path: root/include/configs/evb_rk3399.h
2017-10-01evb-rk3399: avoid redefinition of CONFIG_ENV_OFFSETHeinrich Schuchardt
CONFIG_ENV_OFFSET is already defined in include/configs/rockchip-common.h For CONFIG_ROCKCHIP_BACK_TO_BROM=y we redefine CONFIG_ENV_OFFSET to an unsuitable value. We were lucky to get a compiler warning. Remove the incorrect redefinition. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de> Acked-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-04-30Convert CONFIG_SYS_WHITE_ON_BLACK to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_WHITE_ON_BLACK Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y on various SoCs] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-30evb-rk3399: config: set emmc as default boot devKever Yang
rk3399 has two mmc dev controller: mmc 0: SD card; mmc 1: EMMC U-Boot will scan the mmc boot device configured by CONFIG_SYS_MMC_ENV_DEV, since evb has emmc on board, let's set the EMMC as default. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2016-10-23Convert CONFIG_CONSOLE_SCROLL_LINES to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CONSOLE_SCROLL_LINES Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-07-25ARM64: rockchip: add support for rk3399 SoC based evbKever Yang
RK3399 is a SoC from Rockchip with dual-core Cortex-A72 and quad-core Cortex-A53 CPU. It supports two USB3.0 type-C ports and two USB2.0 EHCI ports. Other interfaces are very much like RK3288, the DRAM are 32bit width address and support address from 0 to 4GB-128MB range. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
