables the ext2 commands which are equivalent to ext4 anyway. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
