path: root/include/configs/evb_rv1108.h
2017-06-07rockchip: Add basic support for evb-rv1108 boardAndy Yan
Add basic support for rv1108 evb, whith this patch we can boot into u-boot console. Signed-off-by: Andy Yan <andy.yan@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
