path: root/include/configs/ethernut5.h
2014-06-14arm: ethernut5: convert to generic boardTim Schendekehl
Enable CONFIG_SYS_GENERIC_BOARD for the Ethernut 5 board. Signed-off-by: Tim Schendekehl <tim.schendekehl@egnite.de> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-05-27ARM: at91: remove redundant ARM926EJS definition in board config filesWu, Josh
As at91 board config file will include the SoC header, so we can remove the ARM926EJS definition in board config files. Signed-off-by: Josh Wu <josh.wu@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2014-05-27at91: remove redundant AT91FAMILY definition in board config fileWu, Josh
Now the AT91FAMILY is already defined in the at91 SoC header. The at91 board config file will include the SoC header file. So we can remove the redundant AT91FAMILY definition in at91 board config files. Signed-off-by: Josh Wu <josh.wu@atmel.com> [rebase patch] Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-12-09at91: nand: switch atmel_nand to generic GPIO APIAndreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de> Tested-by: Jens Scharsig (BuS Elektronik)<esw@bus-elektronik.de> Acked-by: Scott Wood <scottwood@freescale.com>
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
2013-11-04arm: atmel: get rid of too many ifdefferyBo Shen
Get rid of too many ifdeffery in usb ohci driver Add following two configuration for USB clock selecting - CONFIG_USB_ATMEL_CLK_SEL_PLLB: using PLLB as usb ohci input clock - CONFIG_USB_ATMEL_CLK_SEL_UPLL: using UPLL as usb ohci input clock Signed-off-by: Bo Shen <voice.shen@atmel.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2012-09-01ARM: Remove unused stack and irq config definesRob Herring
CONFIG_STACKSIZE is not referenced anywhere except on AVR32, but present in most ARM board config files. IRQs are only enabled for 1 config, so remove the unused config options for IRQ and FIQ stack size as well. Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-02-12configs: Remove CONFIG_NET_MULTI from board filesFabio Estevam
CONFIG_NET_MULTI is not used anymore, so remove it from board files. Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Kumar Gala <kumar.gala@freescale.com> Cc: Sandeep Paulraj <s-paulraj@ti.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Tom Rini <trini@ti.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Heiko Schocher <hs@denx.de> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Stefano Babic <sbabic@denx.de> Tested-by: Marek Vasut <marek.vasut@gmail.com> Tested-by: Heiko Schocher <hs@denx.de>
2011-12-06Ethernut 5 board supportTim Schendekehl
Add support for the Ethernut 5 open hardware design, based on Atmel's AT91SAM9XE512 SoC. V4 - Fix several coding style issues. - Move machine type to config file. - Remove use of CONFIG_ATMEL_LEGACY. Signed-off-by: Tim Schendekehl <tim.schendekehl@egnite.de>
